5 Replies Latest reply on Jan 7, 2015 11:39 AM by Chris Cox
    Photoshop CC will not open files from within the program. Says cannot complete due to a program error. WTF!?
    Kolohe_Boy
      Every time I open photoshop CC, and try to open a file from the File Open menu it pops up window that says Cannot Complete Request Due To A Program Error. All the other functions of the program work fine including saving files I just cannot open files. I have to use bridge to open anything. illustrator CC is doing this as well except it does not pop up with an error message, it just doesn't do anything when trying to open a file or use the place command. I also cannot relink images in Illustrator. Any help would be super. Im on a mac with Yosemite installed. The CC programs are the very latest downloads as well. Im using a mac system at home with Yosemite and it works just fine but this problem is happening on my work system Mac.
        • 1. Re: Photoshop CC will not open files from within the program. Says cannot complete due to a program error. WTF!?
          SG... Adobe Employee
          Can you quit Ps and just after relaunching hold down the shift key? This should pop a dialog asking if you want to skip loading optional plug-ins. Click Yes and see if that changes the behavior. If it does then we need to isolate the plug-in that's problematic.
          regards,
          steve
          • 2. Re: Photoshop CC will not open files from within the program. Says cannot complete due to a program error. WTF!?
            Kolohe_Boy Level 1
            Tried the shift key, clicked on yes. No change in the program error. The tech help folks online suggested I created a new user account on the computer, which I can do but it will be a bit of a pain since I will have to reset up all my network drives and email etc. Not the most techie type person here, I just do the art!
            • 3. Re: Photoshop CC will not open files from within the program. Says cannot complete due to a program error. WTF!?
              The tech suggestion is to just create a new account for checking the Ps behavior. If it changes the behavior then we has more data on where to suggest changes to your existing account.
              Can you also go to Help> System Info... and paste that info into a response here?
              regards,
              steve
              • 4. Re: Photoshop CC will not open files from within the program. Says cannot complete due to a program error. WTF!?
                Kolohe_Boy Level 1
                Adobe Photoshop Version: 2014.2.2 20141204.r.310 2014/12/04:23:59:59 CL 994532  x64
                Operating System: Mac OS 10.10.1
                System architecture: Intel CPU Family:6, Model:60, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
                Physical processor count: 4
                Processor speed: 3400 MHz
                Built-in memory: 32768 MB
                Free memory: 23550 MB
                Memory available to Photoshop: 30875 MB
                Memory used by Photoshop: 82 %
                3D Multitone Printing: Disabled.
                Windows 2x UI: Disabled.
                Highbeam: Disabled.
                Image tile size: 1024K
                Image cache levels: 2
                Font Preview: Medium
                TextComposer: Latin
                Display: 1
                Main Display
                Display Bounds: top=0, left=0, bottom=1440, right=2560
                OpenGL Drawing: Enabled.
                OpenGL Allow Old GPUs: Not Detected.
                OpenGL Drawing Mode: Advanced
                OpenGL Allow Normal Mode: True.
                OpenGL Allow Advanced Mode: True.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGLGPUs=1
                NumCLGPUs=1
                glgpu[0].GLVersion="2.1"
                glgpu[0].GLMemoryMB=2048
                glgpu[0].GLName="NVIDIA GeForce GTX 775M OpenGL Engine"
                glgpu[0].GLVendor="NVIDIA Corporation"
                glgpu[0].GLVendorID=4318
                glgpu[0].GLRectTextureSize=16384
                glgpu[0].GLRenderer="NVIDIA GeForce GTX 775M OpenGL Engine"
                glgpu[0].GLRendererID=16918308
                glgpu[0].HasGLNPOTSupport=1
                glgpu[0].CanCompileProgramGLSL=1
                glgpu[0].GLFrameBufferOK=1
                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
                glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                clgpu[0].CLPlatformVersion="1.2 (Sep 20 2014 22:01:02)"
                clgpu[0].CLDeviceVersion="1.2 "
                clgpu[0].CLMemoryMB=2048
                clgpu[0].CLName="GeForce GTX 775M"
                clgpu[0].CLVendor="NVIDIA"
                clgpu[0].CLVendorID=16918272
                clgpu[0].CLDriverVersion="10.0.43 310.41.05f01"
                clgpu[0].CUDASupported=0
                clgpu[0].CLBandwidth=4.37958e+10
                clgpu[0].CLCompute=96.0176
                License Type: Subscription
                Serial number: 90970220150825315370
                Application folder: /Applications/Adobe Photoshop CC 2014/
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  Startup, 930.7G, 722.3G free
                Required Plug-ins folder: /Applications/Adobe Photoshop CC 2014/Adobe Photoshop CC 2014.app/Contents/Required/Plug-Ins/
                Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2014/Plug-ins/
                Installed components:
                   adbeape.framework   adbeape   3.4.0.29366   0.1160850
                   AdbePM.framework   AdbePM   2.2.00.32695   79.558079
                   AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.32394   79.550992
                   adobe_caps.framework   adobe_caps   8.0.0.13   1.248010
                   AdobeACE.framework   AdobeACE   2.20.02.33308   79.557478
                   AdobeAGM.framework   AdobeAGM   4.30.41.33308   79.557478
                   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.32260   79.551013
                   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.32260   79.551013
                   AdobeBIB.framework   AdobeBIB   1.2.03.33308   79.557478
                   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.557478
                   AdobeCoolType.framework   AdobeCoolType   5.15.00.33308   79.557478
                   AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
                   AdobeExtendScript.framework   AdobeExtendScript   4.5.5.32401   79.551519
                   AdobeJP2K.framework   AdobeJP2K   1.2.2.33078   79.254012
                   AdobeLinguistic.framework      20256
                   AdobeMPS.framework   AdobeMPS   5.8.1.33340   79.557676
