3 Replies Latest reply on Jan 12, 2015 1:49 PM by Warunicorn
    Reduce to 2 colors
    SouthernAtHeart
      On my iPad, using Adobe Touch, is it possible to change a simple little black and white image to just 2 colors- black or white?
        • 1. Re: Reduce to 2 colors
          Blackbird31
          Not sure if I quite understand what effect you're trying to achieve but you could try:
          1) de-saturating the image (turning it to black and white) If you've not already done so
          2) using the "posterIze colour" effect and choose 1 colour. This will force just one colour (black) against white.
          Adjustment using "levels" of the b&w image (after step 1) will influence which shades will be made black in step 2.
          • 2. Re: Reduce to 2 colors
            SouthernAtHeart Level 1
            Thanks! I’ll give that a try.  Basically, I’m trying to create a 1bit image for an LCD screen font. …so each pixel is either on or off, (black or white).
            cheers,
            ck
            • 3. Re: Reduce to 2 colors
              Warunicorn Adobe Community Professional
              In addition to what Blackbird said, try also FX (3rd icon from the top right) > Stylize > Threshold. The default settings should serve you well. (It always reminds me of an old monochrome computer monitor screen, but in high-resolution and in black and white.)  You may have to play with the Threshold setting depending upon how detailed the image is.
