My Flash is out of date, downloading latest installer (v.16) and running it goes fine until 97% when it just hangs. I'm on a MacBook Pro, running OSX10.10.1 and have been through the help pages, even uninstalled Flash and started over and nothing changes. I've read through similar threads but none of them seem to address this problem and nothing suggested seems to work
Hello,
Please try using the full installer, posted at the bottom of the Installation problems | Flash Player | Mac page, in the 'Still having problems' section.
Maria
Hello
Yes have tried that too and it gets to 95% and just hang there as well...
Please post your installation logs:
Where do I find the Flash Player installation log on the Macintosh?
2013-02-07 21:19:47 +0000 ---------- log start ----------
2013-02-07 21:19:47 +0000 [install started]
dyld: DYLD_ environment variables being ignored because main executable (/System/Library/PrivateFrameworks/Install.framework/Resources/runner) is setuid or setgid
installer: Package name is PlugIn
installer: Installing at base path /
installer: The install was successful.
sudo: no tty present and no askpass program specified
2013-02-07 21:19:58 +0000 [install completed]
2013-02-07 21:20:00 +0000 ---------- log end ----------
2013-02-07 21:20:00 +0000 Changing update mode to 1
2013-02-16 17:51:48 +0000 ---------- log start ----------
2013-02-16 17:51:49 +0000 1214
2013-02-16 17:51:52 +0000 ---------- log end ----------
2013-02-24 09:11:31 +0000 ---------- log start ----------
2013-02-24 09:11:31 +0000 1214
2013-02-24 09:11:43 +0000 ---------- log end ----------
2013-03-04 19:25:24 +0000 ---------- log start ----------
2013-03-04 19:25:24 +0000 1214
2013-03-04 19:25:30 +0000 ---------- log end ----------
2013-03-22 08:24:05 +0000 ---------- log start ----------
2013-03-22 08:24:06 +0000 1214
2013-03-22 08:24:12 +0000 ---------- log end ----------
2013-04-26 16:52:00 +0000 ---------- log start ----------
2013-04-26 16:52:00 +0000 All install checks pass
2013-04-26 16:52:01 +0000 [install started]
installer: Upgrading at base path /
installer: The upgrade was successful.
2013-04-26 16:52:13 +0000 [install completed]
2013-04-26 16:52:15 +0000 ---------- log end ----------
2013-04-26 16:52:15 +0000 Changing update mode to 0
2013-05-17 10:06:33 +0000 ---------- log start ----------
2013-05-17 10:06:33 +0000 All install checks pass
2013-05-17 10:06:34 +0000 [install started]
2013-05-17 10:06:45 +0000 [install succeeded]
2013-05-17 10:06:46 +0000 ---------- log end ----------
2013-07-15 10:47:43 +0000 ---------- log start ----------
2013-07-15 10:47:43 +0000 1213
2013-07-15 19:46:04 +0000 ---------- log end ----------
2013-07-26 16:23:41 +0000 ---------- log start ----------
2013-07-26 16:23:41 +0000 1213
2013-07-26 16:23:42 +0000 1213
2013-07-26 16:23:46 +0000 ---------- log end ----------
2013-08-07 08:00:59 +0000 ---------- log start ----------
2013-08-07 08:00:59 +0000 1213
2013-08-07 08:01:04 +0000 ---------- log end ----------
2013-08-15 14:42:15 +0000 ---------- log start ----------
2013-08-15 14:42:15 +0000 1213
2013-08-15 14:42:19 +0000 ---------- log end ----------
2013-11-18 21:29:09 +0000 ---------- log start ----------
2013-11-18 21:29:09 +0000 1389
2013-11-18 21:29:16 +0000 ---------- log end ----------
2013-11-26 16:52:06 +0000 ---------- log start ----------
2013-11-26 16:52:06 +0000 1389
2013-11-26 16:52:07 +0000 1389
2013-11-26 16:52:11 +0000 ---------- log end ----------
2013-12-03 18:21:28 +0000 ---------- log start ----------
2013-12-03 18:21:28 +0000 1389
2013-12-03 18:21:29 +0000 1389
2013-12-03 18:21:57 +0000 ---------- log end ----------
2013-12-10 19:58:11 +0000 ---------- log start ----------
2013-12-10 19:58:11 +0000 1389
2013-12-11 10:58:42 +0000 18417494
2013-12-11 10:58:42 +0000 verifySignatureWithData : Message Verified!
