2 Replies Latest reply on Mar 19, 2007 8:32 AM by
    Preloaders in Form Application
      This is my first time using Form Application so please help
      I can't seem to get my preloader to work in a Flash Form Application. Are there any tricks to getting them to work properly?
      Basically all it does is flash the preload frame after everything is loaded.
        • 1. Re: Preloaders in Form Application
          2m Level 2
          Here's an excerpt form the Flash help-files:
          About using preloaders with screen-based documents
          If you want to include a preloader (a separate SWF file that loads your primary SWF) with your screen-based document, one way to do this is to create the preloader as a separate SWF file (non-screen-based), and load the SWF file for the screen-based document from within the preloader SWF.
          You cannot create a preloader within a screen-based document, because all screens in a document are located on the first frame of the root Timeline, so you cannot call or load other frames
          • 2. Re: Preloaders in Form Application
            I gave this a try but when the primary SWF loads it can only see the initial display and none of the buttons work.
            Are there any examples of using a preloader with screen based flash documents that anyone knows of that I can get a look at?
