4 Replies Latest reply on Jan 7, 2015 4:14 AM by Purmpol
    How can I make different color on text in the same layer "by script" ?
    Purmpol
      [Photoshop CC 2014]
      I need to write JavaScript  to make different color on the texts (or contents) that's in the same text layer. But I can't still find the way.
      example from ...
      to ...
      I have been searching for this solution on the internet for a half of day, but I can't find it.
      Help me please...
        • 1. Re: How can I make different color on text in the same layer "by script" ?
          You may need to use Action Manager Code have you looked at what get recorded by the  scriplistener plugin when you add your mixed colored text layer.
          • 2. Re: How can I make different color on text in the same layer "by script" ?
            Purmpol Level 1
            Hello JJMack
            I'm new to the script programming. When I read the script from the listener's output file, I feel so dizzy.
            However, thanks for your advice. And I will put more effort to do this again.
            • 3. Re: How can I make different color on text in the same layer "by script" ?
              Purmpol Level 1
              I've tried so many times. For simple operation about changing Text color (or format), PS generates huge codes as below.
              Perharps I have to spend all day or (a few days), to understand them.
              var idsetd = charIDToTypeID( "setd" );
                  var desc118 = new ActionDescriptor();
                  var idnull = charIDToTypeID( "null" );
                      var ref21 = new ActionReference();
                      var idTxLr = charIDToTypeID( "TxLr" );
                      var idOrdn = charIDToTypeID( "Ordn" );
                      var idTrgt = charIDToTypeID( "Trgt" );
                      ref21.putEnumerated( idTxLr, idOrdn, idTrgt );
                  desc118.putReference( idnull, ref21 );
                  var idT = charIDToTypeID( "T   " );
                      var desc119 = new ActionDescriptor();
                      var idTxt = charIDToTypeID( "Txt " );
                      desc119.putString( idTxt, """ABC""" );
                      var idwarp = stringIDToTypeID( "warp" );
                          var desc120 = new ActionDescriptor();
                          var idwarpStyle = stringIDToTypeID( "warpStyle" );
                          var idwarpNone = stringIDToTypeID( "warpNone" );
                          desc120.putEnumerated( idwarpStyle, idwarpStyle, idwarpNone );
                          var idwarpValue = stringIDToTypeID( "warpValue" );
                          desc120.putDouble( idwarpValue, 0.000000 );
                          var idwarpPerspective = stringIDToTypeID( "warpPerspective" );
                          desc120.putDouble( idwarpPerspective, 0.000000 );
                          var idwarpPerspectiveOther = stringIDToTypeID( "warpPerspectiveOther" );
                          desc120.putDouble( idwarpPerspectiveOther, 0.000000 );
                          var idwarpRotate = stringIDToTypeID( "warpRotate" );
                          var idOrnt = charIDToTypeID( "Ornt" );
                          var idHrzn = charIDToTypeID( "Hrzn" );
                          desc120.putEnumerated( idwarpRotate, idOrnt, idHrzn );
                      desc119.putObject( idwarp, idwarp, desc120 );
                      var idtextGridding = stringIDToTypeID( "textGridding" );
                      var idNone = charIDToTypeID( "None" );
                      desc119.putEnumerated( idtextGridding, idtextGridding, idNone );
                      var idVrtc = charIDToTypeID( "Vrtc" );
                      desc119.putEnumerated( idOrnt, idOrnt, idVrtc );
                      var idAntA = charIDToTypeID( "AntA" );
                      var idAnnt = charIDToTypeID( "Annt" );
                      var idAnCr = charIDToTypeID( "AnCr" );
                      desc119.putEnumerated( idAntA, idAnnt, idAnCr );
                      var idbounds = stringIDToTypeID( "bounds" );
                          var desc121 = new ActionDescriptor();
                          var idLeft = charIDToTypeID( "Left" );
                          var idPnt = charIDToTypeID( "#Pnt" );
                          desc121.putUnitDouble( idLeft, idPnt, -36.000008 );
                          var idTop = charIDToTypeID( "Top " );
                          desc121.putUnitDouble( idTop, idPnt, -0.000002 );
                          var idRght = charIDToTypeID( "Rght" );
                          desc121.putUnitDouble( idRght, idPnt, 36.000000 );
                          var idBtom = charIDToTypeID( "Btom" );
                          desc121.putUnitDouble( idBtom, idPnt, 216.000000 );
                      desc119.putObject( idbounds, idbounds, desc121 );
                      var idboundingBox = stringIDToTypeID( "boundingBox" );
                          var desc122 = new ActionDescriptor();
                          desc122.putUnitDouble( idLeft, idPnt, -25.451172 );
                          desc122.putUnitDouble( idTop, idPnt, 10.834839 );
                          desc122.putUnitDouble( idRght, idPnt, 25.189453 );
                          desc122.putUnitDouble( idBtom, idPnt, 204.834839 );
                      desc119.putObject( idboundingBox, idboundingBox, desc122 );
                      var idtextShape = stringIDToTypeID( "textShape" );
                          var list19 = new ActionList();
                              var desc123 = new ActionDescriptor();
                              var idTEXT = charIDToTypeID( "TEXT" );
                              var idPnt = charIDToTypeID( "Pnt " );
                              desc123.putEnumerated( idTEXT, idTEXT, idPnt );
                              desc123.putEnumerated( idOrnt, idOrnt, idVrtc );
                              var idTrnf = charIDToTypeID( "Trnf" );