2013-12-11 10:58:47 +0000 ---------- log end ----------
2013-12-11 10:58:51 +0000 ---------- log start ----------
2013-12-11 10:58:51 +0000 All install checks pass
2013-12-11 10:59:00 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-12-11 10:59:09 +0000 ---------- log end ----------
2014-01-03 17:11:02 +0000 ---------- log start ----------
2014-01-03 17:11:02 +0000 All install checks pass
2014-01-03 17:11:11 +0000 [install started]
2014-01-03 17:11:22 +0000 [install succeeded]
2014-01-03 17:11:22 +0000 ---------- log end ----------
2014-01-16 16:32:21 +0000 ---------- log start ----------
2014-01-16 16:32:22 +0000 1386
2014-01-16 16:32:24 +0000 ---------- log end ----------
2014-02-04 17:46:43 +0000 ---------- log start ----------
2014-02-04 17:46:43 +0000 1386
2014-02-04 17:46:44 +0000 1386
2014-02-04 17:46:49 +0000 ---------- log end ----------
2014-02-04 17:49:06 +0000 IM: ---------- log start ----------
2014-02-04 17:49:06 +0000 IM: All install checks pass
2014-02-04 17:49:08 +0000
2014-02-04 17:49:08 +0000 IM: ---------- log end ----------
2014-02-04 17:49:21 +0000 IM: ---------- log start ----------
2014-02-04 17:49:21 +0000 IM: All install checks pass
2014-02-04 17:49:23 +0000 IM: User does not have any processes that need to be closed.
2014-02-04 17:49:23 +0000 IM: [install started]
2014-02-04 17:49:32 +0000 FIN: [finalizer started]
2014-02-04 17:49:32 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-04 17:49:32 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-04 17:49:33 +0000 FIN: [finalizer succeeded]
installer: Package name is Adobe Flash Player
2014-02-04 17:49:39 +0000 IM: [install succeeded]
2014-02-04 17:49:39 +0000 IM: ---------- log end ----------
2014-02-21 16:40:09 +0000 IM: ---------- log start ----------
2014-02-21 16:40:09 +0000 IM: All install checks pass
2014-02-21 16:40:09 +0000 IM: [install started]
2014-02-21 16:40:12 +0000 FIN: [finalizer started]
2014-02-21 16:40:12 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-21 16:40:12 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-21 16:40:13 +0000
2014-02-21 16:40:15 +0000 IM: [install succeeded]
2014-02-21 16:40:15 +0000 IM: ---------- log end ----------
2014-02-24 10:14:30 +0000
2014-02-27 15:46:26 +0000 IM: ---------- log start ----------
2014-02-27 15:46:26 +0000 IM: 1386
2014-02-27 15:46:27 +0000 IM: 1386
2014-02-27 15:46:30 +0000 IM: ---------- log end ----------
2014-03-01 14:00:35 +0000
2014-03-01 23:41:39 +0000
2014-03-02 00:50:47 +0000
2014-03-02 06:39:03 +0000
2014-03-04 10:19:11 +0000
2014-03-12 12:59:07 +0000 IM: ---------- log start ----------
2014-03-12 12:59:07 +0000 IM: All install checks pass
2014-03-12 12:59:07 +0000 IM: [install started]
2014-03-12 12:59:10 +0000 FIN: [finalizer started]
2014-03-12 12:59:10 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-03-12 12:59:10 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-03-12 12:59:11 +0000
2014-03-12 12:59:13 +0000 IM: [install succeeded]
2014-03-12 12:59:13 +0000 IM: ---------- log end ----------
2014-03-24 02:37:09 +0000
2014-03-28 14:17:55 +0000
2014-03-28 15:28:34 +0000
2014-03-31 05:58:20 +0100
2014-04-06 17:05:26 +0100
2014-04-11 13:36:33 +0100 IM: ---------- log start ----------
2014-04-11 13:36:33 +0100 IM: 1387
2014-04-11 13:36:39 +0100 IM: ---------- log end ----------
2014-04-16 21:02:37 +0100
2014-04-17 07:01:16 +0100
2014-04-17 09:44:53 +0100 IM: ---------- log start ----------
2014-04-17 09:44:53 +0100 IM: All install checks pass
2014-04-17 09:44:53 +0100 IM: [install started]
2014-04-17 09:44:56 +0100 FIN: [finalizer started]
