• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Easy Video?
Community Beginner ,
Mar 05, 2007 Mar 05, 2007
Is this product called Breeze because it is so easy to use?
Is there an easy way of inserting video into a slide (not the little talking head up in the corner) without becoming a flash programmer?
Tom
TOPICS
Presenter
Views
762
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Mar 06, 2007 Mar 06, 2007
We are using this piece of software, converts any video format to a swf file, works like a charm:
http://www.on2.com/consumer/flix-pro/
BTW, perhaps thats why they changed the name form Breeze to Presenter...
Votes
Translate
Translate
Report
Report
Mar 08, 2007 Mar 08, 2007
Thanks for the tip, are you using the FlixPro, or the FlixExporter? After using this, are you just importing the flash into the PowerPoint slide? Do you have to insert the audio seperately on the slide?
Could you just give me a quick run down on your work flow?
I just can't seem to get any of the SWF files to play as video in the PowerPoint slide for anything.
I can get the little talking head window to work with no proplem.
Thanks you for any advice.
Tom Bertram
Votes
Translate
Translate
Report
Report
New Here ,
Mar 12, 2007 Mar 12, 2007
Using Flix Pro, you can export a movie to a self containing swf file. The swf can contain both audio and video.
To insert this swf in a powerpoint, select the Adobe Presenter menu -> Insert Flash. Now you have the swf object on the slide, you can move and resize the movie as you like. But you need to export the powerpoint using presenter, before the movie will play.
Cheers
Votes
Translate
Translate
Report
Report
Thanks for replying to my questions.
I continue to have no luck. I downloaded the free trial of Flix-Pro. Followed that steps you advised:
1-Exported a movie to a self containing swf file that contains both audio and video.
2-inserted this swf in a PowerPoint by selecting the Adobe Presenter menu -> Insert Flash.
3-export the PowerPoint using presenter, I checked of to have the file uploaded when I published it.
When I view the published presentation, the video will not play.
Can you tell if I am missing anything? It sound so simple, but I am pulling my hair out.
Any advice is greatly appreciated.
Tom Bertram
tbertram@ilea.in.gov
Votes
Translate
Translate
Report
Report
New Here ,
Mar 13, 2007 Mar 13, 2007
I'm using Presenter vers. 6.0 - which version are you using?
After export the first frame of the video is showing, but the video is not playing?
Votes
Translate
Translate
Report
Report
I am using v5.1.2.. Do you think the upgrade to 6.0 will make a difference?
Yes the first frame only, of course it pays in preview while authoring in PowerPoint, but will not play after published.
Votes
Translate
Translate
Report
Report
Mar 20, 2007 Mar 20, 2007
Hi Tom,
If you have Breeze Presenter 5.1.269 and Flash Player 9 installed, it is possible that you're encountering an incompatibility issue with version 5.1.269 of Breeze Presenter and Flash Player 9. You might want to check this TechNote for more information:
Flash Player 9 Incompatibility Prevents SWF files from being inserted into Breeze Presenter –
http://www.adobe.com/go/9df0a79f
You have three options to resolve this issue:
1. If you still have version 5.1.269, you may either opt to downgrade to Flash Player 8 - OR -
2. File a support case through www.adobe.com/go/supportportal to request for the dll patch - OR -
3. Upgrade to the latest version (Adobe Presenter 6)
Hope this helps.
Votes
Translate
Translate
Report
Report
Mar 21, 2007 Mar 21, 2007
LATEST
Thank you kindly for your help, I will try your suggestions.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 14, 2007 Mar 14, 2007
I don't think your version supports flash video 8, you need to convert the video to another version of flash video.
In Flix Pro you can choose to export to another swf version. Try choosing MX SWF instead Flash 8 SWF.
Votes
Translate
Translate
Report
Report
Resources
Help resources