                                  var desc124 = new ActionDescriptor();
                                  var idxx = stringIDToTypeID( "xx" );
                                  desc124.putDouble( idxx, 1.000000 );
                                  var idxy = stringIDToTypeID( "xy" );
                                  desc124.putDouble( idxy, 0.000000 );
                                  var idyx = stringIDToTypeID( "yx" );
                                  desc124.putDouble( idyx, 0.000000 );
                                  var idyy = stringIDToTypeID( "yy" );
                                  desc124.putDouble( idyy, 1.000000 );
                                  var idtx = stringIDToTypeID( "tx" );
                                  desc124.putDouble( idtx, 0.000000 );
                                  var idty = stringIDToTypeID( "ty" );
                                  desc124.putDouble( idty, 0.000000 );
                              desc123.putObject( idTrnf, idTrnf, desc124 );
                              var idrowCount = stringIDToTypeID( "rowCount" );
                              desc123.putInteger( idrowCount, 1 );
                              var idcolumnCount = stringIDToTypeID( "columnCount" );
                              desc123.putInteger( idcolumnCount, 1 );
                              var idrowMajorOrder = stringIDToTypeID( "rowMajorOrder" );
                              desc123.putBoolean( idrowMajorOrder, true );
                              var idrowGutter = stringIDToTypeID( "rowGutter" );
                              desc123.putUnitDouble( idrowGutter, idPnt, 0.000000 );
                              var idcolumnGutter = stringIDToTypeID( "columnGutter" );
                              desc123.putUnitDouble( idcolumnGutter, idPnt, 0.000000 );
                              var idSpcn = charIDToTypeID( "Spcn" );
                              desc123.putUnitDouble( idSpcn, idPnt, 0.000000 );
                              var idframeBaselineAlignment = stringIDToTypeID( "frameBaselineAlignment" );
                              var idalignByAscent = stringIDToTypeID( "alignByAscent" );
                              desc123.putEnumerated( idframeBaselineAlignment, idframeBaselineAlignment, idalignByAscent );
                              var idfirstBaselineMinimum = stringIDToTypeID( "firstBaselineMinimum" );
                              desc123.putUnitDouble( idfirstBaselineMinimum, idPnt, 0.000000 );
                              var idbase = stringIDToTypeID( "base" );
                                  var desc125 = new ActionDescriptor();
                                  desc125.putDouble( idHrzn, 0.000000 );
                                  desc125.putDouble( idVrtc, 0.000000 );
                              desc123.putObject( idbase, idPnt, desc125 );
                          list19.putObject( idtextShape, desc123 );
                      desc119.putList( idtextShape, list19 );
                      var idTxtt = charIDToTypeID( "Txtt" );
                          var list20 = new ActionList();
                              var desc126 = new ActionDescriptor();
                              var idFrom = charIDToTypeID( "From" );
                              desc126.putInteger( idFrom, 0 );
                              desc126.putInteger( idT, 1 );
                              var idTxtS = charIDToTypeID( "TxtS" );
                                  var desc127 = new ActionDescriptor();
                                  var idstyleSheetHasParent = stringIDToTypeID( "styleSheetHasParent" );
                                  desc127.putBoolean( idstyleSheetHasParent, true );
                                  var idfontPostScriptName = stringIDToTypeID( "fontPostScriptName" );
                                  desc127.putString( idfontPostScriptName, """TimesNewRomanPSMT""" );
                                  var idFntN = charIDToTypeID( "FntN" );
                                  desc127.putString( idFntN, """Times New Roman""" );
                                  var idFntS = charIDToTypeID( "FntS" );
                                  desc127.putString( idFntS, """Regular""" );
                                  var idScrp = charIDToTypeID( "Scrp" );
                                  desc127.putInteger( idScrp, 0 );
                                  var idFntT = charIDToTypeID( "FntT" );
                                  desc127.putInteger( idFntT, 1 );
                                  var idSz = charIDToTypeID( "Sz  " );
                                  desc127.putUnitDouble( idSz, idPnt, 72.000000 );
                                  var idimpliedFontSize = stringIDToTypeID( "impliedFontSize" );
                                  desc127.putUnitDouble( idimpliedFontSize, idPnt, 72.000000 );
                                  var iddigitSet = stringIDToTypeID( "digitSet" );
                                  var iddefaultDigits = stringIDToTypeID( "defaultDigits" );
                                  desc127.putEnumerated( iddigitSet, iddigitSet, iddefaultDigits );
                                  var idmarkYDistFromBaseline = stringIDToTypeID( "markYDistFromBaseline" );
                                  desc127.putUnitDouble( idmarkYDistFromBaseline, idPnt, 100.000000 );
                                  var idClr = charIDToTypeID( "Clr " );
                                      var desc128 = new ActionDescriptor();
                                      var idRd = charIDToTypeID( "Rd  " );
                                      desc128.putDouble( idRd, 99.998474 );
                                      var idGrn = charIDToTypeID( "Grn " );
                                      desc128.putDouble( idGrn, 99.998474 );
                                      var idBl = charIDToTypeID( "Bl  " );
                                      desc128.putDouble( idBl, 99.998474 );
                                  var idRGBC = charIDToTypeID( "RGBC" );