2014-04-17 09:44:56 +0100 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-17 09:44:56 +0100 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-17 09:44:58 +0100
2014-04-17 09:45:00 +0100 IM: [install succeeded]
2014-04-17 09:45:00 +0100 IM: ---------- log end ----------
2014-04-18 18:01:21 +0100 IM: ---------- log start ----------
2014-04-18 18:01:21 +0100 IM: 1387
2014-04-18 18:01:22 +0100 IM: 1387
2014-04-18 18:01:25 +0100 IM: ---------- log end ----------
2014-04-29 15:40:39 +0100 IM: ---------- log start ----------
2014-04-29 15:40:39 +0100 IM: All install checks pass
2014-04-29 15:40:39 +0100 IM: [install started]
2014-04-29 15:40:41 +0100 FIN: [finalizer started]
2014-04-29 15:40:41 +0100 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-29 15:40:41 +0100 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-29 15:40:43 +0100
2014-04-29 15:40:45 +0100 IM: [install succeeded]
2014-04-29 15:40:45 +0100 IM: ---------- log end ----------
2014-05-07 13:56:46 +0100
2014-05-14 14:17:01 +0100 IM: ---------- log start ----------
2014-05-14 14:17:01 +0100 IM: All install checks pass
2014-05-14 14:17:01 +0100 IM: [install started]
2014-05-14 14:17:04 +0100 FIN: [finalizer started]
2014-05-14 14:17:04 +0100 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-05-14 14:17:04 +0100 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-05-14 14:17:05 +0100
2014-05-14 14:17:08 +0100 IM: [install succeeded]
2014-05-14 14:17:08 +0100 IM: ---------- log end ----------
2014-05-21 09:52:19 +0100
2014-05-29 22:34:03 +0100
2014-05-29 23:34:02 +0100
2014-05-31 04:51:52 +0100
2014-06-03 17:25:43 +0100
2014-06-11 10:03:30 +0100 IM: ---------- log start ----------
2014-06-11 10:03:30 +0100 IM: 1387
2014-06-11 10:03:36 +0100 IM: ---------- log end ----------
2014-06-15 19:58:16 +0100
2014-06-15 20:58:18 +0100
2014-06-18 12:34:14 +0100 IM: ---------- log start ----------
2014-06-18 12:34:14 +0100 IM: 1387
2014-06-18 12:34:15 +0100 IM: 1387
2014-06-18 12:40:22 +0100 IM: ---------- log end ----------
2014-06-21 12:55:58 +0100
2014-06-25 04:00:15 +0100
2014-06-25 14:42:49 +0100 IM: ---------- log start ----------
2014-06-25 14:42:49 +0100 IM: 1387
2014-06-25 14:42:50 +0100 IM: 1387
2014-06-25 14:42:52 +0100 IM: ---------- log end ----------
2014-07-02 18:00:58 +0100 IM: ---------- log start ----------
2014-07-02 18:00:58 +0100 IM: 1387
2014-07-02 18:00:59 +0100 IM: 1387
2014-07-03 08:42:57 +0100
2014-07-03 09:51:06 +0100 IM: ---------- log end ----------
2014-07-09 11:31:03 +0100 IM: ---------- log start ----------
2014-07-09 11:31:03 +0100 IM: All install checks pass
2014-07-09 11:31:03 +0100 IM: [install started]
2014-07-09 11:31:07 +0100 FIN: [finalizer started]
2014-07-09 11:31:07 +0100 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-07-09 11:31:07 +0100 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-07-09 11:31:08 +0100
2014-07-09 11:31:10 +0100 IM: [install succeeded]
2014-07-09 11:31:10 +0100 IM: ---------- log end ----------
2014-07-11 10:02:58 +0100 IM: ---------- log start ----------
2014-07-11 10:02:58 +0100 IM: All install checks pass
2014-07-11 10:03:29 +0100
2014-07-11 10:03:29 +0100 IM: ---------- log end ----------
2014-07-11 10:04:42 +0100 IM: ---------- log start ----------
2014-07-11 10:04:42 +0100 IM: All install checks pass
2014-07-11 10:04:44 +0100
2014-07-11 10:04:44 +0100 IM: ---------- log end ----------
2014-07-11 10:05:19 +0100 IM: ---------- log start ----------
2014-07-11 10:05:19 +0100 IM: All install checks pass
2014-07-11 10:05:21 +0100 IM: User does not have any processes that need to be closed.
