4 Replies Latest reply on Jan 5, 2015 1:36 PM by Shelley T
    Publishing with incorrect start page name
    Shelley T
      I am using RoboHelp 10 and publishing using FlashHelp Pro.
      I am entering the Output Folder and Start Page name as shown below:
      The project is compiling as follows:
      vizbybis2.htm is being added as the start page and I can not find where to change it.  vizbybis2 is the orginal name of the project.
      Thank you in advance!
        • 1. Re: Publishing with incorrect start page name
          Questions here
          Typical issue. What happens is you create the project and name it something like vizbybis. You configure the WebHelp Start Page to be vizbybis. But you also likely created a default topic and named that topic vizbybis.
          RoboHelp knows that there generally cannot be two HTML pages in the help folder that use the same name. So it renames one of them for you. In this case, naming the WebHelp start page vizbybis2.htm.
          This is why recent versions of RoboHelp use index.htm as the WebHelp start page.
          Your options are to rename either the WebHelp start page (I'd suggest this - Change it to index.htm) or rename the default topic.
          Curiosity question here. Are you using RoboHelp Server? If your answer is either "What is that?" or "no", then FlashHelp Pro is the wrong output type.
          Cheers... Rick
          • 2. Re: Publishing with incorrect start page name
            Shelley T Level 1
            I will give that a go.
            I dont typically use FlashHelp Pro.  But due to out IT department running http://www.bleepingcomputer.com/download/combofix/ on my computer I now receive the 'Please install a Web browser (Internet Explorer or Netscape)... when publishing using FlashHelp.  Only FlashHelp has been affected by this, I can publish using all other layouts. I have been through the forums and tried fixing by changing the default Open Width to Internet Explorer for .htm but no success.
            I need to be able to publish today so am going to use FlashHelp Pro, and IT has been asked to investigate the FlashHelp issue.
            • 3. Re: Publishing with incorrect start page name
              Shelley T Level 1
              Update.
              Using FlashHelp I have changed the start page name from vizexplorer.html to vizexplorer.htm and publishing now works.  I have been using vizexplorer.html for over 12 months with no problem.
