6 Replies Latest reply on Dec 23, 2014 2:43 PM by Willi Adelberger
    How to create a completely separte duplicate of a book and all of its associated indd files.
    michmoore
      What's the best way to create a duplicate copy of an entire InDesign book (.indb), including all indd files associated with it? I need to maintain one copy of the book for print production and another copy for EPUB export which will require formatting changes that would be inappropriate for printing.
      I have already copied all applicable indd files to a new folder, then copied the indb file over, then selected "Replace Document" to change the file path for all applicable indd files in the copied book. However, I'm concerned that all the cross references may still be pointing back to the old book files. Unfortunately, there's no easy way to tell because when I view the "Cross-Reference Options" for a cross-reference, it does not show the file path for the Document, just the name of the document. I'm also concerned there could be some other connections between the old and the duplicate indd or indb files in some other way I'm unaware of.
      To clarify, I would like two completely different file folders with the same indb and multiple indd files in them to start with, such that all cross references in the newly duplicated ebook and indd files stay relative to the new ebook and new indd files. Is there an easy way to verify the file path, not just the file name, for a cross-references's document?
        • 2. Re: How to create a completely separte duplicate of a book and all of its associated indd files.
          michmoore Level 1
          Hi Willi, I'm pretty new to InDesign and thought that packaging was used to ensure all files are properly formatted and present in one place to pass along to a printer. I did read a thread about using this feature to help with duplicating files, but it was very short and didn't explain the details. If you have a packaged book, what steps would you follow to turn the package into an separate book and supporting indd files in a different file folder unconnected to the original book or supporting files?
          • 4. Re: How to create a completely separte duplicate of a book and all of its associated indd files.
            michmoore Level 1
            For some reason, packaging the book failed. Preflight book passed with green marks next to all indd files in the book pallet. However, when I Package, I get the two error messages below, the bottom on after pressing OK on the top error message. Also, further below are the preflight and packaging reports.
            Note: I do have permission for all folders involved and have been copying and deleting files from these folders just fine. And none of the book's indd files were open or selected in the book pallet when I started the Package Book process.
            Any ideas why these errors are happening and what I can do to fix the problems?
            INDESIGN PREFLIGHT REPORT
            Document: c-diff-book BOOK FILE.indb
            Preflight Profile Used: [Basic]
            Document: G:\1. Internet Marketing\27. Publishing\InDesign\Books\C. difficile Treatments
            & Remedies\c-diff-book, Front matter.indd
            & Remedies\c-diff-book, TOC.indd
            & Remedies\c-diff-book, Introduction.indd
            & Remedies\c-diff-book, Chapter 1.indd
            & Remedies\c-diff-book, Chapter 2.indd
            & Remedies\c-diff-book, Chapter 3.indd
            & Remedies\c-diff-book, Chapter 4.indd
            & Remedies\c-diff-book, Chapter 5.indd
            & Remedies\c-diff-book, Chapter 6.indd
            & Remedies\c-diff-book, Chapter 7.indd
            & Remedies\c-diff-book, Chapter 8.indd
            & Remedies\c-diff-book, Chapter 9.indd
            & Remedies\c-diff-book, Chapter 10.indd
            & Remedies\c-diff-book, Chapter 11.indd
            & Remedies\c-diff-book, Chapter 12.indd
            & Remedies\c-diff-book, Chapter 13.indd
            & Remedies\c-diff-book, Chapter 14.indd
            INDESIGN PREFLIGHT REPORT 2 c-diff-book BOOK FILE.indb
            Error Page
            & Remedies\c-diff-book, Chapter 15.indd
            & Remedies\c-diff-book, Chapter 16.indd
            & Remedies\c-diff-book, Chapter 17.indd
            & Remedies\c-diff-book, Chapter 18.indd
            & Remedies\c-diff-book, Chapter 19.indd
            & Remedies\c-diff-book, Chapter 20.indd
            & Remedies\c-diff-book, Chapter 21.indd
            & Remedies\c-diff-book, Chapter 22.indd
            & Remedies\c-diff-book, Chapter 23.indd
            & Remedies\c-diff-book, Chapter 24.indd
            & Remedies\c-diff-book, Chapter 25.indd
            & Remedies\c-diff-book, Appendix A.indd
            & Remedies\c-diff-book, Appendix B.indd
            & Remedies\c-diff-book, Appendix C.indd
            & Remedies\c-diff-book, Appendix D.indd
            & Remedies\c-diff-book, Appendix E.indd
