1 2 Previous Next 46 Replies Latest reply on Jul 11, 2017 12:29 PM by Paul SLS
    Issue: color print not true
    paulmegan
      Lightroom 5.7 (Updated from 5.5 after the problem below--no help)
      Windows 7
      Epson 2400 Photo Stylus Printer
      Photoshop elements 10
      New problem after using Lightroom for several years
      Working with bright red flower photo.  Color management set to profile for premium luster paper
      Preview and print come out magenta.
      Same photo in Photoshop Elements 10 previews and prints fine.
        • 1. Re: Issue: color print not true
          RikkFlohr Adobe Community Professional
          Magenta is a sign of double profiling. Have Lightroom or the Printer manage the colors but not both.  If Lightroom, turn off color management in your Windows print driver. If the printer. Set your LR Print Job Panel to have the Printer Manage Colors.
          • 2. Re: Issue: color print not true
            paulmegan Level 1
            ""Lightroom 5.7 (Updated from 5.5 after the problem below--no help)
            Windows 7
            Preview and print come out magenta (Flower turns from red to magenta)
            Same photo in Photoshop Elements 10 previews and prints fine.""
            I get unusual color shifts when printing from LR 5.7 to Epson 2400.  I have
            tried all combinations of setting for color management in both devices (
            letting the printer control the color or letting LR control the color).
            Sometimes reds go to magenta, sometimes to brown, the yellows are not true
            either. I use Inkpress ICCs but even epson or HP ICCs have the same
            problem.
            Photoshop elements10, when set to printer controlling the colors, does
            fine, and even windows photo viewer does pretty well when sent to the epson
            printer.
            As far as I can tell, this problem began after I went from LR 4 to LR 5
            several weeks ago--today was the first time I actually used the new LR 5
            • 3. Re: Issue: color print not true
              paulmegan Level 1
              Thanks--after a lot of fiddling with both Photoshop Elements and LR 5 The
              answer seems to be to use the color management setting in LR 5 that is
              Stylus Photo R2400, but I still cannot get good colors when I use ICC
              Profiles listed in LR 5 specific to any of my (common) papers.  Color
              management is OFF in the printer.
              I am now about 1/2 way good to go.
              • 4. Re: Issue: color print not true
                You will also need to verify that Windows Color Management is off if you wish to let Lightroom Manage the colors. It works great btw, if you make sure everything else is turned off Color Management-wise.
                • 5. Re: Issue: color print not true
                  web-weaver Level 5
                  Maybe this helps:
                  There seems to be an odd behavior in Lr that shows up - sometimes - when you have custom printing presets that were created in prior versions of Lr.
                  I had the same thing happen recently: After printing from Lr for a long time flawlessly, after the update to Lr 5.6 my prints came out with a magenta cast. I don't have an Epson printer, so it's not an issue between Lr and Epson printers. First thing I checked is double color management. Nope, that wasn't it.
                  Then I remembered an old thread on this forum where this problem was discussed. The solution was to remove all custom printing presets from Lr.
                  I moved via my OS all my custom printing presets to a different folder so that Lr won't be able to find them.
                  Immediately the problem of the magenta cast  was gone and printing was fine.
                  • 6. Re: Issue: color print not true
                    paulmegan Level 1
                    I have wandered around the Color Management choice in Control panel (Win7)
                    and done some Google searches--I do not understand how or what it means to
                    turn off Windows Color Management--appreciate the help for this old duffer
                    who wrote his first Fortran program in 1967 but can't seem to figure this
                    out even if I "RTFM".  The whole color thing is clearly (or unclearly)
                    complex!
                    • 7. Re: Issue: color print not true
                      You aren't trying to turn off color management in Windows. When in the print module in Lightroom, you need to go to the "Page Setup" button in the lower left-hand corner of the screen. This will open your printer driver dialogue. Somewhere in that dialogue you can turn off color management. By doing so, that will enable Lightroom to effectively manage the colors sent to the printer. If you don't turn off color management in the printer, and to let Lightroom manage colors as well, then you have double color management and that is going to throw your colors off. If you cannot find where to turn off color management in the printer driver then you need to choose the option in Lightroom to let the printer manage the colors. If you do that, and your printer uses paper profiles, then you need to choose the appropriate profile in the printer driver.
                      It's probably easier to allow Lightroom to manage the colors. But you must turn off color management in the printer driver in order for this to work properly.
