6 Replies Latest reply on Jan 7, 2015 12:31 AM by hamdifem
    within a text frame linked in the text frame remove
    hamdifem Level 1
      in a document finding the linked text frames
      get out of text (two lines) and I want to delete a text frame
      Is it possible that a command letter
        • 1. Re: within a text frame linked in the text frame remove
          Chinnadk Level 4
          Try this,
          var doc = app.activeDocument;
          app.findGrepPreferences = app.changeGrepPreferences = null;
          app.findGrepPreferences.findWhat = "~a";
          var found = doc.findGrep();
          for(var i =found.length-1;i>=0;i--)
                  var ip = found[i].insertionPoints[0];
                  if(found[i].allPageItems[0].lines.length == 2)
                          app.findGrepPreferences.findWhat = "\\r";
                          app.changeGrepPreferences.changeTo = "";
                          found[i].allPageItems[0].texts[0].changeGrep();
                          found[i].allPageItems[0].texts[0].duplicate(LocationOptions.AFTER,ip);
                          found[i].remove();
          Regards,
          Chinna
          • 2. Re: within a text frame linked in the text frame remove
            hamdifem Level 1
            great
            upper case character style bottom case another character style
            Can we apply
            • 3. Re: Re: within a text frame linked in the text frame remove
              Chinnadk Level 4
              Try this,
                              var cont = found[i].allPageItems[0].texts[0].duplicate(LocationOptions.AFTER,ip);
                              cont.characters[0].appliedCharacterStyle = doc.characterStyles.item("my character style 1");
                              cont.characters[1].appliedCharacterStyle = doc.characterStyles.item("my character style 2");
                              found[i].remove();
              Regards,
              Chinna
              • 4. Re: within a text frame linked in the text frame remove
                @Chinna – be aware, that your code will break, if you'll find a different object than a text frame with your inital GREP search. ~a could be any object you can anchor: rectangles, ovals, polygons, MSOs etc. (also: text frames).
                Often objects that have no texts property.
                Uwe
                • 5. Re: within a text frame linked in the text frame remove
                  hamdifem Level 1
                  together add "\"
                  cause of the error
                                  app.findGrepPreferences.findWhat = "(\\d)(\\r)(\\d)";
                                  app.changeGrepPreferences.changeTo = "$1$3";   // $1\\$3  ??
                                  cont.texts[0].insertionPoints.item(1).contents = "\\"; \\ ??
                                  found[i].remove();
                  • 6. Re: within a text frame linked in the text frame remove
                    hamdifem Level 1
                    How can I change second character
