1 Reply Latest reply on Dec 22, 2014 4:37 PM by A.T. Romano
    Can you work on multiple projects at one? And cut and paste between projects?
    sjuniper
      Is it possible to work on multiple projects at once?   I would like to cut and paste clips from one project to another?  Is this possible?
        • 1. Re: Can you work on multiple projects at one? And cut and paste between projects?
          A.T. Romano Level 7
          sjuniper
          What version of Premiere Elements is involved and on what computer operating system is it running?
          If Mac, then I have no answer for a program that will allow you to do a copy/paste insert between Premiere Elements projects.
          If Windows, then you should be able to do that copy/paste insert between Premiere Elements projects, using Premiere Elements
          in conjunction with ClipMate. Please refer to the following link
          ATR Premiere Elements Troubleshooting: PE: ClipMate Copy/Paste Between Projects
          The alternative is to export the project 1 Timeline content to a file saved to the computer hard drive and then import that export from project 1 into project 2 whose project preset has been set to match the properties of the export from project 1.
          There are no sequences in Premiere Elements as in Premiere Pro.
          Were you thinking of trying to set up several separated and different Timelines in Premiere Elements to work with them all within one project. Each Premiere Elements project can have only one project preset.
          Please review and consider and supply more details.
          Thank you.
          ATR
