6 Replies Latest reply on Jan 14, 2015 9:15 AM by Drego
    Lightroom crashes when png fils is used for water mark
    Drego
      When I use png files, lightroom 5.7 crashes (windows 7 64 bit). With the plug-in Mogrify it works, but not with lightroom itself.The dng fil can be imported into the lightroom catalog without problem. But it cannot be loaded for the identification table (lightroom crashes). I had this issue already in lightroom 4.
      Thanks for any ideas to solve this.
        • 1. Re: Lightroom crashes when png fils is used for water mark
          ssprengel Adobe Community Professional & MVP
          Can you provide the particular PNG in question?  Upload to http://www.dropbox.com/ and post a public download link, here.
          • 2. Re: Lightroom crashes when png fils is used for water mark
            Drego Level 1
            Thank you,
            the link for the png files is Dropbox - PNG (hopfully it works, I am not so familiar with dropbox)
            In this folder there is the ABC.png file and some converted. All do not work and result in a crash of Lightroom.
            • 3. Re: Lightroom crashes when png fils is used for water mark
              How were these PNGs created?
              I am able to use your ABC.png as a watermark if I open it in PS CC 2014.2.2, leave it non-color-managed, then save it back without any embedded color profile, both compressed and not-compressed.
              My suggestion would me to make them RGB PNGs with an sRGB color profile, rather than indexed or grayscale.
              • 4. Re: Lightroom crashes when png fils is used for water mark
                Drego Level 1
                The ABC was simply written on white paper, scanned with a HP Officejet J4580 and saved as png file. In the HP software there is also the the option to invert it. (Purpose of this is off course to have later my signature as watermark.)
                Do I understand correctly you were able to use the ABC.png as watermark in Lightroom without crash after you changed it ? Can you copy this file in the dropbox ? Not sure where I can set up the color profile for the HP printer (scanner) :-(
                • 5. Re: Lightroom crashes when png fils is used for water mark
                  I opened and resaved the PNG with Photoshop and it didn't crash LR, so it seems your scanner is producing PNGs that aren't quite compatible with Lightroom.
                  Instead of me uploading files after editing in Photoshop, you can use an online editor like Pixlr to edit your own PNGs that won't crash Lightroom:
                  I used the following steps in Pixlr to convert ABC.png to a transparent background PNG that had black writing then another with white writing:
                  1. Open apps.pixlr.com/editor/ Online Photo Editor | Pixlr Editor | Autodesk Pixlr in a browser, I used IE 11
                  2. Click Open Image from Computer
                  4. Double click the padlock symbol in the Layers panel to convert Background to Layer 0
                  5. Select the Magic Wand tool - over at the left
                  6. Turn off Anti-Alias and Contiguous checkboxes up top if necessary because you want all the background removed and clean edges on this B/W PNG
                  7. Click on a white area outside of the letters, notice that the insides of the A and B are also selected because Continuous is turned off
                  8. Hit the Delete (Del) key, notice that the background turns from white to a checkerboard pattern indicating transparency
                  9. Use File / Save... and save this black-letter copy with a new name (e.g.  ABC_black.png) to your computer, somewhere, as filetype PNG - Transparent, Full-Quality
                  10. Use Adjustment / Invert to change the letters to white, notice that the transparency remains
                  11. Use File / Save... and save this white-letter copy with a new name (e.g. ABC_white.png).
                  That's it.
                  Obviously you can do more things in this editor, but for the simple task of making transparent background PNGs from a scanned PNG that's all you need to do.
                  • 6. Re: Lightroom crashes when png fils is used for water mark
                    Drego Level 1
                    Magic. It works ! Many thanks