                                  desc127.putObject( idClr, idRGBC, desc128 );
                                  var idstrokeColor = stringIDToTypeID( "strokeColor" );
                                      var desc129 = new ActionDescriptor();
                                      desc129.putDouble( idRd, 255.000000 );
                                      desc129.putDouble( idGrn, 255.000000 );
                                      desc129.putDouble( idBl, 255.000000 );
                                  desc127.putObject( idstrokeColor, idRGBC, desc129 );
                                  var idbaseParentStyle = stringIDToTypeID( "baseParentStyle" );
                                      var desc130 = new ActionDescriptor();
                                      desc130.putString( idfontPostScriptName, """MyriadPro-Regular""" );
                                      desc130.putString( idFntN, """Myriad Pro""" );
                                      desc130.putString( idFntS, """Regular""" );
                                      desc130.putInteger( idScrp, 0 );
                                      desc130.putInteger( idFntT, 0 );
                                      desc130.putUnitDouble( idSz, idPnt, 12.000000 );
                                      desc130.putUnitDouble( idimpliedFontSize, idPnt, 12.000000 );
                                      var idHrzS = charIDToTypeID( "HrzS" );
                                      desc130.putDouble( idHrzS, 100.000000 );
                                      var idVrtS = charIDToTypeID( "VrtS" );
                                      desc130.putDouble( idVrtS, 100.000000 );
                                      var idsyntheticBold = stringIDToTypeID( "syntheticBold" );
                                      desc130.putBoolean( idsyntheticBold, false );
                                      var idsyntheticItalic = stringIDToTypeID( "syntheticItalic" );
                                      desc130.putBoolean( idsyntheticItalic, false );
                                      var idautoLeading = stringIDToTypeID( "autoLeading" );
                                      desc130.putBoolean( idautoLeading, true );
                                      var idTrck = charIDToTypeID( "Trck" );
                                      desc130.putInteger( idTrck, 0 );
                                      var idBsln = charIDToTypeID( "Bsln" );
                                      desc130.putUnitDouble( idBsln, idPnt, 0.000000 );
                                      var idimpliedBaselineShift = stringIDToTypeID( "impliedBaselineShift" );
                                      desc130.putUnitDouble( idimpliedBaselineShift, idPnt, 0.000000 );
                                      var idcharacterRotation = stringIDToTypeID( "characterRotation" );
                                      desc130.putDouble( idcharacterRotation, 0.000000 );
                                      var idAtKr = charIDToTypeID( "AtKr" );
                                      var idmetricsKern = stringIDToTypeID( "metricsKern" );
                                      desc130.putEnumerated( idAtKr, idAtKr, idmetricsKern );
                                      var idfontCaps = stringIDToTypeID( "fontCaps" );
                                      var idNrml = charIDToTypeID( "Nrml" );
                                      desc130.putEnumerated( idfontCaps, idfontCaps, idNrml );
                                      desc130.putEnumerated( iddigitSet, iddigitSet, iddefaultDigits );
                                      var iddirOverride = stringIDToTypeID( "dirOverride" );
                                      var iddirOverrideDefault = stringIDToTypeID( "dirOverrideDefault" );
                                      desc130.putEnumerated( iddirOverride, iddirOverride, iddirOverrideDefault );
                                      var idkashidas = stringIDToTypeID( "kashidas" );
                                      var idkashidaDefault = stringIDToTypeID( "kashidaDefault" );
                                      desc130.putEnumerated( idkashidas, idkashidas, idkashidaDefault );
                                      var iddiacVPos = stringIDToTypeID( "diacVPos" );
                                      var iddiacVPosOpenType = stringIDToTypeID( "diacVPosOpenType" );
                                      desc130.putEnumerated( iddiacVPos, iddiacVPos, iddiacVPosOpenType );
                                      var iddiacXOffset = stringIDToTypeID( "diacXOffset" );
                                      desc130.putUnitDouble( iddiacXOffset, idPnt, 0.000000 );
                                      var iddiacYOffset = stringIDToTypeID( "diacYOffset" );
                                      desc130.putUnitDouble( iddiacYOffset, idPnt, 0.000000 );
                                      desc130.putUnitDouble( idmarkYDistFromBaseline, idPnt, 100.000000 );
                                      var idbaseline = stringIDToTypeID( "baseline" );
                                      desc130.putEnumerated( idbaseline, idbaseline, idNrml );
                                      var idotbaseline = stringIDToTypeID( "otbaseline" );
                                      desc130.putEnumerated( idotbaseline, idotbaseline, idNrml );
                                      var idstrikethrough = stringIDToTypeID( "strikethrough" );
                                      var idstrikethroughOff = stringIDToTypeID( "strikethroughOff" );
                                      desc130.putEnumerated( idstrikethrough, idstrikethrough, idstrikethroughOff );
                                      var idUndl = charIDToTypeID( "Undl" );
                                      var idunderlineOff = stringIDToTypeID( "underlineOff" );
                                      desc130.putEnumerated( idUndl, idUndl, idunderlineOff );
                                      var idunderlineOffset = stringIDToTypeID( "underlineOffset" );
