3 Replies Latest reply on Mar 7, 2007 9:41 AM by Newsgroup_User
    Issue with CFUpload and CFCs
    Jason_the_Mullerite
      I have the following two methods in the same cfc:
      This function is used to generate the upload form...
      <cffunction name="uploadPictureView" hint="Form to upload bio picture" access="remote">
      <form name="uploadForm" action="cmsBios.cfc?method=uploadPicture" enctype="multipart/form-data">
      Please Select Bio Photo<br>
      <input type="file" name="UploadFile">
      <input type="submit" value=" Upload File ">
      </form>
      </cffunction>
      This function is used to upload the file to the directory and then close the popup and refresh the base page...
      <cffunction name="uploadPicture" hint="Script to upload bio picture" description="Upload Picture" access="remote" output="false">
      <cfset uploadPath = #APPLICATION.localPath# & "\images\bioPicts\">
      <cfif not DirectoryExists(uploadPath)>
      <cfdirectory action="create" directory="#uploadPath#">
      </cfif>
      <cffile action="upload" fileField="UploadFile" destination="#uploadPath#" nameConflict="MakeUnique">
      <script>
      refreshParent();
      </script>
      </cffunction>
      The file does not get uploaded and instead it loads a description of the cfc and all the methods. No error so I can't tell what is wrong. How do I get this to work? Anyone have any ideas?
      Jason
        • 1. Re: Issue with CFUpload and CFCs
          Level 7
          If you are getting the description of the CFC and it's methods, then CF
          is running the Component Explorer, which is the default behavior if one
          access a CFC directly with an URL.
          When I use a CFC as an action for a post form, I put the method in as a
          hidden field rather then an URL parameter. You could give that a try.
          <input type="hidden" name="method" value="uploadPicture">
          • 2. Re: Issue with CFUpload and CFCs
            Jason_the_Mullerite Level 1
            I removed the ?method=uploadPicture from the action attribute and added the hidden variable but now I am getting this message:
            Invalid content type: "".
            CFFILE action="upload" requires forms to use enctype="multipart/form-data".
            The error occurred in D:\www\CMS\CFCs\cmsBios.cfc: line 511
            509 : <cfdirectory action="create" directory="#uploadPath#">
            510 : </cfif>
            511 : <cffile action="upload" fileField="UploadFile" destination="#uploadPath#" nameConflict="MakeUnique">
            512 : <script>
            513 : refreshParent();
            I have the enctype set to multipart/form-data. Also does the cfc know which method to use automatically from the hidden variable or do I need to specify that some how?
            • 3. Re: Issue with CFUpload and CFCs
              Level 7
              You have to specify the method you want to use as the value of the
              hidden field.
              <input type="hidden" name="method" value="methodName">
              Look at the source of the form being generated by your code. Is it
              properly formated? Is there a chance that somehow the output is mangled
              so that you are not getting a correct form?
