0 Replies Latest reply on Jan 10, 2015 11:37 AM by Video Guru
    CC2014 Wont play and has lost sequences and clips
    Video Guru Level 1
      I would really appreciate help! I have googled but not found any help!
      I have been using Premiere for almost 2 years now and loved the fact that I can subscribe and do updates as they come out. I have setup a "template" with certain parts the same each time (Intro, Outro etc). I edit Safari videos with different sequences for the parts that change each time (arrival, safari, dinner etc different clients), unfortunately I have not figured out a way to save a project with just the footage being used so it uses clips from old projects in different folders. I had to buy an external hardrive as my internal hardrive is too full. I saved all the folders onto the external hardrive. When I opened a project it will say missing media, this is not a problem as once I have located the file it updates everything (after about 3 searches). Great.
      But since I update to CC 2014, I am experiencing the following issues:
      1. Projects (from previous version) have lost their sequences in the project window - only the main sequence has remained (which I named MASTER)
      2. Certain clips are now missing in the sequence (just gone, not even a block with "missing media")
      3. Premiere usually does not always play, sometimes I have to restart and reload projects a few times before it will play (I have tried both the spacebar and the play button on the project monitor)
      4. The ` does not maximize the window anymore!
      5. I tried to maximize a window by clicking on "Maximize panel group" on the menu button of the Sequence Header - my MASTER SEQUENCE disappeared!! No amount of Undo could help
      It seems that the new "Improved" 2014 version is full of bugs, and this happens just when I have some deadlines! I have tried updating from the CREATIVE CLOUD interface but it loads the update up to 50% and then says Update Failed (after numerous efforts)
      Could someone please advise.
      My System
      i7 3.5GHZ 4770K
      20GB ram
      NVidea K2000
      Windows 8.1
      Focusrite Scarlette Soundcard
      2x monitors
      500GB SSD
      2x 2TB Internal 7200rpm
      2x 3TB External USB3
      Media used: .mov, jpg, png, wav, mp4
      Many thanks for your help in advance.
      Paul