                                      desc130.putUnitDouble( idunderlineOffset, idPnt, 0.000000 );
                                      var idligature = stringIDToTypeID( "ligature" );
                                      desc130.putBoolean( idligature, true );
                                      var idaltligature = stringIDToTypeID( "altligature" );
                                      desc130.putBoolean( idaltligature, false );
                                      var idcontextualLigatures = stringIDToTypeID( "contextualLigatures" );
                                      desc130.putBoolean( idcontextualLigatures, false );
                                      var idalternateLigatures = stringIDToTypeID( "alternateLigatures" );
                                      desc130.putBoolean( idalternateLigatures, false );
                                      var idoldStyle = stringIDToTypeID( "oldStyle" );
                                      desc130.putBoolean( idoldStyle, false );
                                      var idfractions = stringIDToTypeID( "fractions" );
                                      desc130.putBoolean( idfractions, false );
                                      var idordinals = stringIDToTypeID( "ordinals" );
                                      desc130.putBoolean( idordinals, false );
                                      var idswash = stringIDToTypeID( "swash" );
                                      desc130.putBoolean( idswash, false );
                                      var idtitling = stringIDToTypeID( "titling" );
                                      desc130.putBoolean( idtitling, false );
                                      var idconnectionForms = stringIDToTypeID( "connectionForms" );
                                      desc130.putBoolean( idconnectionForms, false );
                                      var idstylisticAlternates = stringIDToTypeID( "stylisticAlternates" );
                                      desc130.putBoolean( idstylisticAlternates, false );
                                      var idornaments = stringIDToTypeID( "ornaments" );
                                      desc130.putBoolean( idornaments, false );
                                      var idjustificationAlternates = stringIDToTypeID( "justificationAlternates" );
                                      desc130.putBoolean( idjustificationAlternates, false );
                                      var idfigureStyle = stringIDToTypeID( "figureStyle" );
                                      desc130.putEnumerated( idfigureStyle, idfigureStyle, idNrml );
                                      var idproportionalMetrics = stringIDToTypeID( "proportionalMetrics" );
                                      desc130.putBoolean( idproportionalMetrics, false );
                                      var idkana = stringIDToTypeID( "kana" );
                                      desc130.putBoolean( idkana, false );
                                      var iditalics = stringIDToTypeID( "italics" );
                                      desc130.putBoolean( iditalics, false );
                                      var idruby = stringIDToTypeID( "ruby" );
                                      desc130.putBoolean( idruby, false );
                                      var idbaselineDirection = stringIDToTypeID( "baselineDirection" );
                                      var idrotated = stringIDToTypeID( "rotated" );
                                      desc130.putEnumerated( idbaselineDirection, idbaselineDirection, idrotated );
                                      var idtextLanguage = stringIDToTypeID( "textLanguage" );
                                      var idenglishLanguage = stringIDToTypeID( "englishLanguage" );
                                      desc130.putEnumerated( idtextLanguage, idtextLanguage, idenglishLanguage );
                                      var idjapaneseAlternate = stringIDToTypeID( "japaneseAlternate" );
                                      var iddefaultForm = stringIDToTypeID( "defaultForm" );
                                      desc130.putEnumerated( idjapaneseAlternate, idjapaneseAlternate, iddefaultForm );
                                      var idmojiZume = stringIDToTypeID( "mojiZume" );
                                      desc130.putDouble( idmojiZume, 0.000000 );
                                      var idgridAlignment = stringIDToTypeID( "gridAlignment" );
                                      var idroman = stringIDToTypeID( "roman" );
                                      desc130.putEnumerated( idgridAlignment, idgridAlignment, idroman );
                                      var idenableWariChu = stringIDToTypeID( "enableWariChu" );
                                      desc130.putBoolean( idenableWariChu, false );
                                      var idwariChuCount = stringIDToTypeID( "wariChuCount" );
                                      desc130.putInteger( idwariChuCount, 2 );
                                      var idwariChuLineGap = stringIDToTypeID( "wariChuLineGap" );
                                      desc130.putInteger( idwariChuLineGap, 0 );
                                      var idwariChuScale = stringIDToTypeID( "wariChuScale" );
                                      desc130.putDouble( idwariChuScale, 0.500000 );
                                      var idwariChuWidow = stringIDToTypeID( "wariChuWidow" );
                                      desc130.putInteger( idwariChuWidow, 2 );
                                      var idwariChuOrphan = stringIDToTypeID( "wariChuOrphan" );
                                      desc130.putInteger( idwariChuOrphan, 2 );
                                      var idwariChuJustification = stringIDToTypeID( "wariChuJustification" );
                                      var idwariChuAutoJustify = stringIDToTypeID( "wariChuAutoJustify" );
