2 Replies Latest reply on Dec 31, 2014 6:07 AM by winterm
    [JS] Open document without showing window
    winterm Level 5
      Hi there, wise scripters,
      Win7 64-bit, CS6, ID8.0.2
      I need to open indd doc, process some code, close file. Everything works fine.
      However, the 'open' method has a parameter [showingWindow], right?
      To speed things up a bit, I try to turn off displaying document's window by using the 'false' argument while opening the file, like this:
      var file = File.openDialog();
      app.open(file, false);
      ... and can't get it to work. File just won't open then.
      Found a few posts where people say it's working just fine for them.
      What I am missing / doing wrong?
      Thank You!
      P.S. Funny thing is, a couple of years ago, playing with 'save', 'save as', and 'save a copy' options, I had achieved this effect unintentionally, in some quite different way I can't recall now...
        • 1. Re: [JS] Open document without showing window
          Chinnadk Level 4
          These lines are working fine for me.
          Check the target application in ExtendScript it should be 'Adobe Indesign CS6'
          • 2. Re: Re: [JS] Open document without showing window
            winterm Level 5
            Well, I see now, my problem is a bit different...
            This is initial basic working code sample:
            app.open(file);
            app.pdfExportPreferences.pageRange = PageRange.ALL_PAGES;
            app.pdfExportPreferences.viewPDF = false;
            app.activeDocument.exportFile(ExportFormat.pdfType, File("C:/Folder/Test.pdf"), false, "myPDFpreset");
            app.activeDocument.close(SaveOptions.NO);
            alert("Done");
            Now I realized I can't simply add 'false' argument to app.open(file, false) - script throws an error 'No documents are open'.
            And this works as expected (not showing window):
            var myDoc = app.open(file, false);
            myDoc.exportFile(ExportFormat.pdfType, File("C:/Folder/Test.pdf"), false, "myPDFpreset");
            myDoc.close(SaveOptions.NO);
            alert("Done");
            So I would need to modify the main code - that's too bad... I was hoping to use this in a much more complex script, with a lot of lines, doing a big bunch of things...
            However, thank You for your response and have a nice party tonight