2014-07-11 10:05:21 +0100 IM: [install started]
2014-07-11 10:05:25 +0100 FIN: [finalizer started]
2014-07-11 10:05:25 +0100 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-07-11 10:05:25 +0100 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-07-11 10:05:26 +0100 FIN: [finalizer succeeded]
2014-07-11 10:05:33 +0100 IM: [install succeeded]
2014-07-11 10:05:33 +0100 IM: ---------- log end ----------
2014-08-14 01:22:36 +0100
2014-08-16 15:38:06 +0100 IM: ---------- log start ----------
2014-08-16 15:38:06 +0100 IM: 1407
2014-08-16 15:38:07 +0100 IM: 1407
2014-08-16 15:38:12 +0100 IM: ---------- log end ----------
2014-08-27 09:23:11 +0100 IM: ---------- log start ----------
2014-08-27 09:23:11 +0100 IM: 1407
2014-08-27 09:23:12 +0100 IM: 1407
2014-08-27 09:23:26 +0100 IM: ---------- log end ----------
2014-09-03 21:51:08 +0100
2014-09-06 04:19:36 +0100
2014-09-06 14:18:59 +0100 IM: ---------- log start ----------
2014-09-06 14:18:59 +0100 IM: 1407
2014-09-07 20:17:00 +0100 IM: ---------- log end ----------
2014-09-09 19:54:22 +0100 IM: ---------- log start ----------
2014-09-09 19:54:22 +0100 IM: All install checks pass
2014-09-09 19:54:22 +0100 IM: [install started]
2014-09-09 19:54:25 +0100 FIN: [finalizer started]
2014-09-09 19:54:25 +0100 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-09-09 19:54:25 +0100 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-09-09 19:54:26 +0100
2014-09-09 19:54:29 +0100 IM: [install succeeded]
2014-09-09 19:54:29 +0100 IM: ---------- log end ----------
2014-09-10 08:12:51 +0100
2014-09-10 09:13:22 +0100
2014-09-15 10:49:18 +0100
2014-09-23 04:45:12 +0100
2014-10-04 21:04:47 +0100
2014-10-17 16:28:11 +0100
2014-10-20 14:43:06 +0100 IM: ---------- log start ----------
2014-10-20 14:43:06 +0100 IM: 1407
2014-10-20 14:43:07 +0100 IM: 1407
2014-10-20 14:43:09 +0100 IM: ---------- log end ----------
2014-10-27 07:57:17 +0000
2014-10-27 08:59:47 +0000
2014-10-27 09:09:25 +0000 IM: ---------- log start ----------
2014-10-27 09:09:25 +0000 IM: All install checks pass
2014-10-27 09:09:58 +0000
2014-10-27 09:09:58 +0000 IM: ---------- log end ----------
2014-10-27 09:10:08 +0000 IM: ---------- log start ----------
2014-10-27 09:10:08 +0000 IM: All install checks pass
2014-10-27 09:10:09 +0000 IM: User does not have any processes that need to be closed.
