4 Replies Latest reply on Sep 4, 2016 3:48 PM by Peru Bob
    After Effects hardware questions
    jimblind
      Hello everyone.
      I have some questions regarding the optimisation of Adobe After Effects with hardware.
      1. what is more important for better AE performance - CPU or GPU?
      2. what is better for AE performance - Intel i7 CPU with 2 cores and hyper-treading enabled or AMD A10 CPU with 4 cores?
      Thanks in advance.
        • 1. Re: After Effects hardware questions
          Peru Bob Adobe Community Professional & MVP
          CPU
          Intel
          • 2. Re: After Effects hardware questions
            Dave LaRonde Level 6
            1. CPU and NOT GPU.
            2. The faster processor wins.  Neither processor mentioned is worth a spit for multiprocessing in AE.
            • 3. Re: After Effects hardware questions
              glb11
              I was thinking about buying an Alienware PC model # A51R2-1766SLV made by dell.  I currently have a Mac Mini and an older outdated HP use.  Through a Friend I can get this new unused Alienware PC for a really really good price ($999 instead of the retail price of $1700). The Specs are Below. On a scale of 1-10 (10 being the best) how well would this PC work with After Effects, ProPremiere, & Rendering? I've tried to do my homework, but would just like some reassurance. I'd rather buy nice than by twice.  Your help would be appreciated.
              FULL SPECIFICATIONS (not summarized)
              GENERAL
              - Manufacturer - Dell Alienware
              - Series - Area 51
              - Model Number - a51R2-1766SLV
              VIDEO
              - GPU Type - NVIDIA GeForce GTX 970
              - Video Memory - 4GB GDDR5
              - VR Ready - Yes
              - Video Connectors - 1 x HDMI
              - This PC Supports 3 Extra Wide Video cards for up to 12K.  Unstoppable graphics capabilities can enable a mind-melting 11520x2160 resolution across triple Ultra HD 4K monitors (sold seperately). The new Area-51 is designed to support up to three full-length double-wide graphics cards.
              PROCESSOR - Core i7 5820K (3.3GHz)
              - CPU Core - Six-Core
              - CPU Type - Core i7
              - CPU Speed - 5820k (3.3GHz)
              - Turbo Boost Speed - Up to 3.6GHz
              - Smart Cache - 15MB
              - CPU Brand - Intel
              - Front Side Bus - QPI 0GT/s
              - CPU Socket - LGA 2011-3
              - CPUs Installed - 1
              - CPUs Supported - 1
              MEMORY
              - Total Memory - 16GB
              - Memory Speed - DDR4-2133
              - Memory Slots (Total) - 4
              - Form Factor - 288-pin DIMM
              - Maximum Memory Supported - 32GB
              OPERATING SYSTEM
              - Windows 10 Home 64-bit
              CASE & MOTHERBOARD
              - Case Orientation - Vertical
              - Motherboard Chipset - Intel X99 Express
              CPU Main Features
              - Virtualization Technology
              - Hyper-Threading Technology
              - Idle States
              - Execute Disable Bit
              - Thermal Monitoring Technologies
              - Intel 64
              - Enhanced Intel Speedstep Technology
              - Virtualization Technology for Directed I/O
              - Intel VT-x with Extended Page Tables
                (EPT)
              - Intel Identity Protection Technology
              - Intel Smart Response Technology
              - Intel AES New Instructions
              HARD DRIVE
              - HD Interface - SATA
              - HD Capacity - 2TB
              - HD RPM - 7,200 RPM
              - HD Configuration - 1 x 2TB
              SOLID STATE DRIVE
              - SSD Capacity - 128GB
              MULTIMEDIA DRIVES
              - Optical Drives Included - 1
              - Optical Drive - DVDRW
              - Optical Drive Specs - Slot-Loading Dual
                 Layer DVD Burner (DVDRW, CD-RW)
              AUDIO
              - Audio System - Internal High-Definition
              - Audio via Creative Sound Core3D
              COMMUNICATIONS
              LAN
              - Gigabyte LAN
              - LAN Data Rate Speed - 10/100/1000Mbps
              WLAN
              - Intel Dual Band Wireless - AC 7260
              - Bluetooth - Bluetooth 4.0
              - Wireless Technology - 802.11ac
              MEMORY CARD READER
              - FRONT/TOP PANEL PORTS
                  - USB 3.1
                  - 2 x USB 3.1 (Gen 1 Type-A)
              - BACK PANEL PORTS
                  - USB 2.0
                  -  4 x USB 2.0 (Type-A)
                  -  USB 3.1
                  -  4 x USB 3.1 (Gen 1 Type-A)
                  -  LAN RJ45 - 1
                  - Audio - 5 ports
              Here is A Quick Summary Of Specifications:
              (FULL Specifications found above)
              -  Intel Core i7-5820K Processor 3.3GHz
              - Microsoft Windows 10 Home 64-bit
              - 16GB DDR4-2133 RAM
              - 128GB Solid State Drive+2TB 7,200RPM
                 Hard Drive
              - NVIDIA GeForce GTX 970 4GB GDDR5 VR
                 Ready
              - Slot-Loading Dual Layer DVD Burner
              - Media Card Reader
              - 10/100/1000 Network
              - Intel 7260 802.11ac 2x2 Wireless
              • 4. Re: After Effects hardware questions
                You want Windows 7 Pro, not Home.  You will be limited to 16 GB RAM, which is not really enough for good performance with After Effects.
                You will want to add more drive(s), preferably another SSD.