                      • 8. Re: Issue: color print not true
                        paulmegan Level 1
                        Thanks: the following is long because I want to make clear what I am doing
                        The page setup button in LR leads to same page as the setup ( printer
                        driver) for the Epson and it is set to No color management.
                        Lightroom is set to use the profile included in the list of supplied
                        profiles (such as Luster, glossy etc) that is labeled Stylus Photo R2400
                        (my Epson model), there are no paper types associated with this choice,
                        unlike the other choices in the profile list stored in LR.
                        I am getting good printer color output with these settings--perhaps this is
                        all I need to do and forget about other color profiles. When using
                        Photoshop Elements, I use the ICC Profile for the paper I am using, with
                        good results. When I tell LR 5.7 to use a specific paper profile, such as
                        Luster, the colors are screwed up at the printer (often magenta tints). I
                        am making the profile selection in LR when in the Print module under Print
                        Job and then select the profile from the list in the "Other" selection. The
                        printer driver setup is set to Luster as paper type, (paper type seems a
                        required input), even though Color Management is turned off at the
                        printer--do you suppose that by selecting Luster in Lightroom that I am
                        actually double managing the color?
                        Bottom line: With he Epson Stylus Pro R2400 profile selected in LR, the
                        paper type set at whatever I am using in the Printer Driver, and printer
                        color mangement OFF,  I get what appears to be good output but I haven't
                        experimented with other paper types.  I cannot select a specific paper type
                        profile (ICC) in LR and get good result--perhaps the paper type is taken
                        care of by the Stylus Photo R2400 profile selected in LR and setting paper
                        type profile (rather than the profile Stylus Photo R2400 )  in LR causes
                        the LR setting and the Printer setup to trip over each other.
                        Perhaps it time to forge ahead with what seems to work and use other art
                        papers, etc to see what happens.
                        Thanks for listening (reading)
                        • 9. Re: Issue: color print not true
                          paulmegan Level 1
                          See my recent lengthy reply--sounds like your removal of the custom presets
                          is equivalent to my not selecting  custom presets in LR--
                          Somehow the use of the custom presets in LR can somehow screw up the color
                          management.
                          • 10. Re: Issue: color print not true
                            Even though you turn off color management in the printer, it is still necessary to choose the appropriate paper type in the printer driver. You probably already know that, but I'm just mentioning it as another checkpoint to ensure you are doing everything right.
                            • 11. Re: Issue: color print not true
                              paulmegan Level 1
                              I appreciate your advice--I think I finally understand what has been
                              happening
                              Basically, on the lightroom side of things I should not set the paper type
                              profile--this is done ONLY on the printer side and with some further
                              experiments a few minutes ago, it appears LR detects the paper type I
                              select in the Printer and responds accordingly with good output.  If I
                              select a specific paper profile in LR, then the colors are wrong--
                              I am a happy camper after too many hours messing with this--on with the
                              printing project that started this issue.
                              • 12. Re: Issue: color print not true
                                Well, I still think something is not right. I use a Canon printer, and I use Canon and Red River paper. When I choose to use Red River paper and allow Lightroom to manage the color, I still have to go to the printer driver (Page Setup) and choose the type of paper that the Red River instructions tell me to choose. Then, in Lightroom, I choose the profile for the exact paper ( a profile that I downloaded from the Red River website) that I'm using. And I get very good matches on my prints.
                                • 13. Re: Issue: color print not true
                                  paulmegan Level 1
                                  I agree it does not seem right that I cannot put in the downloaded profile
                                  from InkPress into LR and get a good result.  I will try some things and
                                  appreciate it if I can get back to the forum after a few more experiments.
                                  The prints I made this afternoon are fine in the settings I mentioned in
                                  the posts, but perhaps they could be better.
                                  • 14. Re: Issue: color print not true
                                    paulmegan Level 1
                                    I cannot figure out why I cannot use color profiles.  Turns out I have the
                                    same problem in Photoshop elements.  To summarize again:
                                    Devices etc:
                                    Windows 7 on a Dell quadcore desktop (5 years old)
                                    Lightroom 5.7
                                    Epson Stylus Photo Pro R2400 (about 7 years old--drivers updated
                                    today--probably the original ones that came with it))
                                    I have been using Lightroom since ver 3 and Elements since ver 6  with same
                                    printer all the time and not had this happen before.