2014-10-27 09:10:09 +0000 IM: [install started]
2014-10-27 09:10:12 +0000 FIN: [finalizer started]
2014-10-27 09:10:12 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-10-27 09:10:12 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-10-27 09:10:14 +0000 FIN: [finalizer succeeded]
2014-10-27 09:10:20 +0000 IM: [install succeeded]
2014-10-27 09:10:20 +0000 IM: ---------- log end ----------
2014-10-27 12:21:07 +0000
2014-10-27 13:21:07 +0000
2014-10-27 14:21:07 +0000
2014-11-12 10:47:43 +0000 IM: ---------- log start ----------
2014-11-12 10:47:43 +0000 IM: All install checks pass
2014-11-12 10:47:43 +0000 IM: [install started]
2014-11-12 10:47:46 +0000 FIN: [finalizer started]
2014-11-12 10:47:46 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-11-12 10:47:46 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-11-12 10:47:47 +0000
2014-11-12 10:47:49 +0000 IM: [install succeeded]
2014-11-12 10:47:49 +0000 IM: ---------- log end ----------
2014-11-14 13:47:13 +0000
2014-11-16 17:30:38 +0000
2014-11-26 10:40:47 +0000 IM: ---------- log start ----------
2014-11-26 10:40:47 +0000 IM: All install checks pass
2014-11-26 10:40:47 +0000 IM: [install started]
2014-11-26 10:41:47 +0000
2014-11-26 14:14:50 +0000 IM: ---------- log start ----------
2014-11-26 14:14:50 +0000 IM: 1407
2014-11-26 14:14:57 +0000 IM: 15638837
2014-11-26 14:15:01 +0000 IM: ---------- log end ----------
2014-11-26 14:15:07 +0000 IM: ---------- log start ----------
2014-11-26 14:15:07 +0000 IM: All install checks pass
2014-11-26 14:15:14 +0000
2014-11-26 14:15:25 +0000 IM: [install started]
2014-11-28 09:57:29 +0000 IM: ---------- log start ----------
2014-11-28 09:57:29 +0000 IM: All install checks pass
2014-11-28 09:57:29 +0000 IM: [install started]
2014-11-28 09:58:30 +0000
2014-11-29 23:49:08 +0000
2014-12-01 12:25:46 +0000 IM: ---------- log start ----------
2014-12-01 12:25:46 +0000 IM: All install checks pass
2014-12-01 12:25:46 +0000 IM: [install started]
2014-12-01 12:26:46 +0000
2014-12-02 13:17:21 +0000 IM: ---------- log start ----------
2014-12-02 13:17:21 +0000 IM: All install checks pass
2014-12-02 13:17:21 +0000 IM: [install started]
2014-12-02 13:18:21 +0000
2014-12-03 14:09:45 +0000 IM: ---------- log start ----------
2014-12-03 14:09:45 +0000 IM: All install checks pass
2014-12-03 14:09:45 +0000 IM: [install started]
2014-12-03 14:10:45 +0000
2014-12-03 21:36:30 +0000 IM: ---------- log start ----------
2014-12-03 21:36:30 +0000 IM: 1407
2014-12-03 21:37:41 +0000 IM: 15638837
2014-12-03 21:37:45 +0000 IM: ---------- log end ----------
2014-12-03 21:37:50 +0000 IM: ---------- log start ----------
2014-12-03 21:37:50 +0000 IM: All install checks pass
2014-12-03 21:38:01 +0000
2014-12-03 21:38:13 +0000 IM: [install started]
2014-12-04 15:08:18 +0000
2014-12-05 11:01:01 +0000 IM: ---------- log start ----------
