1 Reply Latest reply on Jan 12, 2015 1:43 PM by maria__
    Install flash via msi issue
    jerhc
      I know this has been posted a hundred times before but I am going to post it again.
      Installing flash player msi via batch command (manually double clicking it produces the same issue).  Installing newest activex 16.0.0.235.  I have 15.0.0.246 currently installed.  Running the msi it requests install_flash_player_13_active_x.msi.  Version 13 of the installer!?!?  Is that a joke?
      I know the workaround is to run a script to uninstall the previous version before installing the newest, but that doesn't always work.
      Praise be the day when flash player is no longer needed!
        • 1. Re: Install flash via msi issue
          maria__ Adobe Employee
          Hi there,
          What batch command are you using?  Are you using one of the catalog files?  If so, please provide the contents of the file (copy/paste, or share it using the instructions posted here, The specified item was not found.).
          Please provide the (verbose) MSI installation log file created during the installation process resulting in the behaviour you are observing (e.g. msiexec /i <path_to_msi> /L*V <path_to_log>).
          Thank you.
          Maria
