2 Replies Latest reply on Jan 2, 2015 11:30 AM by marleydog64
    javascript problem CS6
    marleydog64
      Hi when I try to load browse in bridge from photoshop CS6 64 bit it says it cant find the javascript plugin, also 2 of my extentions wont load .Namely Kuboto dashboard pro 4 and OnOne perfect suite9. Yet the 32bit version works fine Tried uninstalling and re-installing, updating all to no avail starting to pull my hair out now please help I don't want to be bald !!!.
      Windows 8.1 64 bit
      Thanks Mick
        • 1. Re: javascript problem CS6
          Look at your Photoshop system information you should see listed in the requires plug-in section a plugin name "ScriptingSupport" listed.  I have see users the find this plug-in does not load in the 64bit version and does loade in the 32bit photoshop program.  The proble seems to be related with third party Pligins like NIK plug-in  when removed from  64Bit Photoshop the ScriptingSupport plug-in loads like it should.
          My Photoshop  menu Help>System Info.... Note "ScriptingSupport" is loaded. version 13.0.1 for windows Perpetual version 13.0.6 Mac and 13.1.2 for subscription CS6
          Adobe Photoshop Version: 2014.2.2 20141204.r.310 2014/12/04:23:59:59 CL 994532  x64
          Operating System: Windows 7 64-bit
          Version: 6.1 Service Pack 1
          System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
          Physical processor count: 12
          Logical processor count: 24
          Processor speed: 1995 MHz
          Built-in memory: 40886 MB
          Free memory: 34401 MB
          Memory available to Photoshop: 37136 MB
          Memory used by Photoshop: 70 %
          3D Multitone Printing: Disabled.
          Windows 2x UI: Disabled.
          Highbeam: Enabled.
          Image tile size: 1024K
          Image cache levels: 4
          Font Preview: Huge
          TextComposer: Latin
          Display: 1
          Display Bounds: top=0, left=0, bottom=1080, right=1920
          Display: 2
          Display Bounds: top=0, left=-1360, bottom=768, right=0
          OpenGL Drawing: Enabled.
          OpenGL Allow Old GPUs: Not Detected.
          OpenGL Drawing Mode: Advanced
          OpenGL Allow Normal Mode: True.
          OpenGL Allow Advanced Mode: True.
          AIFCoreInitialized=1
          AIFOGLInitialized=1
          OGLContextCreated=1
          NumGLGPUs=1
          NumCLGPUs=1
          glgpu[0].GLVersion="3.0"
          glgpu[0].GLMemoryMB=2048
          glgpu[0].GLName="Quadro 4000/PCIe/SSE2"
          glgpu[0].GLVendor="NVIDIA Corporation"
          glgpu[0].GLVendorID=4318
          glgpu[0].GLDriverVersion="9.18.13.4084"
          glgpu[0].GLRectTextureSize=16384
          glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
          glgpu[0].GLRendererID=1757
          glgpu[0].HasGLNPOTSupport=1
          glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
          glgpu[0].GLDriverDate="20140912000000.000000-000"
          glgpu[0].CanCompileProgramGLSL=1
          glgpu[0].GLFrameBufferOK=1
          glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.40 NVIDIA via Cg compiler"
          glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
          glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
          glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
          glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
          glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
          glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
          glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
          glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
          glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
          glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
          glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
          glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
          glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
          clgpu[0].CLPlatformVersion="1.1"
          clgpu[0].CLDeviceVersion="1.1 CUDA"
