12 Replies Latest reply on Mar 9, 2007 9:00 AM by Newsgroup_User
    convert utf-8 to iso-8859-1
    Level 7
      Hello,
      sorry for my very bad english
      i use httpxmlrequest to answer a database and show resultin a div
      the string means utf-8 encoded by my javascript fonction and, of course,
      no result are found in the database.
      How can i convert the string to iso-8859-1 before request the database ?
      Thank if you have an idea
      JiBé (France)
        • 1. Re: convert utf-8 to iso-8859-1
          BKBK Adobe Community Professional & MVP
          What happens when you put
          <cfscript>
          SetEncoding("url", "iso-8859-1");
          </cfscript>
          <cfprocessingdirective pageencoding="iso-8859-1">
          at the top of the Coldfusion page?
          • 2. Re: convert utf-8 to iso-8859-1
            Level 7
            I do that in the application.cfm page
            I just have this problem with httpxmlrequest
            So i want to convert my string before use it in the SQL
            JiBé
            > <cfscript>
            > </cfscript>
            • 3. Re: convert utf-8 to iso-8859-1
              Level 7
              well you might not be able to as iso-8859-1 is a subset of unicode. what
              languages are you dealing with? are you sure they will fit into iso-8859-1? i
              guess maybe have a look at this:
              http://www.phillipholmes.com/?p=46
              • 4. Re: convert utf-8 to iso-8859-1
                Level 7
                PaulH **AdobeCommunityExpert** a écrit :
                Maybe it is more simple with an example :
                http://habitat-developpement.tm.p15.siteinternet.com/test/
                If you seach energie it works...
                If oyu search énergie there is no result because it search "énergie"...
                Jibé
                > iso-8859-1? i guess maybe have a look at this:
                • 5. Re: convert utf-8 to iso-8859-1
                  Couldn't you just do everything in utf-8?
                  • 6. Re: convert utf-8 to iso-8859-1
                    Level 7
                    show the code for that. it seems your encoding isn't the same back-to-front. is
                    it getting to the db ok? what db? what encoding in the db?
                    • 7. Re: convert utf-8 to iso-8859-1
                      Level 7
                      I work with a MS SQL server database encoding in iso-8859-1
                      The code :
                      <cfif len(form.id) GT 2>
                      <cfquery name="l_fichier" datasource="#bdd#">
                      select *
                      from fichier
                      where titre like '%#form.id#%'
                      or contenu like '%#form.id#%'
                      order by rubrique
                      </cfquery>
                      <cfelse>
                      <cfset l_fichier.recordcount = 0>
                      </cfif>
                      <cfoutput>
                      <b> Résultat de votre recherche #form.id#</b>
                      <div id="trans">
                      <cfif l_fichier.recordcount EQ 0>
                      <div id="resultat">Aucun fichier ne correspond à votre demande</div>
                      <cfelse>
                      <div id="x_contenu">
                      <cfloop query="l_fichier">
                      #lsdateformat(date_modif,'dd/mm/yyy')# - #titre#<br/>
                      </cfloop>
                      </div>
                      </cfif>
                      </div>
                      </cfoutput>
                      JiBé
                      > back-to-front. is it getting to the db ok? what db? what encoding in the
                      > db?
                      • 8. Re: convert utf-8 to iso-8859-1
                        Level 7
                        I'm not the owner of the database... I just use it.
                        JiBé
                        • 9. Re: convert utf-8 to iso-8859-1
                          Level 7
                          data stored in plain text,char,varchar datatypes (ie not "N")? using the ODBC or
                          JDBC (it would be listed as ms sql server in the db drivers list) driver?
                          > The code :
                          you're not following good i18n practices. while my preference is for unicode
                          ("just use unicode" has been my motto for years), if you're really only ever
                          going to use french & never need the euro symbol then i guess iso-8859-1
                          (latin-1) is fine.
                          add to top of all your cf pages:
                          in your application.cfm (or it's equivalent) add:
                          <cfset setEncoding("form","iso-8859-1")>
                          <cfset setEncoding("url","iso-8859-1")>
                          <cfcontent type="text/html; charset=iso-8859-1">
                          if you think you might need other languages, including the euro symbol, then you
                          should consider unicode. change your text columsn to "N" type (nText, nChar,
                          nVarChar) & swap the latin-1 encodings in the tags above to utf-8.
                          • 10. Re: convert utf-8 to iso-8859-1
                            Level 7
                            > The code :
                            (latin-1) is fine.
                            • 11. Re: convert utf-8 to iso-8859-1
                              Level 7
                              datatype of "titre" is varchar(250) and "contenu" is text
                              using the
                              > ODBC or JDBC (it would be listed as ms sql server in the db drivers
                              > list) driver?
                              I think it's jdbc driver (case of my test computer)
                              >> The code :
                              > unicode ("just use unicode" has been my motto for years), if you're
                              > really only ever going to use french & never need the euro symbol then i
                              > guess iso-8859-1 (latin-1) is fine.
                              Here is a part of the content of my application.cfm
                              <cfset setEncoding("URL", "iso-8859-1")>
                              <cfset setEncoding("Form", "iso-8859-1")>
                              > then you should consider unicode. change your text columsn to "N" type
                              > (nText, nChar, nVarChar) & swap the latin-1 encodings in the tags above
                              > to utf-8.
                              I'm going to test that....
                              JiBé
                              • 12. Re: convert utf-8 to iso-8859-1
                                Level 7
                                OK, if i add
                                <cfset setEncoding("Form", "utf-8")> at the top of my
                                x_fichier_cherche.cfm it works fine
                                Thank's a lot for your help.
                                JiBé
