2 Replies Latest reply on Jan 11, 2015 6:59 AM by aceleyace
    32bpc Quick Query
    aceleyace
      Hi guys,
      Done a little bit of googling on this, but after 20 minutes perhaps asking might speed this up.
      I'm working in a linear workflow at 32bpc.
      What I'm curious about.. Can I work at 8bpc then for the final render change the setting to 32bpc?
      It's a very vector based motion design project and I'm using the higher bit depth particularly for nicer colour gradients etc.
      Thanks guys
        • 1. Re: 32bpc Quick Query
          That will depend on specifics like whether you use effects like Glow or layer blending modes. They work differently in 8 bit/ 16bit vs. 32bit and thus will affect appearance. If that's not an issue, then this might be a viable option, though generally then one would simply work in 16bpc all the time.
          Mylenium
          • 2. Re: 32bpc Quick Query
            aceleyace Level 1
            ah yes, good point, it sounds like 16 bit is a much better idea to try and work with
            thanks Mylenium
            If anyone else reading this has any other thoughts or input it would be much appreciated