            & Remedies\c-diff-book, End Notes.indd
            Adobe InDesign Package Report
            PUBLICATION NAME: c-diff-book BOOK FILE.indb
            PACKAGE DATE: 12/23/2014 11:09 AM
            Creation Date: 12/15/2014
            Modification Date: 12/23/2014
            SUMMARY
            Fonts: 8 Fonts Used; 0 Missing, 0 Embedded, 0 Incomplete, 0 Protected
            Links and Images: 2 Links Found; 0 Modified, 0 Missing, 0 Inaccessible
            Images: 0 Embedded, 2 use RGB color space
            Colors and Inks: 4 Process Inks; 0 Spot Inks
            CMS is ON
            External Plug-ins 0
            Non Opaque Objects :On 34 Document(s)
            Pagination Options : Continue on next Odd Page
            Number of Documents :34
            FONTS
            - Name: MinionPro-Bold; Type: OpenType Type 1, Status: OK
            Filename: C:\Windows\Fonts\MinionPro-Bold.otf
            Full Name: Minion Pro Bold
            First Used in Document: c-diff-book, Front matter.indd
            Protected: No
            - Name: MinionPro-It; Type: OpenType Type 1, Status: OK
            Filename: C:\Windows\Fonts\MinionPro-It.otf
            Full Name: Minion Pro Italic
            Protected: No
            - Name: MinionPro-Regular; Type: OpenType Type 1, Status: OK
            Filename: C:\Windows\Fonts\MinionPro-Regular.otf
            Protected: No
            - Name: MinionPro-Semibold; Type: OpenType Type 1, Status: OK
            Filename: C:\Windows\Fonts\MinionPro-Semibold.otf
            Full Name: Minion Pro Semibold
            First Used in Document: c-diff-book, TOC.indd
            Protected: No
            - Name: MyriadPro-Bold; Type: OpenType Type 1, Status: OK
            Filename: C:\Windows\Fonts\MyriadPro-Bold.otf
            Full Name: Myriad Pro Bold
            Protected: No
            - Name: MyriadPro-It; Type: OpenType Type 1, Status: OK
            Filename: C:\Windows\Fonts\MyriadPro-It.otf
            Full Name: Myriad Pro Italic
            Protected: No
            - Name: MyriadPro-Regular; Type: OpenType Type 1, Status: OK
            Filename: C:\Windows\Fonts\MyriadPro-Regular.otf
            Protected: No
            - Name: MyriadPro-Semibold; Type: OpenType Type 1, Status: OK
            Filename: C:\Windows\Fonts\MyriadPro-Semibold.otf
            Full Name: Myriad Pro Semibold
            Protected: No
            LINKS AND IMAGES
            - Name: iStock_000004168167XSmall - silverlining56.jpg; Type: JPEG RGB; Status: Linked
            Filename: iStock_000004168167XSmall - silverlining56.jpg
            Link Updated: Monday, Dec 08, 2014 11:57 AM
            File Last Modified:
            Actual ppi: 72x72   Effective ppi: 125x125
            Layer Overrides: N/A
            Complete Name: G:\1. Internet Marketing\Stock Photos\iStock Photo Images\iStock_000004168167XSmall - silverlining56.jpg
            Link Profile:   Embedded
            - Name: iStock_000005790807XSmall © Henrik5000.jpg; Type: JPEG RGB; Status: Linked
            Filename: iStock_000005790807XSmall © Henrik5000.jpg
            Link Updated: Friday, Dec 05, 2014 9:37 AM
            File Last Modified:
            Actual ppi: 72x72   Effective ppi: 145x145
            Complete Name: G:\1. Internet Marketing\Stock Photos\iStock Photo Images\iStock_000005790807XSmall © Henrik5000.jpg
            COLORS AND INKS
            - Name and Type: Process Cyan; Angle: 0.000; Lines/Inch: 0.000
            - Name and Type: Process Magenta; Angle: 0.000; Lines/Inch: 0.000
            - Name and Type: Process Yellow; Angle: 0.000; Lines/Inch: 0.000
            - Name and Type: Process Black; Angle: 0.000; Lines/Inch: 0.000
            PRINT SETTINGS
            PPD: N/A, (EPSON0C88FD (WF-3540 Series))
            Printing To: Printer
            Number of Copies: 1
            Reader Spreads: No
            Even/Odd Pages: Both
            Pages: All
            Proof: No
            Tiling: None
            Scale: 100%, 100%
            Page Position: Upper Left
            Print Layers: Visible & Printable Layers
            Printer's Marks: None
            Bleed: 0p0, 0p0, 0p0, 0p0
            Color: Composite RGB
            Trapping Mode: None
            Send Image Data: Optimized Subsampling
            OPI/DCS Image Replacement: No
            Page Size: Letter
            Paper Dimensions: 51p0 x 66p0
            Orientation: Portrait
            Negative: No
            Flip Mode: Off
            • 5. Re: How to create a completely separte duplicate of a book and all of its associated indd files.
              I suspect the problem is the use of . in the folder names.
              • 6. Re: How to create a completely separte duplicate of a book and all of its associated indd files.
                Also a & is a problem on some servers, make shorter names in the path. I am not a Windows user, but there is sometimes a limit in the letters in the path.
