3 Replies Latest reply on Dec 31, 2014 11:05 AM by bw200
    Show/Hide fields based on checkbox
    bw200
      A common question I know, however I am having an issue with the field labels.
      The PDF form was created with FormsCentral and then edited locally with Acrobat XI (version 11.0.10) on Windows 7 Pro.
      The PDF has a checkbox to allow the user to enter a separate shipping address. In the checkbox properties, Actions tab, I have Mouse Up as the trigger and the following JavaScript.
      var nHide = event.target.isBoxChecked(0)?display.visible:display.hidden;
      this.getField("SHIPPING ADDRESS").display = nHide;
      this.getField("CITY_2").display = nHide;
      this.getField("STATE / PROVINCE_2").display = nHide;
      this works well, however the field labels remain visible in the PDF regardless of the visible / hidden state.
      How can I hide the field labels along with the fields themselves when the checkbox remains unchecked?
      bw200
        • 1. Re: Show/Hide fields based on checkbox
          Assuming the labels are just static text you can't hide them directly. What
          you can do, though, is place white fields on top of them and then show
          those fields when you want to hide the text underneath, and hide them when
          you want the text to be visible.
          • 2. Re: Show/Hide fields based on checkbox
            bw200 Level 1
            Many thanks Gilad, yep they are static text, your solution sounds viable.
            • 3. Re: Show/Hide fields based on checkbox
              bw200 Level 1
              For anyone who may benefit - this is what I did.
              In checkbox properties:
              Actions tab
              Select Trigger: Mouse Up
              Select Action: Run a JavaScript
              Here is the JS:
              // Show/hide alternate shipping address text fields
              // Show/hide alternate shipping address text field label overlays
              this.getField("Overlay_1").display = event.target.value == "Off"? display.visible: display.hidden;
              this.getField("Overlay_2").display = event.target.value == "Off"? display.visible: display.hidden;
              this.getField("Overlay_3").display = event.target.value == "Off"? display.visible: display.hidden;
              So the overlay simply refers to three text fields I added to the PDF form, which cover the labels for the three text fields that are hidden/visible for use as an alternate shipping address. The properties of these overlay text fields in the Appearance tab ensure the border color and fill color, (there is no text), match my document's background. Then, under the General tab, provide a name (i.e. Overlay_1, etc.), no tooltip needed, and then check Read Only. This last bit will ensure that when the user selects Highlight Existing Fields (upper right corner in green bar), these three overlay fields don't appear in the document (they just look strange and confusing if they do).
