0 Replies Latest reply on Dec 23, 2014 3:47 AM by Stamm
    Object is invalid on object.parentStory.characters.item(i+1).fontStyle;
    Stamm Level 1
      Hey guys,
      I have an array where I save the contents of a textFrame, where "object" is the textFrame.
      textContent = object.contents;
      Then I have a for loop to loop  through all items. With
      if(i > 0)
      object.parentStory.characters.item(i-1).fontStyle.toString().toLowerCase();
      object.parentStory.characters.item(i).fontStyle.toString().toLowerCase();
      if(i < textContent.length-1)
      object.parentStory.characters.item(i+1).fontStyle.toString().toLowerCase();
      I am getting the previous, current and next styles. It's for xml purposes and with this I can add a "<b>" , "<i>", etc. tag for my objects. The problem occuring now is that on some point, object.parentStory.characters.item(i+1).fontStyle; returns "object is invalid".
      That being said, item(i+1) is valid. If I alert this, it says "object [character]". I tried to use if(object.parentStory.characters.item(i+1).hasOwnProperty('fontStyle')), but it didn't work. I don't know why it throws this error and I couldn't find any solution to this problem on the web.
      Has anybody experienced this?  Here is the complete code(without italic and bold italic):
      function spliceSlice(str, index, count, add) {
        return str.slice(0, index) + (add || "") + str.slice(index + count);
      function checkFontStyle(object){
          for(i = 0; i < textContent.length; i++){
              style = object.parentStory.characters.item(i).fontStyle.toString().toLowerCase();
              if(i > 0)
                  prevStyle = object.parentStory.characters.item(i-1).fontStyle.toString().toLowerCase();
              if(i < textContent.length - 1){
                  nextStyle = object.parentStory.characters.item(i+1).fontStyle.toString().toLowerCase();
              if(style.indexOf('bold') > -1){
                  if(prevStyle.indexOf('bold') > -1){
                  else if(nextStyle.indexOf('bold') < -1){
                      textContent.spliceSlice(textContent, i, 0, '[/b]');
                  else{
                      textContent = spliceSlice(textContent, i, 0, '[b]');
          return textContent;
      The desired behaviour would be, that if the current object has no "fontStyle" it should just skip this iteration.
