2 Replies Latest reply on Dec 25, 2014 3:27 AM by Ann Bens
    Edit multiple objects?
    babafafasdf
      I'm using Premiere Pro CS5.5, is it possible to edit multiple objects (mostly titles or colour matte) at once? For example if I have say 100 subtitles and I want to move all of them down a few pixels, how do I do that besides manually moving them one by one? Or if I enlarge all the colour mattes I have by x%?
        • 1. Re: Edit multiple objects?
          Yes you can:
          Move one title down. Copy.
          Select all the rest of the titles and paste attributes.
          The same goes for the color matte: change scale, copy, paste attributes.
          • 2. Re: Edit multiple objects?
            Richard M Knight Adobe Community Professional & MVP
            If the title is just size and motion changes, use the fixed motion effects for one title and then copy-paste attributes for the others. This works if you are not scaling up the title too much, if it is a large zoom in you will loose resolution. This copy and paste attributes should work with all effects. If you are changing for a second time remember to remove effects form the clips first or you will get them duplicated.
            As is often the case, Ann got her reply in first
            • 3. Re: Edit multiple objects?
              Paste attributes does not work on copied Motion properties from the Effect Controls, you need to use Paste from the dropdown menu Edit or just Ctrl+V.
