2 Replies Latest reply on Jan 24, 2015 7:50 AM by BKBK
    Problems Installing Coldfusion 11 with Yosemite
    bobcel
      I have just installed Yosemite and updated from Coldfusion 10 to 11.  At present, I have two problems for which I can find no answers:
      The first, when trying to access the CF Administrator (http://localhost:8500/CFIDE/administrator/index.cfm), I get this error:
      The Graphing service is not available.
      This exception is usually caused by service startup failure. Check your server configuration.
      The error occurred in C:/work/cf10_final_hotfix/cfusion/wwwroot/CFIDE/administrator/Application.cfm: line 95
      Called fromC:/work/cf10_final_hotfix/cfusion/wwwroot/CFIDE/administrator/Application.cfm: line 85
      Called fromC:/work/cf10_final_hotfix/cfusion/wwwroot/CFIDE/administrator/Application.cfm: line 4
      Called fromC:/work/cf10_final_hotfix/cfusion/wwwroot/CFIDE/administrator/Application.cfm: line 1
      This problem may have originated after downloading and installing the ColdFusion 11 Update 3 hotfix.
      And second, when trying to access a web page on my local host, I get this error:
      Error Executing Database Query.
      No suitable driver available for gzc, please check the driver setting in resources file, error: com.mysql.jdbc.Driver
      I used the migration tool when updating from CF10 to CF11.  MySQL is running okay.  I cannot get to the datasources page in the CF Administrator until the first issue is resolved.
      Thanks for your help!