                                    If I set the printer to no color management and choose a paper (such as
                                    Inkpress Luster) in the printer page setup
                                    and if I set either Photoshop or Lightroom to control color via the proper
                                    profile for the selected paper, I get magenta instead of red, and some
                                    other funky color changes as well in either of the programs.
                                    If I choose an option in the profiles list which appears to be kind of
                                    generic for the printer and use this in either Lightroom or Photoshop, I
                                    get good prints and by the changes in print speed depending on the choices
                                    I make, it seems that the printer and the software are communicating.  I
                                    can't get ICC profiles for different papers to work in either program--? a
                                    printer issue in using the ICC information?
                                    Screen shots as follows:
                                    see notes BELOW each photo
                                    Original photo of Sierra Snowplant--actually more crimson than even seen
                                    here
                                    First of 3 pix of printer settings
                                    Second page of printer settings
                                    Last page of printer settings showing Color adjustment OFF
                                    Lightroom setting in Print Module
                                    With these settings I get what appears to be an accurate paper print of the
                                    original pix
                                    BUT.......
                                    With the same printer settings and the lightroom settings shown
                                    Then I select the downloaded ICC profile for my paper
                                    and I get this result when printing
                                    and..if I allow the printer manage colors I get this ugly rendition
                                    I have no idea what I am doing wrong--it is likely operator error, as
                                    usual, but can anyone spot what is going wrong??
                                    • 15. Re: Issue: color print not true
                                      None of your pictures posted. In order to include pictures you have to do it by using the forum interface. Photos will not post through e-mail or phone. Here's a suggestion. Have Lightroom let the printer manage the colors. Then choose the paper type and the paper profile in the printer driver. I have done it both ways using my printer, and I get excellent results either way.
                                      • 16. Re: Issue: color print not true
                                        paulmegan Level 1
                                        I would like to solve the mysteries in my system, just because "it should
                                        work!".  I am able to print with some settings, so I can still work.
                                        The suggestion to work in Lightroom with printer managing color produces an
                                        ugly brown rather than the crimson of the original and it matters not what
                                        settings I use on the printer setup page--
                                        If I let LR control color, then some settings (which I think are the
                                        overarching settings for the printer) work OK but paper specific profiles
                                        turn crimson to magenta.
                                        Elements behaves differently: I get reasonable prints with any settings
                                        when the printer controls (unlike LR) but when the program controls color
                                        some settings have the magenta shift in the red range (the whole print is
                                        NOT washed in magenta--just color changes  in the reds) and others print
                                        OK--and the aberrancies are the same as what happens in LR with the same
                                        settings--i.e. LR and Elements screw up the same way for the same settings
                                        when Program controls color.
                                        I will probably continue to obsess about this but life and time are short,
                                        so unless someone has some magical ideas, I will disappear into the digital
                                        haze--maybe buy a new printer (?Canon)
                                        • 17. Re: Issue: color print not true
                                          Modesto Vega Level 1
                                          The Epson Stylus Photo R2400, assuming we are talking about the same printer, is a good printer, I wouldn't just buy a new printer just for this (and I know is a frustrating issue).
                                          Where did you get the paper profiles from? What happens if you soft proof using the paper profiles? Do you get gamut warnings? Sorry if all of this has been asked before.
                                          Also are you on version 5.7.1 and not on 5.7. 5.7.1 is the latest? It is a long shot but you never know.
                                          • 18. Re: Issue: color print not true
                                            paulmegan Level 1
                                            Most of the profiles from which I can choose appear to have been included
                                            with the printer setup, named such as SPR2400 Premium Glossy or SPR2400
                                            Premium Luster.  One choice from the profile list is just SPR2400 with no
                                            other info and this works when LR controls color.  Other paper profiles
                                            that I have downloaded include 2 from Inkpress for their Luster and their
                                            Pro Silky paper--I still get the results described with these,i.e. If
                                            Printer controls color then the Crimson of the Sierra snowplant becomes an
                                            ugly brown.  If LR controls then I get a magenta.  That is to say, I cannot
                                            seem to use specific paper profiles in either mode but can get OK prints if
                                            I use LR controls and select the SPR2400 setting mentioned above--in fact
                                            this is the only way I can get a decent print either with LR controls or
                                            Printer controls.
                                            LR version under Help is 5.7 but if I go to adobe to check updates am told
                                            I am current.
                                            Also I tested soft proof with LR controls color and the Inkpress Luster
                                            profile.  No real issues--I get some minor gamut warnings if I turn
                                            contrast to 100% but otherwise no warnings.
