0 Replies Latest reply on Dec 25, 2014 3:03 AM by Kirill_F
    Premiere Pro CC crashes because of volume keyframes in the nested sequence
    Kirill_F
      Hello. Looks like there is a bug in the Adobe Premiere Pro CC 8.2.0(65) Build.
      The problem is that Premiere crashes each time I have volume keyframes on the clips inside a nested sequence.
      So I have one Master sequence and I put a Nested sequence in it. In the Nested sequence I have few subclips with volume keyframes on them. Premiere crashes each time as I roll the playback head over the Master's timeline with the Nested sequence in it. Everything works fine if i delete all volume keyframes on the subclips inside the Nested sequence.
      I also noticed that there is no issues when I roll the playback head over these subclips(with or without keyframes) while I am in the Nested sequece. It only occurs on the Master's timeline and in any place.
      Master Sequence is 1280x720. The Nested is 4k. Subclips mediainfo:
      Format     : XAVC
      Codec ID     : XAVC
      File size     : 1.94 GiB
      Duration     : 5mn 35s
      Overall bit rate mode     : Variable
      Overall bit rate                         : 49.7 Mbps
      Video
      Format     : AVC
      Format/Info     : Advanced Video Codec
      Format profile     : High@L5.1
      Format settings, CABAC     : Yes
      Format settings, ReFrames     : 2 frames
      Codec ID     : avc1
      Codec ID/Info     : Advanced Video Coding
      Duration     : 5mn 35s
      Bit rate mode     : Variable
      Bit rate     : 48.0 Mbps
      Maximum bit rate     : 60.0 Mbps
      Width     : 3 840 pixels
      Height     : 2 160 pixels
      Display aspect ratio     : 16:9
      Frame rate mode     : Constant
      Frame rate     : 25.000 fps
      Color space     : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Bits/(Pixel*Frame)                       : 0.231
      Stream size                              : 1.88 GiB (96%)
      Color primaries                          : BT.709
      Transfer characteristics                 : IEC 61966-2-4
      Matrix coefficients                      : BT.709
      Audio
      Format                                   : PCM
      Format settings, Endianness              : Big
      Format settings, Sign                    : Signed
      Codec ID                                 : twos
      Duration                                 : 5mn 35s
      Bit rate mode                            : Constant
      Bit rate                                 : 1 536 Kbps
      Channel(s)                               : 2 channels
      Sampling rate                            : 48.0 KHz
      Bit depth                                : 16 bits
      Delay relative to video                  : 40ms
      Stream size                              : 61.4 MiB (3%)
