0 Replies Latest reply on Jan 7, 2015 5:56 PM by Pooja.Mittal@kpit.com
    Passing the webservice url in execute button synamically
    Pooja.Mittal@kpit.com Level 1
      I am using Data connection from the wsdl file to interact with the backend, the button generated from the data connection is of type execute which has the url of the webservice in the object property "Webservice URL" and name of the FM in the interface name. My problem is at present the form is working fine but when the same form transported to QA and PRD them the url of the webservice gets change. hence the same button wont function.
      The solution is either we do the changes manually in all the system or pass the url at run time. Please proide me the solution if there is a way to set this url in the execute button at runtime.
      Thanks in advance.
      Pooja