                                            Based on what I noted earlier about what happens in Elements and LR, it
                                            suggests a printer issue to me, but the printer will put out good quality
                                            with some settings, so the hardware is OK
                                            BTW  Google Sierra Snowplant==a beautiful early spring alpine flower found
                                            just 8 km from my house near Reno Nevada at 2000 meters elevation.
                                            On Fri, Jan 9, 2015 at 11:10 AM, Modesto Vega <forums_noreply@adobe.com>
                                            • 19. Re: Issue: color print not true
                                              Just googled Sierra Snowplant, it is indeed beautiful and can also see how some of those tones could cause some trouble when printing.
                                              It also seems that, perhaps not surprisingly, you are not the 1st one to have this problem, I just came across this post How to use SPR2400 profiles?: Printers and Printing Forum: Digital Photography Review (I googled SPR2400). My guess is that the profile cannot handle that colour.
                                              1. When you set the profile under Color Manager to Manage by Printer, are you actually changing the printer on the advanced settings to "Color Management: Color Controls"?
                                              2. When you set the profile under Color Manager to the paper profile, are you actually changing the printer on the advanced settings to "Color Management: ICM, ICC/ICM Profile: Off, and Paper: to whatever paper your using?
                                              Sorry, there are basic questions. I am sure you are. If you are setting the LR and the printer as described in point 2, what do you choose for Print Resolution, Media Type, Intent, Print Adjustments.
                                              • 20. Re: Issue: color print not true
                                                paulmegan Level 1
                                                If I tell LR to manage color then I tell Printer to not manage color by
                                                selection ICM then checking Color management off so that all profile
                                                choices are grayed out.  If I tell LR to have the printer manage color then
                                                I choose the ICM button and choose the Input profile as sRGB (default) and
                                                the printer profile as the Paper profile from a menu list ( or the SPR2400
                                                profile with nothing else attached which does usually work).  As noted
                                                previously, with some settings ( LR manages color with the SPR2400 profile
                                                selection and the advanced printer settings are ICM checked and no color
                                                management selected)  then I get a reasonable rendition of the photo, hence
                                                the printer seems able to reproduce to crimson color.  The problem occurs
                                                when instead of this mysterious SPR2400 selection from the profile list, I
                                                use a specific paper profile that the color of the plant turns from crimson
                                                to magenta.
                                                Also having the printer manage color never works with any settings I have
                                                tried (2 hours of marching through the printer setup choices--always ugly
                                                brown rather than crimson plant.)
                                                BTW this problem is not exclusive this plant photo--I have a snowcat
                                                tractor at a ski area that is an orange color and it turns a reddish purple
                                                when I tell LR to use specific paper profiles (printer color control off),
                                                and when I set the Printer to control the color and use any paper profile,
                                                I get the same ugly brown instead of the orange.  I get a good print if LR
                                                controls color and the profile selection is that SPR2400 with no paper name
                                                attached.  Something seems to be tripping over something else but ????
                                                On Fri, Jan 9, 2015 at 2:17 PM, Modesto Vega <forums_noreply@adobe.com>
                                                • 21. Re: Issue: color print not true
                                                  SPR2400 is a generic printer profile, paper independent. I think the problem is with the paper profiles which probably have a problem handling orangish and reddish colours.
                                                  The only 2 ways I can think to confirm this is to create a printer profile for your printer and type of paper or to use some other lustre paper, like Red River, they have profiles available for r2400. If you get the same problem with other paper, I think is hardware/software problem. If you don't it is the profiles. The best option would give you better results.
                                                  • 22. Re: Issue: color print not true
                                                    paulmegan Level 1
                                                    I finally figured out how to get pictures into the forum:
                                                    Original image to be printed via LR5
                                                    Image with LR5 set to Printer controls color and Printer set to any choice of Paper type with input as sRGB:
                                                    Print with LR5 set to control color with any paper profile choice in the list --choice of profile does not matter as results are all the same:
                                                    Finally, print with LR5 controlling color but profile in LR set to
                                                    SPR2400  choice from the defaults available that came with printer:
                                                    • 23. Re: Issue: color print not true
                                                      Where is this sRGB Input profile coming from? I don't understand that. You shouldn't be using any input profiles. You should turn color management off in the printer, but choose the paper type according to the instructions that are with your paper or that you got from the website. There is no input profile. The only profile you need to worry about is the paper. As an example, I use a Canon Pixma Pro-100. If I decide to print on Red River UltraPro glossy paper these are the steps:
