0 Replies Latest reply on Dec 27, 2014 11:36 PM by gageller1
    Cannot burn DVD in Premier Elements 13. Receiving multiple errors
    gageller1 Level 1
      Hi All,
      I have created a project in Premier Elements 13. I have imported two jpegs and an mpg file into the project. The total length is 46 minutes. When I try to burn the project to a DVD, I get the following error   "The data rate of this file is too high for DVD". I have tried to do it several times unchecking "Fit Contents to available space check box and lower the bitrate from 8.00 Mbps on down. I received the same error until I get to the bitrate of around 6. Then I get the error "PluginCoder error:no plugin DLLs".
      I'm not quite sure where to go from here
      I running on a Dell Inspiron
      Windows 8.1 Pro 64 bit
      8 GB Memory
      Intel i7-3630QM CPU @ 2.40 GHz
      Thanks for any help. It is greatly appreciated.
      Greg