                                      desc130.putEnumerated( idwariChuJustification, idwariChuJustification, idwariChuAutoJustify );
                                      var idtcyUpDown = stringIDToTypeID( "tcyUpDown" );
                                      desc130.putInteger( idtcyUpDown, 0 );
                                      var idtcyLeftRight = stringIDToTypeID( "tcyLeftRight" );
                                      desc130.putInteger( idtcyLeftRight, 0 );
                                      var idleftAki = stringIDToTypeID( "leftAki" );
                                      desc130.putDouble( idleftAki, -1.000000 );
                                      var idrightAki = stringIDToTypeID( "rightAki" );
                                      desc130.putDouble( idrightAki, -1.000000 );
                                      var idjiDori = stringIDToTypeID( "jiDori" );
                                      desc130.putInteger( idjiDori, 0 );
                                      var idnoBreak = stringIDToTypeID( "noBreak" );
                                      desc130.putBoolean( idnoBreak, false );
                                          var desc131 = new ActionDescriptor();
                                          desc131.putDouble( idRd, 0.000000 );
                                          desc131.putDouble( idGrn, 0.000000 );
                                          desc131.putDouble( idBl, 0.000000 );
                                      desc130.putObject( idClr, idRGBC, desc131 );
                                          var desc132 = new ActionDescriptor();
                                          desc132.putDouble( idRd, 0.000000 );
                                          desc132.putDouble( idGrn, 0.000000 );
                                          desc132.putDouble( idBl, 0.000000 );
                                      desc130.putObject( idstrokeColor, idRGBC, desc132 );
                                      var idFl = charIDToTypeID( "Fl  " );
                                      desc130.putBoolean( idFl, true );
                                      var idStrk = charIDToTypeID( "Strk" );
                                      desc130.putBoolean( idStrk, false );
                                      var idfillFirst = stringIDToTypeID( "fillFirst" );
                                      desc130.putBoolean( idfillFirst, true );
                                      var idfillOverPrint = stringIDToTypeID( "fillOverPrint" );
                                      desc130.putBoolean( idfillOverPrint, false );
                                      var idstrokeOverPrint = stringIDToTypeID( "strokeOverPrint" );
                                      desc130.putBoolean( idstrokeOverPrint, false );
                                      var idlineCap = stringIDToTypeID( "lineCap" );
                                      var idbuttCap = stringIDToTypeID( "buttCap" );
                                      desc130.putEnumerated( idlineCap, idlineCap, idbuttCap );
                                      var idlineJoin = stringIDToTypeID( "lineJoin" );
                                      var idmiterJoin = stringIDToTypeID( "miterJoin" );
                                      desc130.putEnumerated( idlineJoin, idlineJoin, idmiterJoin );
                                      var idlineWidth = stringIDToTypeID( "lineWidth" );
                                      desc130.putUnitDouble( idlineWidth, idPnt, 1.000000 );
                                      var idmiterLimit = stringIDToTypeID( "miterLimit" );
                                      desc130.putUnitDouble( idmiterLimit, idPnt, 4.000000 );
                                      var idlineDashoffset = stringIDToTypeID( "lineDashoffset" );
                                      desc130.putDouble( idlineDashoffset, 0.000000 );
                                  desc127.putObject( idbaseParentStyle, idTxtS, desc130 );
                              desc126.putObject( idTxtS, idTxtS, desc127 );
                          list20.putObject( idTxtt, desc126 );
                              var desc133 = new ActionDescriptor();
                              desc133.putInteger( idFrom, 1 );
                              desc133.putInteger( idT, 2 );
                                  var desc134 = new ActionDescriptor();
                                  desc134.putBoolean( idstyleSheetHasParent, true );
                                  desc134.putString( idfontPostScriptName, """TimesNewRomanPSMT""" );
                                  desc134.putString( idFntN, """Times New Roman""" );
                                  desc134.putString( idFntS, """Regular""" );
                                  desc134.putInteger( idScrp, 0 );
                                  desc134.putInteger( idFntT, 1 );
                                  desc134.putUnitDouble( idSz, idPnt, 72.000000 );
                                  desc134.putUnitDouble( idimpliedFontSize, idPnt, 72.000000 );
                                  desc134.putEnumerated( iddigitSet, iddigitSet, iddefaultDigits );
                                  desc134.putUnitDouble( idmarkYDistFromBaseline, idPnt, 100.000000 );
                                      var desc135 = new ActionDescriptor();
                                      desc135.putDouble( idRd, 199.996948 );
                                      desc135.putDouble( idGrn, 99.998474 );
                                      desc135.putDouble( idBl, 199.996948 );
                                  desc134.putObject( idClr, idRGBC, desc135 );
                                      var desc136 = new ActionDescriptor();
                                      desc136.putDouble( idRd, 255.000000 );
                                      desc136.putDouble( idGrn, 255.000000 );
                                      desc136.putDouble( idBl, 255.000000 );
