0 Replies Latest reply on Jan 9, 2015 12:18 PM by kevinknox
    Adobe Media Encoder (Error compiling movie) Unknown error when writing to Isilon OneFS 6.5.5.18
    kevinknox
      Adobe Media Encoder (Error compiling movie) Unknown error when writing to Isilon OneFS 6.5.5.18 while using Adobe Premiere Pro.
      Process:         Adobe Premiere Pro CC 2014
      Path: /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/MacOS/Adobe Premiere Pro CC 2014
      Identifier: com.adobe.AdobePremierePro
      Version:         8.1.0 (8.1.0)
      Code Type: X86-64 (Native)
      Parent Process: launchd [2538]
      Responsible:     Adobe Premiere Pro CC 2014
      Date/Time: 2015-01-06 14:04:23.500 -0700
      OS Version:      Mac OS X 10.9.2 (13C64)
      Report Version:  11
      Crashed Thread: 55  Dispatch queue: com.apple.root.default-priority
      Exception Type: EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
      Customer created test export with 777 permissions and set mount parameters to the following:
      mount_nfs -o vers=3,tcp,rdirplus,intr,nolocks,async,rsize=32768,wsize=32768
        -- Original mount options:
           General mount flags: 0x40 async
           NFS parameters: vers=3,tcp,nolocks,rsize=32768,wsize=32768,rdirplus
        -- Current mount parameters:
           General mount flags: 0x4000058 async,nodev,nosuid multilabel
           NFS parameters: vers=3,tcp,port=2049,nomntudp,hard,nointr,noresvport,negnamecache,callumnt,nolocks,quota, rsize=32768,wsize=32768,readahead=16,dsize=32768,rdirplus,nodumbtimr,timeo=10,maxgroups=16 ,acregmin=5,acregmax=60,acdirmin=5,acdirmax=60,nomutejukebox,nonfc,sec=sys
      The pcap shows once the movie is created a lockup call is responded from Isilon with Error: NFS3ERR_NOENT
      478         V3 CREATE Call (Reply In 479), DH: 0xea5f731c/QBRSN-0-0-1.mov Mode: UNCHECKED
      479         V3 CREATE Reply (Call In 478)
      484         V3 LOOKUP Call (Reply In 485), DH: 0xea5f731c/._QBRSN-0-0-1.mov
      485        V3 LOOKUP Reply (Call In 484) Error: NFS3ERR_NOENT
      V3 LOOKUP Reply (Call In ....) Error: NFS3ERR_NOENT  -   This is by design of OneFS, we coalesce files and then flush them out to disk which is why the commit time is accurate but the file is not immediately available. however when an async option is used within the mount options this should be avoided if writing asynchronously to the cluster.  Has anyone else seen this behavior lately? (current workaround is to store locally and transfer to the cluster via Finder)
