6 Replies Latest reply on Apr 22, 2015 6:06 AM by migro1982
    CSS rotate with origin
    migro1982 Level 1
      I'm new in Edge. Need to rotate a wheel with the origin information. I set a button on my stage for the click event code I write this.
      var your_angle = 45;
      sym.$("Rad").css({
      '-ms-transform': 'rotate(' + your_angle + 'deg)',
      '-ms-transform-origin': '50% 50%',
      '-webkit-transform': 'rotate(' + your_angle + 'deg)',
      '-webkit-transform-origin': '50% 50%',
      'transform': 'rotate(' + your_angle + 'deg)',
      'transform-origin': '50% 50%',
      But something are wrong. becose my wheel don't rotate in center.
      Anyone here to check my syntax?
        • 1. Re: CSS rotate with origin
          resdesign Adobe Community Professional & MVP
          You need to alternate single quotes and double quotes
          On Sat, Jan 3, 2015 at 6:15 PM, migro1982 <forums_noreply@adobe.com>
          • 2. Re: CSS rotate with origin
            joel_pau Level 5
            resdesign is traveling and cannot test your code.
            I copied and pasted your code here: rotateTemp.zip - Box and it runs. You don't have syntax errors.
            I tested webkit browsers, Firefox and IE 11.
            • 3. Re: CSS rotate with origin
              joel_pau Level 5
              Now, an update: rotateTemp.zip - Box I added a demo file about rotate using Edge timeline.
              You've got a test page here: A Pen by Louis Lazaris
              You can change css properties. For instance:
              .box {
                background: lightblue;
                width: 200px;
                height: 200px;
                margin: 20px auto;
                transition: transform 1s linear;
                transform-origin: 50% 50%;
              • 4. Re: CSS rotate with origin
                migro1982 Level 1
                This code in Chrome work but in IE 11 don't work. Whats my wrong?
                tRotationRad=setInterval(RotationRad, 250);
                   function getRotationDegrees() {
                  var matrix = sym.$("Rad").css("-webkit-transform") ||
                    sym.$("Rad").css("-moz-transform")    ||
                    sym.$("Rad").css("-ms-transform")     ||
                    sym.$("Rad").css("-o-transform")      ||
                    sym.$("Rad").css("transform");
                    if(typeof matrix === 'string' && matrix !== 'none') {
                        var values = matrix.split('(')[1].split(')')[0].split(',');
                        var a = values[0];
                        var b = values[1];
                        var angle = Math.round(Math.atan2(b, a) * (180/Math.PI));
                    } else { var angle = 0; }
                    return angle;
                // Rotaion of the Wheel
                   function RotationRad(){
                   your_angle = getRotationDegrees() + 45;
                   sym.$("Rad").css({
                • 5. Re: CSS rotate with origin
                  seano2o7 Level 3
                  I copied your original code into compositionReady and removed the "var" to allow the variable to be called from another element. I made the your code into a function in the stage called "Circle"
                  your_angle = 45;
                  sym.Circle = function() {
                  sym.$("Circle").css({
                  On the click of the Circle I ran the function,
                  sym.Circle();
                  and the code worked as expected. I added the text in to check to see if the circle changed.
                  I hope this helped.
                  • 6. Re: CSS rotate with origin
                    migro1982 Level 1
                    Please take a look of my sample file. I have the exact same source in edge and I use it in a normal HTML file. The HTML file work in IE 11 but the Edge sample work only in Chrome not in IE 11. https://drive.google.com/file/d/0B29heH7LlO5QTk5LRXl3THpmTzQ/view?usp=sharing
