2 Replies Latest reply on Dec 30, 2014 3:05 PM by Elly48
    Video conversion
    Elly48
      Hi All
      How do i change 4:3 video from old camera I use to 16:9 format so I can post on utube without black bars.
      All previous versions of elements could do it but cant find solution on v13.
      Please help as know it must be easy but pulling hair out over this simple task.
      thanks
      Elly48
        • 1. Re: Video conversion
          A.T. Romano Level 7
          elly48
          What you could do with earlier versions you surely can with Premiere Elements 13 in this regard.
          What previous version of Premiere Elements did you use to achieve what you seek and how did you do it?
          What is the resolution of this 4:3 video - 680 x 480?
          Assuming that to be the case, you could explore the following
          1. Set your Premiere Elements 13 project preset manually to
          NTSC
          DV
          Widescreen
          To do that, open Premiere Elements 13 to its Expert workspace. Go to File Menu/New/Project and Change Settings.
          In Change Settings set the above project preset. (I am assuming that you are in a NTSC setup rather than PAL.)
          OK out of there. You will next encounter the new project dialog where you put a check mark next to "Force Selected
          Project Setting on This Project". OK out of there.
          2. Back in the Expert workspace, go to Edit Menu/Preferences/General and remove the check mark next to "Fit Content
          to Available Space". Next import your 4:3 file into the project, using Add Media/Files and Folders/Project Assets. Drag
          your 4:3 file to the Timeline.
          3. Click on the Edit area monitor to bring up the image's bounding box. Drag on one of the points of the bounding box to
          adjust the image just to fit the space in the monitor until no black borders.
          Does that work for you?
          ATR
          • 2. Re: Video conversion
            Elly48 Level 1
            oh joy...thank you sooooooo much.
            U R a legend!
            Elly48
