1 Reply Latest reply on Dec 23, 2014 12:58 PM by Peter Spier
    Genrating a main Table of Contents based off the headers of sub Tables of contents
    WHD2000
      I have a lengthy document i'm working on, with many sections. Each section has a divider with its own table of contents generated for that section, 15 sections in total. Each section's TOC is set up like any other TOC, and the headline is generated using the same paragraph style for each section. I then have a main TOC that targets the one paragraph style I defined to for each section's headline. When I generate that TOC though, the headline comes out pink, and contents do not appear.
      I have a feeling this is some kind of bug where you cant target paragraph styles that were used to generate other TOCs but I want to make sure that im not doing anything wrong.
      Thanks!
