0 Replies Latest reply on May 7, 2006 11:17 AM by benwh8
    HTML embedded media
      Hi, i'm currently developing a Flash XML database and am having problems with embedding movieclips within the dynamic text box that displays the HTML results. I am using an external SWF to control the search function, which is loaded into the main SWF.
      I have embedded the movieclips into the HTML text using <img src ='movieclip_name'>, and this seems to work fine in the external SWF. however, when i load the external SWF into the main SWF, using attachMovie and perform a search function, the external SWF itself strangely resizes. I have checked, and the <img src> tag is the line of code causing a problem, and i'm at a total loss as to why!
      Any help on why this might be happening, and/or a remedy to the problem would be very much appreciated,