2014-12-05 11:01:01 +0000 IM: All install checks pass
2014-12-05 11:01:01 +0000 IM: [install started]
2014-12-05 11:02:01 +0000
2014-12-08 10:22:53 +0000 IM: ---------- log start ----------
2014-12-08 10:22:53 +0000 IM: All install checks pass
2014-12-08 10:22:53 +0000 IM: [install started]
2014-12-08 10:23:53 +0000
2014-12-08 11:23:49 +0000
2014-12-08 12:23:49 +0000
2014-12-08 13:23:49 +0000
2014-12-08 14:23:49 +0000
2014-12-08 15:23:49 +0000
2014-12-08 16:23:49 +0000
2014-12-08 20:00:12 +0000
2014-12-09 10:11:23 +0000
2014-12-09 11:44:17 +0000
2014-12-09 16:01:20 +0000
2014-12-09 17:01:20 +0000
2014-12-09 20:18:46 +0000
2014-12-10 10:00:33 +0000
2014-12-10 11:00:33 +0000
2014-12-10 12:00:33 +0000
2014-12-10 13:00:33 +0000
2014-12-10 14:00:33 +0000
2014-12-10 17:53:09 +0000
2014-12-11 11:01:30 +0000
2014-12-11 11:10:15 +0000 IM: ---------- log start ----------
2014-12-11 11:10:15 +0000 IM: 1387
2014-12-11 11:10:20 +0000 IM: ---------- log end ----------
2014-12-11 12:01:31 +0000
2014-12-11 13:01:31 +0000
2014-12-11 14:01:31 +0000
2014-12-11 15:01:31 +0000
2014-12-11 16:01:31 +0000
2014-12-12 10:23:24 +0000
2014-12-12 11:23:19 +0000
2014-12-12 12:23:19 +0000
2014-12-15 10:58:08 +0000
2014-12-15 11:58:08 +0000
2014-12-15 12:58:04 +0000
2014-12-15 13:58:04 +0000
2014-12-15 14:58:04 +0000
2014-12-15 15:58:04 +0000
2014-12-15 21:13:36 +0000
2014-12-15 22:13:36 +0000
2014-12-16 10:10:38 +0000
2014-12-16 11:10:39 +0000
2014-12-16 12:10:39 +0000
2014-12-16 13:10:39 +0000
2014-12-16 14:10:40 +0000
2014-12-16 16:51:25 +0000
2014-12-16 19:05:19 +0000
2014-12-16 20:12:37 +0000
2014-12-16 21:12:37 +0000
2014-12-17 14:24:09 +0000
2014-12-18 10:29:33 +0000
2014-12-18 11:29:33 +0000
2014-12-18 12:29:33 +0000
2014-12-18 13:29:33 +0000
2014-12-18 14:17:47 +0000 IM: ---------- log start ----------
2014-12-18 14:17:48 +0000 IM: 1387
2014-12-18 14:17:53 +0000 IM: ---------- log end ----------
2014-12-18 14:29:33 +0000
2014-12-18 15:29:33 +0000
2014-12-18 16:29:33 +0000
2014-12-18 18:57:46 +0000
2014-12-20 08:16:10 +0000
2014-12-20 09:16:10 +0000
2014-12-21 20:16:50 +0000
2014-12-22 11:08:32 +0000
2014-12-23 18:27:29 +0000
2014-12-27 15:19:24 +0000
2014-12-27 16:19:24 +0000
2014-12-29 11:20:38 +0000
2014-12-29 15:05:11 +0000
2014-12-29 15:22:47 +0000 IM: ---------- log start ----------
2014-12-29 15:22:47 +0000 IM: All install checks pass
2014-12-29 15:22:48 +0000
2014-12-29 15:22:48 +0000 IM: ---------- log end ----------
2014-12-29 15:23:04 +0000 IM: ---------- log start ----------
2014-12-29 15:23:04 +0000 IM: All install checks pass
2014-12-29 15:23:04 +0000 IM: User does not have any processes that need to be closed.
2014-12-29 15:23:04 +0000 IM: [install started]
2014-12-29 15:28:27 +0000 IM: ---------- log start ----------
2014-12-29 15:28:27 +0000 IM: All install checks pass
2014-12-29 15:28:27 +0000 IM: User does not have any processes that need to be closed.