                                  desc134.putObject( idstrokeColor, idRGBC, desc136 );
                              desc133.putObject( idTxtS, idTxtS, desc134 );
                          list20.putObject( idTxtt, desc133 );
                              var desc137 = new ActionDescriptor();
                              desc137.putInteger( idFrom, 2 );
                              desc137.putInteger( idT, 4 );
                                  var desc138 = new ActionDescriptor();
                                  desc138.putBoolean( idstyleSheetHasParent, true );
                                  desc138.putString( idfontPostScriptName, """TimesNewRomanPSMT""" );
                                  desc138.putString( idFntN, """Times New Roman""" );
                                  desc138.putString( idFntS, """Regular""" );
                                  desc138.putInteger( idScrp, 0 );
                                  desc138.putInteger( idFntT, 1 );
                                  desc138.putUnitDouble( idSz, idPnt, 72.000000 );
                                  desc138.putUnitDouble( idimpliedFontSize, idPnt, 72.000000 );
                                  desc138.putEnumerated( iddigitSet, iddigitSet, iddefaultDigits );
                                  desc138.putUnitDouble( idmarkYDistFromBaseline, idPnt, 100.000000 );
                                      var desc139 = new ActionDescriptor();
                                      desc139.putDouble( idRd, 99.998474 );
                                      desc139.putDouble( idGrn, 99.998474 );
                                      desc139.putDouble( idBl, 99.998474 );
                                  desc138.putObject( idClr, idRGBC, desc139 );
                                      var desc140 = new ActionDescriptor();
                                      desc140.putDouble( idRd, 255.000000 );
                                      desc140.putDouble( idGrn, 255.000000 );
                                      desc140.putDouble( idBl, 255.000000 );
                                  desc138.putObject( idstrokeColor, idRGBC, desc140 );
                              desc137.putObject( idTxtS, idTxtS, desc138 );
                          list20.putObject( idTxtt, desc137 );
                      desc119.putList( idTxtt, list20 );
                      var idparagraphStyleRange = stringIDToTypeID( "paragraphStyleRange" );
                          var list21 = new ActionList();
                              var desc141 = new ActionDescriptor();
                              desc141.putInteger( idFrom, 0 );
                              desc141.putInteger( idT, 4 );
                              var idparagraphStyle = stringIDToTypeID( "paragraphStyle" );
                                  var desc142 = new ActionDescriptor();
                                  desc142.putBoolean( idstyleSheetHasParent, true );
                                  var idAlgn = charIDToTypeID( "Algn" );
                                  var idAlg = charIDToTypeID( "Alg " );
                                  desc142.putEnumerated( idAlgn, idAlg, idLeft );
                                  var idfirstLineIndent = stringIDToTypeID( "firstLineIndent" );
                                  desc142.putUnitDouble( idfirstLineIndent, idPnt, 0.000000 );
                                  var idimpliedFirstLineIndent = stringIDToTypeID( "impliedFirstLineIndent" );
                                  desc142.putUnitDouble( idimpliedFirstLineIndent, idPnt, 0.000000 );
                                  var idstartIndent = stringIDToTypeID( "startIndent" );
                                  desc142.putUnitDouble( idstartIndent, idPnt, 0.000000 );
                                  var idimpliedStartIndent = stringIDToTypeID( "impliedStartIndent" );
                                  desc142.putUnitDouble( idimpliedStartIndent, idPnt, 0.000000 );
                                  var idendIndent = stringIDToTypeID( "endIndent" );
                                  desc142.putUnitDouble( idendIndent, idPnt, 0.000000 );
                                  var idimpliedEndIndent = stringIDToTypeID( "impliedEndIndent" );
                                  desc142.putUnitDouble( idimpliedEndIndent, idPnt, 0.000000 );
                                  var idspaceBefore = stringIDToTypeID( "spaceBefore" );
                                  desc142.putUnitDouble( idspaceBefore, idPnt, 0.000000 );
                                  var idimpliedSpaceBefore = stringIDToTypeID( "impliedSpaceBefore" );
                                  desc142.putUnitDouble( idimpliedSpaceBefore, idPnt, 0.000000 );
                                  var idspaceAfter = stringIDToTypeID( "spaceAfter" );
                                  desc142.putUnitDouble( idspaceAfter, idPnt, 0.000000 );
                                  var idimpliedSpaceAfter = stringIDToTypeID( "impliedSpaceAfter" );
                                  desc142.putUnitDouble( idimpliedSpaceAfter, idPnt, 0.000000 );
                                  var iddropCapMultiplier = stringIDToTypeID( "dropCapMultiplier" );
                                  desc142.putInteger( iddropCapMultiplier, 1 );
                                  var idautoLeadingPercentage = stringIDToTypeID( "autoLeadingPercentage" );
                                  desc142.putDouble( idautoLeadingPercentage, 1.200000 );
                                  var idleadingType = stringIDToTypeID( "leadingType" );
                                  var idleadingBelow = stringIDToTypeID( "leadingBelow" );
                                  desc142.putEnumerated( idleadingType, idleadingType, idleadingBelow );
                                  var iddirectionType = stringIDToTypeID( "directionType" );
                                  var iddirLeftToRight = stringIDToTypeID( "dirLeftToRight" );
                                  desc142.putEnumerated( iddirectionType, iddirectionType, iddirLeftToRight );
