1 Reply Latest reply on Mar 5, 2007 8:09 PM by ggshow
    change stage dimensions with script
    shueardm Level 1
      Is there a way to change the stage dimesions with a script please? Relates to another post below which I can't figure out.
        • 1. Re: change stage dimensions with script
          ggshow Level 2
          stage width & height properties are read only, you cant change the stage size by using actionscript.
          if you are displaying an swf object on a webpage, you may consider to change the swf object width & height parameters using javascript, & make sure your scaleMode is showAll.
          good luck
