4 Replies Latest reply on Jan 7, 2015 7:14 AM by jeichar7
    Exporting as an XML file never works CS6
    jeichar7
      I am trying to export the timeline as an XML file in order to color correct in a different program. Every time I export it gets stuck with a status bar and stays there until I have to force quit Premiere (attached is an image of where I get stuck). I am using Yosemite with adobe CS6. How can I get this export to work!?Screen Shot 2015-01-06 at 3.50.04 PM.png
        • 1. Re: Exporting as an XML file never works CS6
          Kevin-Monahan Adobe Employee
          Hi Jeichar7,
          Have you updated to the latest version of Premiere Pro CS6 (6.0.4 or 6.0.5)?
          Kevin
          • 2. Re: Exporting as an XML file never works CS6
            jeichar7 Level 1
            Hey Kevin,
            Thanks for the response, but I am fully up to date 6.0.5 and still having the issue.
            • 3. Re: Exporting as an XML file never works CS6
              Hi Jeichar7,
              Thanks for the info. Can you test with a new project with a short sequence of clips?
              Kevin
              • 4. Re: Exporting as an XML file never works CS6
                jeichar7 Level 1
                Ok tested with a new project and now I am getting a different issue:
                I have looked at the results and this is what it shows:
                "Translation issue:
                  Sequence <Anna> at 00:02:08:00, audio track 3: Effect <Internal Channel Volume Stereo> on Clip <MONO-023.wav> not translated.
                Translation issue:
                  Sequence <Anna> at 00:02:25:21, audio track 1: Effect <Internal Channel Volume Stereo> on Clip <664A6306.MOV> not translated.
                Translation issue:
                  Sequence <Anna> at 00:02:27:11, audio track 2: Effect <Internal Channel Volume Stereo> on Clip <080A7924.MOV> not translated.
                Translation issue:
                  Sequence <Anna> at 00:08:25:13, audio track 1: Effect <Internal Channel Volume Stereo> on Clip <664A6307.MOV> not translated.
                Translation issue:
                  Sequence <Anna> at 00:11:52:07, audio track 1: Effect <Internal Channel Volume Stereo> on Clip <664A6307.MOV> not translated.
                Translation issue:
                  Sequence <Anna> at 00:12:06:07, audio track 1: Effect <Internal Channel Volume Stereo> on Clip <664A6307.MOV> not translated."
                and that goes on for about 20 more lines...