                   AdobeOwl.framework   AdobeOwl   5.2.4
                   AdobePDFL.framework   AdobePDFL   11.0.0.33336   79.512424
                   AdobePDFSettings.framework   AdobePDFSettings   1.4
                   AdobePIP.framework   AdobePIP   7.2.1.3399
                   AdobeScCore.framework   AdobeScCore   4.5.5.32401   79.551519
                   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                   AdobeXMP.framework   AdobeXMPCore   79.156797   79.156797
                   AdobeXMPFiles.framework   AdobeXMPFiles   79.156797   79.156797
                   AdobeXMPScript.framework   AdobeXMPScript   79.156797   79.156797
                   ahclient.framework   ahclient   1.8.0.31
                   aif_core.framework   AdobeAIF   2014.0.00   2014.0
                   aif_ocl.framework   AdobeAIF   2014.0.00   2014.0
                   aif_ogl.framework   AdobeAIF   2014.0.00   2014.0
                   amtlib.framework   amtlib   8.0.0.122
                   boost_date_time.framework   boost_date_time   8.0.0.0
                   boost_signals.framework   boost_signals   8.0.0.0
                   boost_system.framework   boost_system   8.0.0.0
                   boost_threads.framework   boost_threads   8.0.0.0
                   Cg.framework   NVIDIA Cg
                   CIT.framework   CIT   2.2.6.32411   155804
                   CITThreading.framework   CITThreading_boost   2.2.6.32411   155804
                   dvaaudiodevice.framework   dvaaudiodevice   8.0.0.0
                   dvacore.framework   dvacore   8.0.0.0
                   dvamarshal.framework   dvamarshal   8.0.0.0
                   dvamediatypes.framework   dvamediatypes   8.0.0.0
                   dvametadata.framework   dvametadata   8.0.0.0
                   dvametadataapi.framework   dvametadataapi   8.0.0.0
                   dvametadataUI.framework   dvametadataUI   8.0.0.0
                   dvaplayer.framework   dvaplayer   8.0.0.0
                   dvatransport.framework   dvatransport   8.0.0.0
                   dvaui.framework   dvaui   8.0.0.0
                   dvaunittesting.framework   dvaunittesting   8.0.0.0
                   dynamiclink.framework   dynamiclink   8.0.0.0
                   ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                   ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                   LogSession.framework   LogSession   7.2.1.3399
                   mediacoreif.framework   mediacoreif   8.0.0.0
                   PlugPlugExternalObject.framework      5.0.0.62
                   PlugPlugOwl.framework   PlugPlugOwl   5.2.0.54
                   UpdaterNotifications.framework   UpdaterNotifications   8.0.0.14   "8.0.0.14"
                   WRServices.framework
                Required plug-ins:
                   3D Studio 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Accented Edges 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Adaptive Wide Angle 15.2.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                   Angled Strokes 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Average 2014.2.2 x001 x003  ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
                   Bas Relief 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   BMP 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Camera Raw 8.7.1 (311), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Camera Raw Filter 8.7.1 (311), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                   Chalk & Charcoal 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Chrome 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Cineon 2014.2.2 x001 x003  ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
                   Clouds 2014.2.2 x001 x003  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                   Collada DAE 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Color Halftone 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Colored Pencil 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   CompuServe GIF 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Conté Crayon 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Craquelure 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Crop and Straighten Photos 2014.2.2 x001 x003  ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                   Crop and Straighten Photos Filter 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Crosshatch 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Crystallize 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Cutout 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Dark Strokes 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   De-Interlace 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Dicom 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
                   Difference Clouds 2014.2.2 x001 x003  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                   Diffuse Glow 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Displace 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Dry Brush 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Eazel Acquire 2014.2.2 x001 x003  ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                   Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                   Entropy 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Export Color Lookup Tables 2014.2.2 x001 x003  �2012-2014 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                   Extrude 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   FastCore Routines 2014.2.2 x001 x003  ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
                   Fibers 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Film Grain 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Filter Gallery 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Flash 3D 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Fresco 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Glass 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Glowing Edges 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Google Earth 4 KMZ 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Graphic Pen 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Halftone Pattern 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   HDRMergeUI 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                   HSB/HSL 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   IFF Format 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   IGES 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Ink Outlines 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   JPEG 2000 2014.2.2 x001 x003  ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                   Kurtosis 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Lens Blur 15.2.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                   Lens Correction 15.2.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                   Lens Flare 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Liquify 15.2.2, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