          clgpu[0].CLMemoryMB=2048
          clgpu[0].CLName="Quadro 4000"
          clgpu[0].CLVendor="NVIDIA Corporation"
          clgpu[0].CLVendorID=4318
          clgpu[0].CLDriverVersion="340.84"
          clgpu[0].CUDASupported=1
          clgpu[0].CUDAVersion="6.5.18"
          clgpu[0].CLBandwidth=7.49358e+010
          clgpu[0].CLCompute=184.252
          License Type: Subscription
          Serial number: 96040035116912554961
          Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\
          Temporary file path: C:\Users\JOHNJM~1\AppData\Local\Temp\
          Photoshop scratch has async I/O enabled
          Scratch volume(s):
            F:\, 465.2G, 184.9G free
            C:\, 224.2G, 102.8G free
          Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\Required\Plug-Ins\
          Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2014\Plug-ins\
          Installed components:
             A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
             ACE.dll   ACE 2014/08/12-23:42:09   79.557478   79.557478
             adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
             AdbePM.dll   PatchMatch 2014/09/07-21:07:38   79.558079   79.558079
             AdobeLinguistic.dll   Adobe Linguisitc Library   8.0.0
             AdobeOwl.dll   Adobe Owl   5.2.4
             AdobePDFL.dll   PDFL 2014/08/18-15:13:12   79.512424   79.512424
             AdobePIP.dll   Adobe Product Improvement Program   7.2.1.3399
             AdobeXMP.dll   Adobe XMP Core 2014/08/20-09:53:02   79.156797   79.156797
             AdobeXMPFiles.dll   Adobe XMP Files 2014/08/20-09:53:02   79.156797   79.156797
             AdobeXMPScript.dll   Adobe XMP Script 2014/08/20-09:53:02   79.156797   79.156797
             adobe_caps.dll   Adobe CAPS   8,0,0,13
             AGM.dll   AGM 2014/08/12-23:42:09   79.557478   79.557478
             ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
             amtlib.dll   AMTLib (64 Bit)   8.0.0.122212002 BuildVersion: 8.0; BuildDate: Wed Jul 30 2014 15:59:34)   1.000000
             ARE.dll   ARE 2014/08/12-23:42:09   79.557478   79.557478
             AXE8SharedExpat.dll   AXE8SharedExpat 2013/12/20-21:40:29   79.551013   79.551013
             AXEDOMCore.dll   AXEDOMCore 2013/12/20-21:40:29   79.551013   79.551013
             Bib.dll   BIB 2014/08/12-23:42:09   79.557478   79.557478
             BIBUtils.dll   BIBUtils 2014/08/12-23:42:09   79.557478   79.557478
             boost_date_time.dll   photoshopdva   8.0.0
             boost_signals.dll   photoshopdva   8.0.0
             boost_system.dll   photoshopdva   8.0.0
             boost_threads.dll   photoshopdva   8.0.0
             cg.dll   NVIDIA Cg Runtime   3.0.00007
             cgGL.dll   NVIDIA Cg Runtime   3.0.00007
             CIT.dll   Adobe CIT   2.2.6.32411   2.2.6.32411
             CITThreading.dll   Adobe CITThreading   2.2.6.32411   2.2.6.32411
             CoolType.dll   CoolType 2014/08/12-23:42:09   79.557478   79.557478
             dvaaudiodevice.dll   photoshopdva   8.0.0
             dvacore.dll   photoshopdva   8.0.0
             dvamarshal.dll   photoshopdva   8.0.0
             dvamediatypes.dll   photoshopdva   8.0.0
             dvametadata.dll   photoshopdva   8.0.0
             dvametadataapi.dll   photoshopdva   8.0.0
             dvametadataui.dll   photoshopdva   8.0.0
             dvaplayer.dll   photoshopdva   8.0.0
             dvatransport.dll   photoshopdva   8.0.0
             dvaui.dll   photoshopdva   8.0.0
             dvaunittesting.dll   photoshopdva   8.0.0
             dynamiclink.dll   photoshopdva   8.0.0
             ExtendScript.dll   ExtendScript 2014/01/21-23:58:55   79.551519   79.551519
             icucnv40.dll   International Components for Unicode 2013/02/25-15:59:15    Build gtlib_4.0.19090
             icudt40.dll   International Components for Unicode 2013/02/25-15:59:15    Build gtlib_4.0.19090
             igestep30.dll   IGES Reader   9.3.0.113
             imslib.dll   IMSLib DLL   7.0.0.154
             JP2KLib.dll   JP2KLib 2014/06/28-00:28:27   79.254012   79.254012
             libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
             libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
             libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
             LogSession.dll   LogSession   7.2.1.3399
             mediacoreif.dll   photoshopdva   8.0.0
             MPS.dll   MPS 2014/08/18-23:43:19   79.557676   79.557676
             pdfsettings.dll   Adobe PDFSettings   1.04
             Photoshop.dll   Adobe Photoshop CC 2014   15.2.2
             Plugin.dll   Adobe Photoshop CC 2014   15.2.2
             PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   5.0.0
             PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   5.2.0.54
             PSArt.dll   Adobe Photoshop CC 2014   15.2.2
             PSViews.dll   Adobe Photoshop CC 2014   15.2.2
             SCCore.dll   ScCore 2014/01/21-23:58:55   79.551519   79.551519
             ScriptUIFlex.dll   ScriptUIFlex 2014/01/20-22:42:05   79.550992   79.550992
             svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
             tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 2, 2013, 1114
             tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 2, 2013, 1114
             TfFontMgr.dll   FontMgr   9.3.0.113
             TfKernel.dll   Kernel   9.3.0.113
             TFKGEOM.dll   Kernel Geom   9.3.0.113
             TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
             updaternotifications.dll   Adobe Updater Notifications Library   8.0.0.14 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   8.0.0.14
             VulcanControl.dll   Vulcan Application Control Library   5.0.0.82
             VulcanMessage5.dll   Vulcan Message Library   5.0.0.82
             WRServices.dll   WRServices Fri Mar 07 2014 15:33:10   Build 0.20204   0.20204
             wu3d.dll   U3D Writer   9.3.0.113
          Required plug-ins:
             3D Studio 15.2.2 (2014.2.2 x001 x003)
             Accented Edges 15.2.2
             Adaptive Wide Angle 15.2.2
             Angled Strokes 15.2.2
             Average 15.2.2 (2014.2.2 x001 x003)
             Bas Relief 15.2.2
             BMP 15.2.2
             Camera Raw 8.7.1
             Camera Raw Filter 8.7.1
             Chalk & Charcoal 15.2.2
             Charcoal 15.2.2
             Chrome 15.2.2
             Cineon 15.2.2 (2014.2.2 x001 x003)
             Clouds 15.2.2 (2014.2.2 x001 x003)
             Collada 15.2.2 (2014.2.2 x001 x003)
             Color Halftone 15.2.2
             Colored Pencil 15.2.2
             CompuServe GIF 15.2.2
             Conté Crayon 15.2.2
             Craquelure 15.2.2
             Crop and Straighten Photos 15.2.2 (2014.2.2 x001 x003)
             Crop and Straighten Photos Filter 15.2.2
             Crosshatch 15.2.2
             Crystallize 15.2.2
             Cutout 15.2.2
             Dark Strokes 15.2.2
             De-Interlace 15.2.2
             Dicom 15.2.2
             Difference Clouds 15.2.2 (2014.2.2 x001 x003)
             Diffuse Glow 15.2.2
             Displace 15.2.2
             Dry Brush 15.2.2
             Eazel Acquire 15.2.2 (2014.2.2 x001 x003)
             Embed Watermark 4.0
             Entropy 15.2.2 (2014.2.2 x001 x003)
             Export Color Lookup Tables NO VERSION
             Extrude 15.2.2
             FastCore Routines 15.2.2 (2014.2.2 x001 x003)
             Fibers 15.2.2
             Film Grain 15.2.2
             Filter Gallery 15.2.2
             Flash 3D 15.2.2 (2014.2.2 x001 x003)
             Fresco 15.2.2
             Glass 15.2.2
             Glowing Edges 15.2.2
             Google Earth 4 15.2.2 (2014.2.2 x001 x003)
             Grain 15.2.2
             Graphic Pen 15.2.2
             Halftone Pattern 15.2.2
             HDRMergeUI 15.2.2
             HSB/HSL 15.2.2
             IFF Format 15.2.2
             IGES 15.2.2 (2014.2.2 x001 x003)
             Ink Outlines 15.2.2
             JPEG 2000 15.2.2
             Kurtosis 15.2.2 (2014.2.2 x001 x003)
             Lens Blur 15.2.2
             Lens Correction 15.2.2
