1 Reply Latest reply on Mar 29, 2015 6:42 PM by Tariq Dar
    PDF Files
      How do I change a document that is saved as an image to a PDF File ?
        • 1. Re: PDF Files
          Tariq Dar Adobe Employee
          If you still looking for answer to this query. And if you are using Acrobat. Or create pdf service.
          You may import the file using Acrobat and then choose Save As and choose PDF format to save the file. Or if you are using create PDF service you may select file and then convert the file to PDF.
