3 Replies Latest reply on Dec 25, 2014 10:00 AM by pixxxel schubser
    Make a script for build table
    Teetan VK Level 1
      Hi everyone
      How to make a script for build table:
      col width 25mm
      align decimal
      align on close paren
      Teetan
        • 1. Re: Make a script for build table
          pixxxel schubser MVP & Adobe Community Professional
          Hi Teetan VK,
          Merry Chrismas.
          I'm not really an InDesign scripter.
          But you can try the following code:
          // TableCreate_simple.jsx
          // regards pixxxelschubser
          var aDoc = app.activeDocument;
          // your width of every column
          var w = Number(prompt("width of columns", 25));
          var NrOfColumns = 3;
          var aTextFrame = aDoc.textFrames.add({visibleBounds:[0, 0, 30, NrOfColumns*w + 1]});
          var aTable = aTextFrame.insertionPoints[0].tables.add({columnCount:NrOfColumns,bodyRowCount:1});
          for (i=0; i<aTable.columns.length; i++) {
          aTable.columns[i].width = w;
          // Paragraph sytyle with decimal aligning should already exists in your document
          for (j = 0; j < aTable.cells.length; j++) {
              aTable.cells[j].texts[0].appliedParagraphStyle = aDoc.paragraphStyles.item("AlignDecimal");
          Be sure, that a paragraph style (named with "AlignDecimal") exists in your Document.
          But what is:
          Teetan VK schrieb:
          … align on close paren …
          • 2. Re: Make a script for build table
            Teetan VK Level 1
            Hi Pixxel
            thank you for your response
            the align with decimal and align on close paren like this:
            thank you so much
            Teetan
            • 3. Re: Make a script for build table
              Create a paragraph style with decimal and align on close paren (named with AlignDecimal) and run the script.
              Have fun
