6 Replies Latest reply on Dec 29, 2014 8:09 AM by MaxCO2012
    Excel VBA to JS: How does one pass rectangle coordinates to a JS function.
    MaxCO2012
      I have an Excel VBA sub that calls a folder level JS function and I'm trying to pass a set of rectangle coordinates.
      This is the VBA code:
      Sub BarcodeDoc_PDF417(pdfFileName As String)
          Dim AVDoc As Acrobat.CAcroAVDoc
          Dim PDDoc As Acrobat.CAcroPDDoc
          Dim myApp As Acrobat.CAcroApp
          Dim jso As Object
          Dim bcTmpFile As String
              bcTmpFile = "C:\Temp\bcTmpFile.pdf"
              Set myApp = CreateObject("AcroExch.App")
              Set AVDoc = CreateObject("AcroExch.AVDoc")
                  If AVDoc.Open(pdfFileName, "") Then
                      Set PDDoc = AVDoc.GetPDDoc
                      Set jso = PDDoc.GetJSObject
                          jso.myAdd417Barcode 'This is where the coordinates get passed.
                          PDFSave PDDoc, bcTmpFile
                      myApp.CloseAllDocs
                      myApp.Exit
                      Set AVDoc = Nothing
                      Set jso = Nothing
                      Set PDDoc = Nothing
                      Set myApp = Nothing
                  Else
                      MsgBox "Sub: BarcodeDoc_PDF417. Document not found:" & vbCrLf & vbCrLf & pdfFileName
                  End If
      End Sub
      This is the folder level JS script:
      function myAdd417Barcode(myCoords)
      //The line below is just for testing. Will come out once I can pass the coords in from my VBA sub.
      //var myCoords = [324, 756, 540, 720];
      InsertPDF417Barcode(this, myCoords);
      I've tried to pass the coords as a string and an array, both to no avail. Any ideas?
      Thanks.