                                  var idkashidaWidthType = stringIDToTypeID( "kashidaWidthType" );
                                  var idkashidaWidthMedium = stringIDToTypeID( "kashidaWidthMedium" );
                                  desc142.putEnumerated( idkashidaWidthType, idkashidaWidthType, idkashidaWidthMedium );
                                  var idjustificationMethodType = stringIDToTypeID( "justificationMethodType" );
                                  var idjustifMethodAutomatic = stringIDToTypeID( "justifMethodAutomatic" );
                                  desc142.putEnumerated( idjustificationMethodType, idjustificationMethodType, idjustifMethodAutomatic );
                                  var idhyphenate = stringIDToTypeID( "hyphenate" );
                                  desc142.putBoolean( idhyphenate, true );
                                  var idhyphenateWordSize = stringIDToTypeID( "hyphenateWordSize" );
                                  desc142.putInteger( idhyphenateWordSize, 6 );
                                  var idhyphenatePreLength = stringIDToTypeID( "hyphenatePreLength" );
                                  desc142.putInteger( idhyphenatePreLength, 2 );
                                  var idhyphenatePostLength = stringIDToTypeID( "hyphenatePostLength" );
                                  desc142.putInteger( idhyphenatePostLength, 2 );
                                  var idhyphenateLimit = stringIDToTypeID( "hyphenateLimit" );
                                  desc142.putInteger( idhyphenateLimit, 0 );
                                  var idhyphenationZone = stringIDToTypeID( "hyphenationZone" );
                                  desc142.putDouble( idhyphenationZone, 36.000000 );
                                  var idhyphenateCapitalized = stringIDToTypeID( "hyphenateCapitalized" );
                                  desc142.putBoolean( idhyphenateCapitalized, true );
                                  var idhyphenationPreference = stringIDToTypeID( "hyphenationPreference" );
                                  desc142.putDouble( idhyphenationPreference, 0.500000 );
                                  var idjustificationWordMinimum = stringIDToTypeID( "justificationWordMinimum" );
                                  desc142.putDouble( idjustificationWordMinimum, 0.800000 );
                                  var idjustificationWordDesired = stringIDToTypeID( "justificationWordDesired" );
                                  desc142.putDouble( idjustificationWordDesired, 1.000000 );
                                  var idjustificationWordMaximum = stringIDToTypeID( "justificationWordMaximum" );
                                  desc142.putDouble( idjustificationWordMaximum, 1.330000 );
                                  var idjustificationLetterMinimum = stringIDToTypeID( "justificationLetterMinimum" );
                                  desc142.putDouble( idjustificationLetterMinimum, 0.000000 );
                                  var idjustificationLetterDesired = stringIDToTypeID( "justificationLetterDesired" );
                                  desc142.putDouble( idjustificationLetterDesired, 0.000000 );
                                  var idjustificationLetterMaximum = stringIDToTypeID( "justificationLetterMaximum" );
                                  desc142.putDouble( idjustificationLetterMaximum, 0.000000 );
                                  var idjustificationGlyphMinimum = stringIDToTypeID( "justificationGlyphMinimum" );
                                  desc142.putDouble( idjustificationGlyphMinimum, 1.000000 );
                                  var idjustificationGlyphDesired = stringIDToTypeID( "justificationGlyphDesired" );
                                  desc142.putDouble( idjustificationGlyphDesired, 1.000000 );
                                  var idjustificationGlyphMaximum = stringIDToTypeID( "justificationGlyphMaximum" );
                                  desc142.putDouble( idjustificationGlyphMaximum, 1.000000 );
                                  var idsingleWordJustification = stringIDToTypeID( "singleWordJustification" );
                                  var idJstA = charIDToTypeID( "JstA" );
                                  desc142.putEnumerated( idsingleWordJustification, idAlg, idJstA );
                                  var idhangingRoman = stringIDToTypeID( "hangingRoman" );
                                  desc142.putBoolean( idhangingRoman, false );
                                  var idautoTCY = stringIDToTypeID( "autoTCY" );
                                  desc142.putInteger( idautoTCY, 0 );
                                  var idkeepTogether = stringIDToTypeID( "keepTogether" );
                                  desc142.putBoolean( idkeepTogether, true );
                                  var idburasagari = stringIDToTypeID( "burasagari" );
                                  var idburasagariNone = stringIDToTypeID( "burasagariNone" );
                                  desc142.putEnumerated( idburasagari, idburasagari, idburasagariNone );
                                  var idpreferredKinsokuOrder = stringIDToTypeID( "preferredKinsokuOrder" );
                                  var idpushIn = stringIDToTypeID( "pushIn" );
                                  desc142.putEnumerated( idpreferredKinsokuOrder, idpreferredKinsokuOrder, idpushIn );
                                  var idkurikaeshiMojiShori = stringIDToTypeID( "kurikaeshiMojiShori" );
                                  desc142.putBoolean( idkurikaeshiMojiShori, false );
                                  var idtextEveryLineComposer = stringIDToTypeID( "textEveryLineComposer" );
                                  desc142.putBoolean( idtextEveryLineComposer, false );
                                  var iddefaultTabWidth = stringIDToTypeID( "defaultTabWidth" );
                                  desc142.putDouble( iddefaultTabWidth, 36.000000 );
