11 Replies Latest reply on Dec 29, 2014 2:40 PM by gkaiseril
    How do I use Javascript to populate a text field based on a selection from a drop down box?
    timothy.flohrschutz
      Greetings,
      I have virtually no experience with JavaScript and I am trying to figure out how to add some basic automation features to an Adobe form.  I have a drop down box called "Hospital_Name" that will contain approximately 7 possible selections.  When the user makes a selection, I would like to have the text field (called "Hospital_Address") below the drop down box populate with the corresponding address for the selection.  I have the "Hospital_Address" text field configured for multiple lines and would like the address to have a line break between the street address and the city/state/zip.
      For example, if the user selected "Hospital 1", the text field would display:
      123 Main St
      Anytown, CA 12345
      Any help or examples you can provide would be greatly appreciated.
        • 2. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
          timothy.flohrschutz Level 1
          Thanks for the assist.  I've followed the tutorial and generated the following code which is producing a syntax error which states that there is an invalid property id (Line 3 begins with "function."  Any idea what I'm missing?
          // Place all pre-population data into a single data structure
          var Location = { --Hospital--:{ line1: " ", line2: " " }, { Bellevue Medical Center:{ line1: "2500 BMC Drive", line2: "Bellevue, NE 68123" }, { CHI Bergan Mercy:{ line1: "7500 Mercy Road", line2: "Omaha, NE 68124" }, { CHI Immanuel:{ line1: "6901 N. 72nd Street", line2: "Omaha, NE 68122" }, { CHI Lakeside:{ line1: "16901 Lakeside Hills Court", line2: "Omaha, NE 68130" }, { CHI Midlands:{ line1: "11111 S. 84th Street", line2: "Papillion, NE 68046" }, { Creighton University Medical Center:{ line1: "601 N. 30th Street", line2: "Omaha, NE 68131" }, { Nebraska Medical Center:{ line1: "4400 Emile Drive", line2: "Omaha, NE 68105" }};
          function SetFieldValues (cHospitalName)
              this.getField("AddLine1").value = Location[cHospitalName].line1;
              this.getField("AddLine2").value = Location[cHospitalName].line2;
          • 3. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
            You need to place double-quotes around all the strings like "Hospital"
            and "Bellevue Medical Center"...
            On Mon, Dec 29, 2014 at 1:25 AM, timothy.flohrschutz <
            • 4. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
              I made the suggested changes and I'm still receiving the same error "Syntax Error: invalid property id" "2: at line 3" for the second section of code.
              Here is the code I have in the Custom Keystroke Script for the drop down called "Hospital_Name":
              if( event.willCommit ) {
                  if(event.value == " ") this.resetForm(["AddLine1","AddLine2"]); else SetFieldValues(event.value);
              Here is this most recent code I tried in the Document JavaScript field:
              var Location = { "--Hospital--":{ line1: " ", line2: " " }, { "Bellevue Medical Center":{ line1: "2500 BMC Drive", line2: "Bellevue, NE 68123" }, { "CHI Bergan Mercy":{ line1: "7500 Mercy Road", line2: "Omaha, NE 68124" }, { "CHI Immanuel":{ line1: "6901 N. 72nd Street", line2: "Omaha, NE 68122" }, { "CHI Lakeside":{ line1: "16901 Lakeside Hills Court", line2: "Omaha, NE 68130" }, { "CHI Midlands”:{ line1: "11111 S. 84th Street", line2: "Papillion, NE 68046" }, { "Creighton University Medical Center":{ line1: "601 N. 30th Street", line2: "Omaha, NE 68131" }, { "Nebraska Medical Center":{ line1: "4400 Emile Drive", line2: "Omaha, NE 68105" }};
              function SetFieldValues(Hospital_Name)
                  this.getField("AddLine1").value = Location[Hospital_Name].line1;
                  this.getField("AddLine2").value = Location[Hospital_Name].line2;
              • 5. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
                Are you sure you have all the field names correctly spelled and capitalized?
                Are there any errors in the JavaScript console?
                All the form field in a PDF are processed by using JavaScript and any error in any script will stop JavaScript processing.
                It might help to have a link to the problem form.
                Make sure your brackets are properly placed and matched.
                var Location = {
                "Bellevue Medical Center":{ line1: "2500 BMC Drive", line2: "Bellevue, NE 68123" },  "CHI Bergan Mercy":{ line1: "7500 Mercy Road", line2: "Omaha, NE 68124" },
                "CHI Lakeside":{ line1: "16901 Lakeside Hills Court", line2: "Omaha, NE 68130" },  "CHI Midlands”:{ line1: "11111 S. 84th Street", line2: "Papillion, NE 68046" },
                function SetFieldValues(Hospital_Name) {
                This is not a beginners task but requires a fair amount of knowledge about the structure of objects, defining strings, and structure of arrays.
                • 6. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
                  I located a misplaced comma within the first variable.  I corrected it and now I'm receiving the following error: "missing } after property list."
                  There are only two text fields (AddLine1 and AddLine2) which are both spelled and capitalized correctly.
                  The only errors that I see in the JavaScript Debugger console is the error that I have listed above.
                  • 7. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
                    You have the element names within the object within brackets.
                    var Location = {
                    "CHI Midlands":{ line1: "11111 S. 84th Street", line2: "Papillion, NE 68046" },
                    // some debugging code to see location names;
                    console.show();console.clear():
                    for(I in Location) {
                    console.println(I);
                    // end debugging code;
                    Do you get any error in the JavaScript console?
                    Just trying the line that defines the "Location", I get the following error:
                    SyntaxError: invalid property id
                    1:Console:Exec
                    undefined
                    var Location = {
                    • 9. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
                      You are missing the document level script that defines the data object and the setItems function.
                      // document level JavaScript; Could be placed in the page open action if you cannot access the document level JavaScripts;
                      var Location = {
                      "--Hospital--": { line1: " ", line2: " " },
                      "Bellevue Medical Center": { line1: "2500 BMC Drive", line2: "Bellevue, NE 68123" },
                      "CHI Bergan Mercy": { line1: "7500 Mercy Road", line2: "Omaha, NE 68124" },
                      "CHI Immanuel": { line1: "6901 N. 72nd Street", line2: "Omaha, NE 68122" },
                      "CHI Lakeside": { line1: "16901 Lakeside Hills Court", line2: "Omaha, NE 68130" },
                      "CHI Midlands": { line1: "11111 S. 84th Street", line2: "Papillion, NE 68046" },
                      "Nebraska Medical Center": { line1: "4400 Emile Drive", line2: "Omaha, NE 68105" }
                      // end document level scripts;
                      // custom keystroke script;
                      // end custom keystroke script;
                      Note the formatting some items in a columnar like line can help one review the code. Also use a text editor for processing the code.
                      • 10. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
                        I don't see what changed in the code, but it seems to work now.  I am extremely appreciative for your help.  Thank you.
                        • 11. Re: How do I use Javascript to populate a text field based on a selection from a drop down box?
                          Your code:
                          The "{" before the hospital name was removed. So 7 instances of "{" were removed.
