13 Replies Latest reply on Dec 25, 2014 2:56 PM by Teetan VK
    Script for get titles of subfolders
    Teetan VK Level 1
      Hi everyone,
      If a folder full of subfolders, may be thousands.
      Is that possible to make a script for get those titles of the subfolders.
      Teetan
        • 1. Re: Script for get titles of subfolders
          Ronald63 Level 4
          Try this snippet ...
          var myFolder=Folder("~/Documents/");
          var subFolderList = new Array;
          getSubFolders(myFolder);
          function getSubFolders(theFolder) {
               var elementList = theFolder.getFiles();
               for (var i= 0; i< elementList.length;i++) {
                    var aElement = elementList[i];
                    if (aElement instanceof Folder){
                         subFolderList.push(aElement.displayName);
                          //getSubFolders(aFile); // recursive function
               $.writeln (subFolderList)
          I hope this will help you
          Regards
          Ronald
          • 2. Re: Script for get titles of subfolders
            Teetan VK Level 1
            Thanks Ronald
            I change the script into like this
            var myFolder=Folder("~Desktop\Teetan");
            then run it
            but it seems nothing response to me
            how can make it happen?
            Teetan
            • 3. Re: Script for get titles of subfolders
              Ronald63 Level 4
              subFolder's titles are in the array subFolderList.
              If you run the script in ExtendScript Toolkitn, you can see all title's subFolder in the Javascript Console.
              That you want to do exactly with subFolder's titles ?
              • 4. Re: Script for get titles of subfolders
                Teetan VK Level 1
                Hi Ronald
                All I got are these:
                Result: undefined
                <![CDATA[
                ]]>Result: undefined
                <![CDATA[
                is that possible to writein in the text file like xxxx.txt?
                Teetan
                • 5. Re: Re: Script for get titles of subfolders
                  Ronald63 Level 4
                  var myFolder=Folder("~/Documents");
                  var logFile = new File(myFolder + "/"+"logFile.txt");
                                 writeLogFile(aElement.displayName)
                  function writeLogFile(theString) {
                      logFile.open( "a" );
                      logFile.writeln(theString);
                      logFile.close();
                  You are on MacOS or Windows ?
                  • 7. Re: Re: Script for get titles of subfolders
                    pixxxel schubser Level 5
                    Teetan VK schrieb:
                    … All I got are these:
                    Result: undefined
                    <![CDATA[
                    <![CDATA[
                    Hi.Teetan VK
                    Your syntax is wrong.
                    replace these lines:
                    with this:
                    var myFolder=Folder("~/Desktop/Teetan/");
                    var subFolderList = new Array ();
                    Teetan VK schrieb:
                    … is that possible to writein in the text file like xxxx.txt?
                    var myFile = File("~/Desktop/Some.txt");
                    myFile.open('w');
                    myFile.write(subFolderList);
                    myFile.close();
                    Have fun
                    • 8. Re: Script for get titles of subfolders
                      Teetan VK Level 1
                      Thanks all gus
                      but can you gus me fix this line error?
                      Teetan
                      • 9. Re: Script for get titles of subfolders
                        Teetan VK Level 1
                        Hi Ronald
                        Is that possible to change this script for get the tltles of the subfolder hierarchy?
                        Teetan
                        • 10. Re: Script for get titles of subfolders
                          Ronald63 Level 4
                          What do you mean by "get the tltles of the subfolder hierarchy"?
                          • 11. Re: Script for get titles of subfolders
                            Teetan VK Level 1
                            Hi Ronald
                            in side the subfolders have their own subfolder
                            thank you for your respons
                            thank so much
                            Teetan
                            • 12. Re: Re: Script for get titles of subfolders
                              Ronald63 Level 4
                              Try this ...
                              var myFolderPath =myFolder.path;
                              var refCountSep = myFolderPath.split("/").length
                                             countSep = aElement.path.split("/").length
                                             tabCount = countSep - refCountSep
                                             myIndent = Array(tabCount).join('\t')
                                             writeLogFile(myIndent + aElement.displayName)
                                             getSubFolders(aElement); // recursive function
                                  //$.writeln (subFolderList)
                                  logFile.close();
                              • 13. Re: Script for get titles of subfolders
                                Teetan VK Level 1
                                Thank you Ronald
                                Thank so much
                                Teetan
