6 Replies Latest reply on Jan 5, 2015 1:38 PM by Rick Gerard
    3d tracker problem
    andrewdraws
      Hi there!  If I use the 3d camera tracker and then select "create camera and text" the text behaves as it should.
      But I'm trying to move a comp around.
      So if I try to parent the comp to the text (after first switching the comp to a 3D layer)… the comp jumps around wildly.
      The same thing happens if I create "a camera and null object" and then attach my comp to the null object.
      any thoughts?
        • 1. Re: 3d tracker problem
          Camer Tracking creates an animated camera that matches the camera position and movement of the camera used to shoot the tracked video. If you set an origin and ground plane and then add a 3D null or other 3D layer at the same spot the new element will be at the comp center. If you do not set an origin and ground plane new layers can end up anywhere. I'm guessing that you are just adding a comp and turning the comp 3D or that your comp contains 3D layers and you didn't set up the origin.
          There is is a way to move a new 3D layer to the current position of a correctly placed layer. Just reveal the parent column hold down the shift key and parent the new layer to the properly positioned one.
          If that doesn't work we need done a lot more about your composition and your workflow.
          • 2. Re: 3d tracker problem
            andrewdraws Level 1
            Thanks for the reply!
            Attached is an image that hopefully explains my problem. I'll reread you answer and see if I can make sense of it (I'm still new to this).
            Thanks again,
            • 3. Re: 3d tracker problem
              dcfreelancelot Level 2
              according to your screengrab, you have nothing parented to the null
              • 4. Re: 3d tracker problem
                Your comp is not at the same position as the null, simple as that. It's also probably not the right size so it needs to be scaled. If there are any 3D layers in your comp you must not have Collapse Transformations turned on. BTW, a screenshot with no properties revealed for the layers you are having problems with isn't very helpful. When you have problems in the future select the layers that you are having problems with and press the U key twice to reveal everything about these layers that is not at the default setting.
                To move your comp to the same position as your 3D null simply make the comp a 3D layer, hold down the Shift key and make the null the parent of the null. Problem solved. Note the second paragraph of my first reply.
                Note the before and after in this simple example.
                Screen Shot 2015-01-04 at 7.29.14 AM.pngScreen Shot 2015-01-04 at 7.29.44 AM.png
                • 5. Re: 3d tracker problem
                  andrewdraws Level 1
                  Thanks Rick! … I'm new at this, and don't totally understand anchor points, etc.
                  I also decided that using AE's 3D Tracker might have been too confusing. So now I'm using the data from Mocha, and it works fine with just a simple shape layer. But when I apply Mocha's Corner Pin data to an animated comp, it shifts wildly.  Any thoughts? Tracking-Data-1.jpgTracking-Data-2.jpg
                  • 6. Re: 3d tracker problem
                    If you're null ended up in the right position when you did the camera tracking then all you have to do is hold down the shift key when you parent your embedded composition to the null and then scale and position the layer.
                    I have no idea what's going on with Mocha because you haven't told us about your technique.