                                  var iddefaultStyle = stringIDToTypeID( "defaultStyle" );
                                      var desc143 = new ActionDescriptor();
                                      desc143.putString( idfontPostScriptName, """MyriadPro-Regular""" );
                                      desc143.putString( idFntN, """Myriad Pro""" );
                                      desc143.putString( idFntS, """Regular""" );
                                      desc143.putInteger( idScrp, 0 );
                                      desc143.putInteger( idFntT, 0 );
                                      desc143.putUnitDouble( idSz, idPnt, 12.000000 );
                                      desc143.putDouble( idHrzS, 100.000000 );
                                      desc143.putDouble( idVrtS, 100.000000 );
                                      desc143.putBoolean( idsyntheticBold, false );
                                      desc143.putBoolean( idsyntheticItalic, false );
                                      desc143.putBoolean( idautoLeading, true );
                                      desc143.putInteger( idTrck, 0 );
                                      desc143.putUnitDouble( idBsln, idPnt, 0.000000 );
                                      desc143.putDouble( idcharacterRotation, 0.000000 );
                                      desc143.putEnumerated( idAtKr, idAtKr, idmetricsKern );
                                      desc143.putEnumerated( idfontCaps, idfontCaps, idNrml );
                                      var idarabicDigits = stringIDToTypeID( "arabicDigits" );
                                      desc143.putEnumerated( iddigitSet, iddigitSet, idarabicDigits );
                                      desc143.putEnumerated( idkashidas, idkashidas, idkashidaDefault );
                                      desc143.putEnumerated( iddiacVPos, iddiacVPos, iddiacVPosOpenType );
                                      desc143.putUnitDouble( iddiacXOffset, idPnt, 0.000000 );
                                      desc143.putUnitDouble( iddiacYOffset, idPnt, 0.000000 );
                                      desc143.putUnitDouble( idmarkYDistFromBaseline, idPnt, 0.000000 );
                                      desc143.putEnumerated( idbaseline, idbaseline, idNrml );
                                      desc143.putEnumerated( idstrikethrough, idstrikethrough, idstrikethroughOff );
                                      desc143.putEnumerated( idUndl, idUndl, idunderlineOff );
                                      desc143.putBoolean( idligature, true );
                                      desc143.putBoolean( idaltligature, false );
                                      desc143.putBoolean( idcontextualLigatures, true );
                                      desc143.putBoolean( idalternateLigatures, false );
                                      desc143.putBoolean( idoldStyle, false );
                                      desc143.putBoolean( idfractions, false );
                                      desc143.putBoolean( idordinals, false );
                                      desc143.putBoolean( idswash, false );
                                      desc143.putBoolean( idtitling, false );
                                      desc143.putBoolean( idconnectionForms, false );
                                      desc143.putBoolean( idstylisticAlternates, false );
                                      desc143.putBoolean( idornaments, false );
                                      desc143.putEnumerated( idfigureStyle, idfigureStyle, idNrml );
                                      var idwithStream = stringIDToTypeID( "withStream" );
                                      desc143.putEnumerated( idbaselineDirection, idbaselineDirection, idwithStream );
                                      desc143.putEnumerated( idtextLanguage, idtextLanguage, idenglishLanguage );
                                          var desc144 = new ActionDescriptor();
                                          desc144.putDouble( idRd, 0.000000 );
                                          desc144.putDouble( idGrn, 0.000000 );
                                          desc144.putDouble( idBl, 0.000000 );
                                      desc143.putObject( idClr, idRGBC, desc144 );
                                          var desc145 = new ActionDescriptor();
                                          desc145.putDouble( idRd, 0.000000 );
                                          desc145.putDouble( idGrn, 0.000000 );
                                          desc145.putDouble( idBl, 0.000000 );
                                      desc143.putObject( idstrokeColor, idRGBC, desc145 );
                                  desc142.putObject( iddefaultStyle, idTxtS, desc143 );
                              desc141.putObject( idparagraphStyle, idparagraphStyle, desc142 );
                          list21.putObject( idparagraphStyleRange, desc141 );
                      desc119.putList( idparagraphStyleRange, list21 );
                      var idkerningRange = stringIDToTypeID( "kerningRange" );
                          var list22 = new ActionList();
                      desc119.putList( idkerningRange, list22 );
                  desc118.putObject( idT, idTxLr, desc119 );
              executeAction( idsetd, desc118, DialogModes.NO );
              var idslct = charIDToTypeID( "slct" );
                  var desc146 = new ActionDescriptor();
                      var ref22 = new ActionReference();
                      var idLyr = charIDToTypeID( "Lyr " );
                      ref22.putName( idLyr, "Background" );
                  desc146.putReference( idnull, ref22 );
                  var idMkVs = charIDToTypeID( "MkVs" );
                  desc146.putBoolean( idMkVs, false );
              executeAction( idslct, desc146, DialogModes.NO );