                                                      1. Go to page setup in the Lightroom print module and turn off color management.
                                                      2. In the paper type (in the printer driver) I choose Photo Paper Plus Glossy II, as instructed by the Red River sheet.
                                                      3. Next, make sure I have selected the appropriate paper size and quality in the printer driver.
                                                      4. In Lightroom, in the print module, color management, I choose the Red River profile for UltraPro Glossy paper.
                                                      That gets everything set the way it needs to be done, and I get good prints. There is nothing anywhere about an input profile. Lightroom doesn't use sRGB, But that doesn't matter.
                                                      I don't know if this will help at all. But you have got an extra step in there somewhere that is throwing things off for your printing.
                                                      • 24. Re: Issue: color print not true
                                                        paulmegan Level 1
                                                        I will try the Red River idea tonight: Please see the photos I added to the thread--I just figured out how to get these pix into the forum
                                                        Thanks--(I am a 70 yo duffer who wrote his first Fortran program in 1967 but programming and manipulating computer products are 2 different animals)
                                                        • 25. Re: Issue: color print not true
                                                          Could I suggest trying something else? Try printing https://forums.adobe.com/servlet/JiveServlet/showImage/2-7082389-714300/Color+printed+with +specific+ICC+for+Inkpress+Lus… , which I understand was printed using the paper profile, to JPEG, exact same steps but to JEPG.
                                                          If the profile is wrong it should look the image you posted. If there is an issue with the printer, it should look fine. I'll check the thread tomorrow.
                                                          • 26. Re: Issue: color print not true
                                                            paulmegan Level 1
                                                            I downloaded the Red River Luster profiles for the R2400.  They recommend
                                                            that I choose Premium Luster as the paper type in the Advanced printer
                                                            setup, which I have been using anyway.
                                                            Results unchanged in both Elements and LR5--the abnormal results are not
                                                            the same in both programs but there are abnormal results, again to
                                                            reiterate:
                                                            If Lightroom Controls color--all paper choices produce the magenta shift
                                                            except the SPR2400 profile choice that came with the printer, then color
                                                            looks OK--also see comment below about the stray profile when monitor was
                                                            calibrated--this works OK as well
                                                            If LR5 used but printer controls color--all choices produce the ugly brown,
                                                            including the
                                                            SPR2400
                                                            • 27. Re: Issue: color print not true
                                                              paulmegan Level 1
                                                              As far as I can tell, I am doing as you outline.  To use LR as color
                                                              manager, I select a paper profile on the Print module page in the area
                                                              where one can also choose to have Printer control color if one wants, and I
                                                              go to page setup and turn off printer color management, in my printer this
                                                              is a button for ICM and a check box for No color management--after this all
                                                              the choices such as Input and printer setup etc are grayed out. I also
                                                              enter the paper type in the Page setup.
                                                              You asked about the sRGB as input profile--that is seen only if I have
                                                              asked the Printer to manage color,
                                                              • 28. Re: Issue: color print not true
        Okay, I misunderstood part of what you were saying. Do you have specific paper profiles for the specific paper you are using?
        • 29. Re: Issue: color print not true
        paulmegan Level 1
        Here are screen shots of what my LR5 setup to have LR contol color look like.  Hopefully this will help with my trying to communicate what I am doing.
        The profile is from Red River for their Luster and they suggest on the website that in the printer I choose Ultra Premium Luster as paper type.
        Lightroom setup
        Then under Page Setup for the printer, the first level is:
        Then after clicking Properties one sees:
        Then under Advanced one sees:
        As far as I can tell, this setting with ICM checked and the No color Correction box checked is the only way I can turn of printer color management.  The other radio buttons do not have an option to turn off printer color management--I've tried them all.
        • 30. Re: Issue: color print not true
        I wish I knew what to tell you. What you have selected looks right to me. On another forum, someone who knows a lot more about printing than I do has stated on numerous occasions that Epson and the Mac don't cooperate as well as they should. I don't know anything more about it than that.
        • 31. Re: Issue: color print not true
        paulmegan Level 1
        Yes.  I have profiles for Inkpress Luster and Pro Silky,  and RR luster (as
        part of the experiment to try to figure out where this issue is coming from.