2014-12-29 15:28:27 +0000 IM: [install started]
2015-01-01 22:26:31 +0000
2015-01-02 16:10:05 +0000
2015-01-02 17:39:28 +0000
2015-01-02 22:01:50 +0000
2015-01-03 11:43:43 +0000
2015-01-04 19:38:26 +0000
2015-01-04 20:38:26 +0000
2015-01-05 12:34:17 +0000
2015-01-05 13:34:18 +0000
2015-01-05 14:45:15 +0000
2015-01-05 18:06:46 +0000
2015-01-05 18:23:30 +0000 IM: ---------- log start ----------
2015-01-05 18:23:30 +0000 IM: All install checks pass
2015-01-05 18:23:31 +0000
2015-01-05 18:23:31 +0000 IM: ---------- log end ----------
2015-01-05 18:23:39 +0000 IM: ---------- log start ----------
2015-01-05 18:23:39 +0000 IM: All install checks pass
2015-01-05 18:23:39 +0000 IM: User does not have any processes that need to be closed.
2015-01-05 18:23:39 +0000 IM: [install started]
2015-01-06 10:14:32 +0000
2015-01-06 11:14:32 +0000
2015-01-06 12:14:32 +0000
2015-01-06 13:14:32 +0000
2015-01-06 14:14:32 +0000
2015-01-06 14:19:42 +0000 IM: ---------- log start ----------
2015-01-06 14:19:42 +0000 IM: All install checks pass
2015-01-06 14:19:42 +0000 IM: User does not have any processes that need to be closed.
2015-01-06 14:19:42 +0000 IM: [install started]
2015-01-06 14:27:11 +0000 IM: ---------- log start ----------
2015-01-06 14:27:11 +0000 IM: All install checks pass
2015-01-06 14:27:12 +0000
2015-01-06 14:27:12 +0000 IM: ---------- log end ----------
2015-01-06 14:27:24 +0000 IM: ---------- log start ----------
2015-01-06 14:27:24 +0000 IM: All install checks pass
2015-01-06 14:27:24 +0000 IM: User does not have any processes that need to be closed.
2015-01-06 14:27:24 +0000 IM: [install started]
2015-01-06 14:55:41 +0000 IM: ---------- log start ----------
2015-01-06 14:55:48 +0000 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2015-01-06 14:55:48 +0000 IM: Uninstall Started
2015-01-06 14:55:48 +0000 IM: [uninstall start]
2015-01-06 14:55:48 +0000 IM: user authorized
2015-01-06 14:55:48 +0000 IM: [file removal start]
2015-01-06 14:55:49 +0000 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-01-06 14:55:49 +0000 IM: Removed file: '/Library/Internet Plug-Ins/Flash Player.plugin'
2015-01-06 14:55:49 +0000 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-01-06 14:55:49 +0000 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-01-06 14:55:49 +0000 IM: Removed file: '/Library/Internet Plug-Ins/flashplayer.xpt'
2015-01-06 14:55:49 +0000 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-01-06 14:55:49 +0000 IM: Did not find file '/Users/frizbeeretina/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-01-06 14:55:49 +0000 IM: Did not find file '/Users/frizbeeretina/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-01-06 14:55:49 +0000 IM: Did not find file '/Users/frizbeeretina/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-01-06 14:55:49 +0000 IM: Did not find file '/Users/frizbeeretina/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-01-06 14:55:49 +0000 IM: Did not find file '/Users/frizbeeretina/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-01-06 14:55:49 +0000 IM: Did not find file '/Users/frizbeeretina/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-01-06 14:55:49 +0000 IM: Removed file: '/Library/LaunchDaemons/com.adobe.fpsaud.plist'
2015-01-06 14:55:49 +0000 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2015-01-06 14:55:49 +0000 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml'
2015-01-06 14:55:49 +0000 IM: Did not find bundle receipt to remove.
