4 Replies Latest reply on Jan 5, 2015 7:00 AM by ImFluffeh
    Playback Problems - Stutter, lag, audio dropoff
    ImFluffeh
      Hey guys, sorry for the long spam of what is below, but it is really making me insane, and I want to fix it. Any help would be appreciated. I included all information that would be needed, and am very competent with computers (programming, tech work, etc)
      Issues:
      1) Playback in the preview section is stuttery after a time, and audio cuts out*
      2) Adding video files causes complete UI lockup in Explorer.exe and the Premiere Pro window*
      *Present in all projects
      Temporary remedy:
      1) When playback resolution is 1/2, paused at Full, waiting for the resolution of the paused image to increase allows the video to play back smoothly for a few seconds
      2) None found
      System specs:
      1x 250GB 840 Evo SSD <-- Where Premiere is installed
      1x 3TB WD Green Drive <-- Where clips are stored
      1x 1TB Seagate 64MB Cache 7200RPM drive <-- Unused, but no performance change when used
      Video clips:
      80GB to 160GB, H264, 30FPS, recorded with OBS max bitrate set to 450000
      System specs:
      i5 4440 w/ stock cooling
      16GB RAM - 1600MHz
      B85-Plus motherboard
      GTX 970 Strix Gaming
      Windows 8.1 64bit <- Was installed as 8.1 on computer's assembly
      -----------ADOBE SETTINGS-----------
      Project Settings: Mercury Playback Engine GPU Acceleration
      Video Display Format - Timecode
      Audio Display Format - Audio Samples
      Capture Format - HDV
      MEDIA
      _____________________
      Media Cache Files: save media cache files next to originals when possible - unchecked
      Location is on 1TB drive - %appdata%\Roaming\Adobe\Common
      Media Cache Database:
      Location is on 1TB drive %appdata%\Roaming\Adobe\Common
      Indeterminate Media Timebase - 29.97fps Drop-Frame
      Timecode: Use Media Source
      Frame Count: Start at 0
      Write XMP ID to Files on Import - Unchecked
      Write clip markers to XMP - Checked
      Enabled Clip and XMP Metadata Linking - Checked
      Include Captions on Import - Checked
      Growing Files
      Automatically Refresh Growing Files - Checked
      Refresh Growing Files Every [60] seconds
      MEMORY
      __________________
      Installed RAM: 15.9GB
      RAM reserved for other applications: 4GB
      Optimized Rendering for [Performance]
      PLAYBACK
      ____________
      Preroll [3] seconds
      Postroll [2] seconds
      Step forward/back many [5] seconds
      Enable Mercury Transmit - Checked
      Audio Device [Adobe DV]
      -----------OPEN BROADCASTER SOFTWARE SETTINGS-----------
      Encoding
      ______________
      Video Encoding:
      Encoder [x264]
      Use CBR - Checked
      Enable CBR padding - Checked
      Max bitrate (kb/s) [450000]
      Audio Encoding:
      Codec[AAC]
      Bitrate[320]
      Format[48kHz]
      Channel[stereo]
      Nvidia driver version - 347.09
      Goal:
      Remedy interface lockup when adding files/modifying clips
      Smooth out playback to prevent audio drop-off and video stutter/lag (drops to 0.5fps)
      I can record it if you wish, but it will take a bit of time.
