0 Replies Latest reply on Mar 7, 2007 7:51 AM by Holoville
    Loading only one class in the first frame
    Holoville
      Hello,
      I'm really stuck with this, so I'd really be grateful for some help...
      I built a preloader component, which is, obviously, used to preload a flash movie. The problem comes if I have other component inside the main movie. To preload components, you need to set "export frame for classes" option to a frame different than the first, but if I do so, my preloader's classes won't be loaded either!
      Anybody know if there's a way to load only one class in the first frame, while all the others load in a different frame? I tried to import the preloader's classes using "import..." but it doesn't function. And I can't to load the components from other external swfs (which would solve the problem).
      Thanks for any help!
      Bab