        I also just posted screen shots of how I have things set up in LR.
        • 32. Re: Issue: color print not true
        paulmegan Level 1
        Thanks for tryingMac is not and issueusing Win 7
        • 33. Re: Issue: color print not true
        Yeah, don't know what I was thinking.
        • 34. Re: Issue: color print not true
        paulmegan Level 1
        Do you mean I should print the original without intervention by lightroom? I printed it using Windows Picture Manager and the Epson printer and the colors are OK. The linked picture in your reply is a screenshot of the print preview of an attempt to print the crimson image using LR controlling color   with the specific Inkpress profile for the selected Luster paper. The paper print looks the same as the preview i.e. magenta
        To quote:
        “Curiouser and curiouser!” Cried Alice (she was so much surprised, that for the moment she quite forgot how to speak good English).”
        1. Print of the original photo to the Epson printer using Windows Picture Manager (which I presume has no intrinsic color control but leaves all to the printer). I am asked to select a paper type but have no other printer control such as profile selection (although again I presume selecting the Luster paper selects that profile intrinsic in the printer)===result is crimson flower like the original.
        2. From Lightroom with setting Printer Controls Color and paper selected as Luster in printer page setup and Printer NOT set to ICM but just to the radio button for Color Control (choices seen on one of the screen shots I posted yesterday) I get the ugly brown .  BUT if I choose ICM and then choose a specific profile such as RR Luster or Inkpress Luster I STILL GET THE SAME UGLY BROWN
        3 In Lightroom, If I choose to have LR control the color and choose a paper specific profile with the printer set to no color correction, I get magenta BUT if the choice in Lightroom is not a specific color profile but the apparently generic SPR2400 , then I get crimson.
        4. Just to add to the confusion, in Photoshop Elements, Setting to Printer Controls Color and using a paper profile in the printer page setup such as Inkpress Luster, I do not get the ugly brown seen with the same settings in LR, I get a good crimson of the original.
        In example 3 above, setting the paper TYPE to Luster and then choosing ICM with the same paper type profile might be a double correction ? In the same setting choosing SPR2400 as the profile may not apply a double correction and I get good color
        But what about he fact that the same settings in Elements and LR when Printer Controls color produce different results--ugly brown in LR and original crimson in Elements.
        I am a fan of BBC mysteries, Agatha Christie,  Poirot etc, so perhaps he should be summoned??
        This is one of those computer issues that is not intrinsically important--not my livelihood at stake, but just like a coding bug-Why Won't it Work (and it used to).
        The machine I use for photo editing and printing is not used for much of anything else and has only had upgrades to LR, the antivirus program, java and such
        I have considered doing a system restore to several months back but I have never had a system restore work on this machine and am reluctant to try again.
        Lots of words but precision in description is difficult to achieve..
        • 35. Re: Issue: color print not true
        Could please confirm that this an accurate summary of your problem? Sorry I know I am going back to basics but I am just looking for a straight yes/no answer, please only give more details if they answer is no.
        1) You have a photo in the Development module looking like
        2) When you go into the Print module, choose any of the papers profiles mentioned in this thread the printer turns out this (which is obviously incorrect)
        3) The image you are printing is JPG image and not a raw image
        • 36. Re: Issue: color print not true
        paulmegan Level 1
        Yes to all 3 , reiterating that in the print module the selection is for LR
        to control color and a paper profile is selected (doesn't matter which
        one--same magenta output)  and printer color control  is off
        On Sat, Jan 10, 2015 at 11:06 AM, Modesto Vega <forums_noreply@adobe.com>
        • 37. Re: Issue: color print not true
        What are your brightness and contrast settings under Print Adjustment?
        • 38. Re: Issue: color print not true
        paulmegan Level 1
        I have left Print Adjustment turned off in my examples in the thread,
        although I did experiment with changing the settings a few times--made no
        difference in the outcome
        On Sat, Jan 10, 2015 at 11:28 AM, Modesto Vega <forums_noreply@adobe.com>
        • 39. Re: Issue: color print not true
        The only thing I can think of is that something either Lightroom or the printer is turning the Brightness up. If you look at the print, the dry gras is too bright, brighter than the photo. If something is turning the Brightness up, perhaps even the Contrast, then the colour of the crimson will be too bright and no longer the original colour.
        If it turn out that nothing is turning the Brightness up, I am at a loss. What you are seeing should not be happening?
        1 2 Previous Next