                   Matlab Operation 2014.2.2 x001 x003  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                   Maximum 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Mean 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Measurement Core 2014.2.2 x001 x003  ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                   Median 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Mezzotint 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Minimum 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   MMXCore Routines 2014.2.2 x001 x003  ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                   Mosaic Tiles 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Multiprocessor Support 2014.2.2 x001 x003  ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                   Neon Glow 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Note Paper 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   NTSC Colors 2014.2.2 x001 x003  ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                   Ocean Ripple 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   OpenEXR 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Paint Daubs 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Palette Knife 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Patchwork 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Paths to Illustrator 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   PCX 2014.2.2 x001 x003  ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
                   Photocopy 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Photoshop 3D Engine 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                   Photoshop Touch CC 2014 (15.2.2.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
                   Picture Package Filter 2014.2.2 x001 x003  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                   Pinch 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Pixar 2014.2.2 x001 x003  ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
                   Plaster 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Plastic Wrap 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   PLY 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   PNG 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Pointillize 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Polar Coordinates 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Portable Bit Map 2014.2.2 x001 x003  ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
                   Poster Edges 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   PRC 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Radial Blur 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Radiance 2014.2.2 x001 x003  ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
                   Range 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Read Watermark NO VERSION - from the file “DigiRead.plugin”
                   Render Color Lookup Grid 2014.2.2 x001 x003  �2012-2014 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                   Reticulation 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Ripple 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Rough Pastels 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Save for Web 15.2.2, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                   ScriptingSupport 15.2.2, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                   Shake Reduction 15.2.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                   Shear 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Skewness 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Smart Blur 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Smudge Stick 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Solarize 2014.2.2 x001 x003  ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
                   Spatter 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Spherize 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Sponge 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Sprayed Strokes 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Stained Glass 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Stamp 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Standard Deviation 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   STL 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Sumi-e 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Summation 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Targa 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Texturizer 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Tiles 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Torn Edges 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Twirl 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   U3D 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Underpainting 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Vanishing Point 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                   Variance 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                   Virtual Reality Modeling Language | VRML 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Water Paper 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Watercolor 15.2.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                   Wave 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Wavefront|OBJ 2014.2.2 x001 x003  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                   Wind 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                   Wireless Bitmap 2014.2.2 x001 x003  ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
                   ZigZag 15.2.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                Optional and third party plug-ins: NONE
                Plug-ins that failed to load: NONE
                Flash:
                   Libraries
                   Adobe Color Themes
                Installed TWAIN devices: NONE
                • 5. Re: Photoshop CC will not open files from within the program. Says cannot complete due to a program error. WTF!?
                  Level 7
                  In the OS open dialog, try changing the view to list view then opening the file.