2015-01-06 14:55:55 +0000 IM: Removed file: '/Library/PreferencePanes/Flash Player.prefPane'
2015-01-06 14:55:55 +0000 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-01-06 14:55:55 +0000 IM: [file removal end]
2015-01-06 14:55:55 +0000 IM: [uninstall end]
2015-01-06 14:55:55 +0000 IM: Uninstall Ended
2015-01-06 14:55:58 +0000 IM: ---------- log end ----------
2015-01-06 14:56:54 +0000 IM: ---------- log start ----------
2015-01-06 14:56:54 +0000 IM: All install checks pass
2015-01-06 14:56:54 +0000 IM: User does not have any processes that need to be closed.
2015-01-06 14:56:54 +0000 IM: [install started]
2015-01-06 15:18:52 +0000 IM: ---------- log start ----------
2015-01-06 15:18:52 +0000 IM: All install checks pass
2015-01-06 15:18:52 +0000 IM: User does not have any processes that need to be closed.
2015-01-06 15:18:52 +0000 IM: [install started]
2015-01-06 15:34:42 +0000 IM: ---------- log start ----------
2015-01-06 15:34:42 +0000 IM: All install checks pass
2015-01-06 15:34:42 +0000 IM: User does not have any processes that need to be closed.
2015-01-06 15:34:42 +0000 IM: [install started]
2015-01-06 17:33:57 +0000 IM: ---------- log start ----------
2015-01-06 17:33:57 +0000 IM: All install checks pass
2015-01-06 17:34:04 +0000
2015-01-06 17:34:15 +0000 IM: [install started]
Hope this is what you need
Unfortunately, the logs look normal, except that if that's the end of the log, it looks like the installer just hangs. There's no obvious culprit here. My guess is that this is happening because something unexpected is failing due to an underlying issue with the filesystem, and we're either not getting an error back when it happens, or it's something totally unexpected that we don't handle.
Is your hard disk named something sane? It will get displayed when you go into the Disk Utility (instructions below). The only thing I've run into like this recently was a guy who's hard disk name was corrupted after an OS upgrade, and we didn't like the huge list of esoteric characters in the disk name. I see that the uninstaller is unable to find a bunch of files, so that *might* be what's happening, but there's nothing that clearly points to a problem in the log.
I'd recommend that you sanity-check the filesystem, then retry installing using the offline installer in Safe Mode, which should minimize any potential for conflicts:
Run First-Aid on the disks using Disk Utility:
How to verify and repair your hard disk in OS X | MacIssues
Boot into Safe Mode:
Thanks for that, sorry this is proving to be quite frustrating and this route was the only Support route offered when I went through the contact Adobe section on the site. I'll try your recommendations and see what happens.
Thanks again.
Well, ran Disk Utilities and verified, repaired everything but it didn't actually throw up any errors, ran installer in safe mode as well as the specific installer for Safari and same problems - Install v.16 hangs at 97, Safari at 95 and then isn't responding when have to Force Quit the installers as quitting them doesn't work. My hard drive is named Macintosh HD so don't think that is an issue.
I have seen this problem flagged up in a bunch of other forums on the Adobe site so don't think it is unique to my mac, so not sure what else to do here - appreciate any suggestions or at least knowing what it is looking for (you mentioned the logs said it was trying to find some things during the installation).
Are you using the offline installer?
http://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player_osx.dmg
Yes - this is the situation in safe mode
Try deleting all of these locations by hand, and then running the installer:
If that doesn't work, please give me the recent output of ~/Library/Logs/FlashPlayerInstallManager.log again. Maybe we'll get something more useful.
Hi
Ok so NONE of those files were in those folders, I had run Uninstaller before based on something I found on another forum so possibly why? And the Installer log wasn't there either but do have a Logistic Report of the hang. It is a huge file so not sure how to get it to you or if you want it?
Yeah, I'm not sure what's going on. My hope was that one or more of those files was corrupted and couldn't be overwritten, which was why the install was failing, but it sounds like it's just unable to copy the files into the locations they need to be in, and there's not a lot of information about why.
The log file (/Users/<you>/Library/Logs/FlashPlayerInstallManager.log) should tell you what's failing, but if you that's not getting created either, then I don't have a lot of clues.
