7 Replies Latest reply on Jan 7, 2015 10:30 AM by thebass
    Green Line on right side of exported video Premiere Pro
    MsAmos12
      Hi, when I export my footage I am seeing a slight green line on the right edge of the frame, no matter the media player and is visible as well on youtube and vimeo uploads.  I am making sure it is exported at 1280x720 as that is the aspect ratio I am recording at on my GH2. The GH2 are avchd files or .mts files natively, so when I import them I convert them using Adobe Media Encoder set to ProRes 720 60fps.  This green line does not occur on every clip when I export, just the majority of them.  I am also using Premiere Pro CC 2014 with the latest version updated.Screen Shot 2014-12-27 at 12.10.12 AM.png Please help!
        • 1. Re: Green Line on right side of exported video Premiere Pro
          Why Prores? Premiere edits the mts files native.
          Import them as mts, edit and export them and see if the green line is still there.
          • 2. Re: Green Line on right side of exported video Premiere Pro
            MsAmos12 Level 1
            I do it because a lot of people ask me for the clips to send them, and sending mts files isnt the easiest way, and because I should be able to convert to prores and not experience this.
            • 3. Re: Green Line on right side of exported video Premiere Pro
              DMH79 Level 2
              Can you send a screenshot of your video export settings? I vaguely remember this happening a couple years back but can't recall how it was resolved at the moment.
              • 4. Re: Green Line on right side of exported video Premiere Pro
                MsAmos12 Level 1
                Screen Shot 2015-01-01 at 10.22.25 PM.pngTheses are the general settings I usually export my videos with if they are going online, usually the bit rate is a little higher.
                • 5. Re: Green Line on right side of exported video Premiere Pro
                  DMH79 Level 2
                  Hmmm. Is your "max bit depth" checked? I vaguely remember having an issue once upon a time and I can't remember if that was related or not. It seemed like it shouldn't be related but I'm recalling that once I unchecked that setting, my issues went away. What's odd is that it doesn't happen on all of them. Not 100% sure, sorry. Maybe someone else can help or Google.
                  • 6. Re: Green Line on right side of exported video Premiere Pro
                    MsAmos12 Level 1
                    I tried it and it did seem to work for most of the clips, however i did notice a slight blue line in a couple of them, not all the way down like the green one was but more in the middle right of the frame, like a slight 1-2 pixel band in and out of the frame.
                    • 7. Re: Green Line on right side of exported video Premiere Pro
                      thebass Level 1
                      Yes looks very similar to what I am getting with the cube transition.
                      It is probably something to do with the MPE and Direct X or Acc Graphics used to process the clips during the transition, only a guess for a non programmer like myself lol.
                      Yes, bet it is one of those bugs that has slipped through, when viewing as a screen shot it is hard to see it at stop so possible more so even in motion, but yes it is there and as I posted in my other thread, I am seeing it also, I am not green screening neither.
                      As say, for TV's then probably 99% of the time it will be hidden in the overscan area but for some and for Web Based viewing, I as you, would rather it not be there.
                      As say it is kinda like the feature in EDIUS Called enable transition handling in over scan, where the default for a new project is set at 3%.
                      Anyway, I have kinda solved my problem with the cube spin transition by subscribing to Red Giant Universe at $10 a month, they have a nice set of transitions that work well in premiere Pro CC, I am currently on version 8.0.1. Though I do plan on upgrading as and when to the newest one 8.0.2. Though doubt that the original issue has been fixed, but for now, I am using Red Giant.
                      FInally, I notice that if I click on the settings box in Red Giant Transitions, then it crashes Premiere Pro with this message, so I avoid doing that, but still work mentioning, probably should put this into a fresh post of submit bug report, I will also contact Red Giant to make them aware of it also.
                      Premiere Pro has encountered an error
                      [..\..\Scr\AESupport.cpp-86]
                      Problem signature:
                        Problem Event Name:    APPCRASH
                        Application Name:    Adobe Premiere Pro.exe
                        Application Version:    8.1.0.81
                        Application Timestamp:    5426694c
                        Fault Module Name:    MSVCR110.dll
                        Fault Module Version:    11.0.51106.1
                        Fault Module Timestamp:    5098826e
                        Exception Code:    40000015
                        Exception Offset:    00000000000740da
                        OS Version:    6.1.7601.2.1.0.256.1
                        Locale ID:    2057
                        Additional Information 1:    9bca
                        Additional Information 2:    9bca88f85e8c36e7d86179cefb863392
                        Additional Information 3:    e5c7
                        Additional Information 4:    e5c75cdca8ef833efce9f20f61f3f27a
                      Read our privacy statement online:
                        http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
                      If the online privacy statement is not available, please read our privacy statement offline:
                        C:\Windows\system32\en-US\erofflps.txt
