5 Replies Latest reply on Dec 30, 2014 9:58 PM by hurix@123
    Image File Name
    hurix@123 Level 1
      Hi
      I Need to get link name in newHeights, can any one help me
      newHeights = {
      linkname: 4.4,
        /*  "O1.tif": 4.4,
          "IMG_1334.jpg": 4.4,
          "IMG_1335.jpg": 1,
      for (i = 0, l = doc.links.length; i < l; i++) {
      var link = doc.links;
      var sourcefile = link[i].filePath;
      alert (sourcefile);
      var linkname = link[i].name;
          if (linkname in newHeights) {
              pageItem = link.parent.parent;
              height = pageItem.visibleBounds[2] - pageItem.visibleBounds[0];
              target = new UnitValue(newHeights[linkname], 'in').as('pt');
              scale = target / height;
              matrix = app.transformationMatrices.add({horizontalScaleFactor: scale, verticalScaleFactor: scale});
              pageItem.transform(CoordinateSpaces.INNER_COORDINATES, AnchorPoint.CENTER_ANCHOR, matrix);
        • 1. Re: Image File Name
          -hans- Level 4
          well, if you want to check if a objcet has got a property just check if it is true ...
          if(newHeights.hasOwnProperty('linkname'))...
          Your attempt: linkname in newHeights is a setup for a loop ...
          There'll be many other possibilities ....
          • 2. Re: Image File Name
            hurix@123 Level 1
            show error on above line: Unable to set BoundingBox
            • 3. Re: Image File Name
              hurix@123 Level 1
              hans
              everything is ok, script run perfectly But problem is
              showing cannot set boundingbox.
              • 4. Re: Image File Name
                steverocket2 Level 1
                I have linked a sample PDF document and
                modified your code some. This works for me:
                var doc = app.activeDocument;
                var newHeights = {
                linkname: 4.4,
                "SampleDocument-5.pdf": 4.4
                    "IMG_1335.jpg": 1,
                alert (sourcefile);
                       var curLink = link[i];
                        pageItem = curLink.parent.parent;
                • 5. Re: Image File Name
                  hurix@123 Level 1
                  Thanks Steve,
                  I have huge images in my document, so i can expect  to get document link name in newHeights.
                  if i give file name "O1.tif" It works.