             Lens Flare 15.2.2
             Liquify 15.2.2
             Matlab Operation 15.2.2 (2014.2.2 x001 x003)
             Maximum 15.2.2 (2014.2.2 x001 x003)
             Mean 15.2.2 (2014.2.2 x001 x003)
             Measurement Core 15.2.2 (2014.2.2 x001 x003)
             Median 15.2.2 (2014.2.2 x001 x003)
             Mezzotint 15.2.2
             Minimum 15.2.2 (2014.2.2 x001 x003)
             MMXCore Routines 15.2.2 (2014.2.2 x001 x003)
             Mosaic Tiles 15.2.2
             Multiprocessor Support 15.2.2 (2014.2.2 x001 x003)
             Neon Glow 15.2.2
             Note Paper 15.2.2
             NTSC Colors 15.2.2 (2014.2.2 x001 x003)
             Ocean Ripple 15.2.2
             OpenEXR 15.2.2
             Paint Daubs 15.2.2
             Palette Knife 15.2.2
             Patchwork 15.2.2
             Paths to Illustrator 15.2.2
             PCX 15.2.2 (2014.2.2 x001 x003)
             Photocopy 15.2.2
             Photoshop 3D Engine 15.2.2 (2014.2.2 x001 x003)
             Photoshop Touch 14.0
             Picture Package Filter 15.2.2 (2014.2.2 x001 x003)
             Pinch 15.2.2
             Pixar 15.2.2 (2014.2.2 x001 x003)
             Plaster 15.2.2
             Plastic Wrap 15.2.2
             PLY 15.2.2 (2014.2.2 x001 x003)
             PNG 15.2.2
             Pointillize 15.2.2
             Polar Coordinates 15.2.2
             Portable Bit Map 15.2.2 (2014.2.2 x001 x003)
             Poster Edges 15.2.2
             PRC 15.2.2 (2014.2.2 x001 x003)
             Radial Blur 15.2.2
             Radiance 15.2.2 (2014.2.2 x001 x003)
             Range 15.2.2 (2014.2.2 x001 x003)
             Read Watermark 4.0
             Render Color Lookup Grid NO VERSION
             Reticulation 15.2.2
             Ripple 15.2.2
             Rough Pastels 15.2.2
             Save for Web 15.2.2
             ScriptingSupport 15.2.2  <---------------------------------------------------------------------------------------- ---------------
             Shake Reduction 15.2.2
             Shear 15.2.2
             Skewness 15.2.2 (2014.2.2 x001 x003)
             Smart Blur 15.2.2
             Smudge Stick 15.2.2
             Solarize 15.2.2 (2014.2.2 x001 x003)
             Spatter 15.2.2
             Spherize 15.2.2
             Sponge 15.2.2
             Sprayed Strokes 15.2.2
             Stained Glass 15.2.2
             Stamp 15.2.2
             Standard Deviation 15.2.2 (2014.2.2 x001 x003)
             STL 15.2.2 (2014.2.2 x001 x003)
             Sumi-e 15.2.2
             Summation 15.2.2 (2014.2.2 x001 x003)
             Targa 15.2.2
             Texturizer 15.2.2
             Tiles 15.2.2
             Torn Edges 15.2.2
             Twirl 15.2.2
             U3D 15.2.2 (2014.2.2 x001 x003)
             Underpainting 15.2.2
             Vanishing Point 15.2.2
             Variance 15.2.2 (2014.2.2 x001 x003)
             Virtual Reality Modeling Language | VRML 15.2.2 (2014.2.2 x001 x003)
             Water Paper 15.2.2
             Watercolor 15.2.2
             Wave 15.2.2
             Wavefront|OBJ 15.2.2 (2014.2.2 x001 x003)
             WIA Support 15.2.2 (2014.2.2 x001 x003)
             Wind 15.2.2
             Wireless Bitmap 15.2.2 (2014.2.2 x001 x003)
             ZigZag 15.2.2
          Optional and third party plug-ins:
             CUR (Windows Cursor) NO VERSION
             Face Control II 2.00
             Fine Touch 3.25
             GREYCstoration NO VERSION
             ICO (Windows Icon) NO VERSION
             Reduce Noise 7.0.0.0
             ScriptListener 13.0
             StarFilter Pro 3 3.0.5.1
             SuperPNG 2.0
             Variations 14.2.1 (14.2.1 x001)
          Plug-ins that failed to load: NONE
          Flash: NONE
          Installed TWAIN devices: NONE
          • 2. Re: javascript problem CS6
            marleydog64 Level 1
            Many thanks to JJMack for the reply, removed nik software and all is well again, would like to understand why it run for so long with nik software then suddenly stopped ?. anyway thankyou for your help in solving this problem.
            Mick.
