5 Replies Latest reply on Dec 29, 2014 2:03 PM by Rick Gerard
    Transform Effect jumps around when Collapse Transformation is enabled
    nikolaig Level 1
      I created a reflection on one of my vector based animated layers. Then decided to apply reflection with Transform effect.
      It all held true before I assigned "Collapse Transformation" and my Transform effect is going awry. Basically because there is zoom out with the camera and scale as well.
      Transformation's Anchor points and Distance are note keeping up with the movements and reflection is jumpint all over the place.
      Where should this Transformation effect be applied. On the first level when I created my PreComp1 with all the layers (and then PreComp1 is getting nested within other PreComps) or at the very end at the Final PreComp for render I should apply this effect.
      It seems to jump around in any case...
        • 1. Re: Transform Effect jumps around when Collapse Transformation is enabled
          Don't use the collapse transformations/continuously rasterize switch.
          If you need to have that layer crisper when scaled, precompose it, tick that continuously rasterize box, and scale it up. Use that precomp in your main comp.
          • 2. Re: Transform Effect jumps around when Collapse Transformation is enabled
            nikolaig Level 1
            Ok. so the individual layers which need to be continuosly rasterized should be enabled individually within the comp or the PreComp itself should be used in composition with Collapse Transformations enabled?
            If this comp is nested further on in other comps should all of them be enabled with Collapse Transformation?
            • 3. Re: Transform Effect jumps around when Collapse Transformation is enabled
              All of this really depends on what you're doing. The only reason to enable the continuously rasterize button is if you need AE to continuously rasterize a vector image.
              The only reason you would need that is if you were planning to scale it larger (or move a camera closer to it). This is taken care of by scaling in a precomp. That way any effects that get messed up by the continuously rasterize/collapse transformation switch won't matter.
              I'd suggest reading up in the AE help on the use of this switch in working with vector graphics.
              • 4. Re: Transform Effect jumps around when Collapse Transformation is enabled
                nikolaig Level 1
                I read the help, it states that Collapse Transormation buttons treats the PreComp as seprated layers, which preserved 3D treatiment for casting shadows and does not cut off shapes by PreComp size.
                It seems to work for me that I check continuosly rasterize on each individual illustrator imported layer (inside the PreComp1), so when I enlarge the shapes they stay crisp. Then I keep on checking Collapse transformations on all consequtive PreComps and everything stays sharp.
                My question is at what stage I would better apply Transform effect, which doesn't seem to work. Should it be on the PreComp1 layer with all the Continuoiusly rasterize enabled or on final Render Out PreComp where "Collapse Transformations" is checked off?
                In eather way because of movement of these illustrator layers, Transform position seems to be fixe on screen, but is not relevant to shape movement whithin the PreComp1.
                What previously worked for me was that I applied Transformation on each individual illustrator layer, however I did not enable "Collapse Transformations" in and consequtive PreComps. As soon as this feature is enabled everything goes awry....
                • 5. Re: Transform Effect jumps around when Collapse Transformation is enabled
                  The most common reason things go awry is that users fail to realize that when you collapse transformations on a 3-D layer in a pre-comp that the camera in the main comp is the one that will be used. This really fouls things up if you have a camera in the pre-comp or you are not looking at the active camera view.
