2 Replies Latest reply on Jan 13, 2015 3:13 PM by DonAndress
    Animating text
    DonAndress Level 1
      Hello guys.
      So, there is this idea of mine, where I'd like to create the following animation of text:
      White text, then something like a knife cut over this text (in the middle of the text but the line is not straight horizontal, rather a bit diagonal) and along with the cut line red color shows up (imitating blood), then from this cut line red color starts to slowly cover letters down (and only letters, no covering background at this stage), at the end the "blood" starts dripping from letters.
      I already know how to make the easiest part, which is the last one
      I used liquify and the result is great.
      How to get all the effects before that?
      Is it possible in After Effects?
      I use AE CC and Win7.
        • 1. Re: Animating text
          You have got to start thinking in layers, learn about masking, track mattes masks and not be afraid to duplicate layers. Here's one approach.
          1. Create your text layer
          2. Add an open mask to the text layer to give you the path of the knife
          3. Set a keyframe for the mask path and copy it
          4. Add a graphic of a knife to the timeline
          5. Set a position keyframe for the knife and paste.
          6. The knife now follows the same path you drew with the open mask
          7. Go back to the text layer and duplicate it twice
          8. Edit the mask on the top copy of the text layer and close it so you only see the top half of the text layer
          9. Add a white solid to the comp and place it between on the bottom layer
          10. Set the bottom copy of the text layer as a track matte for the blood splash
          11. Animate the position of the blood splash layer so that it matches the knife cut
          12. Add another layer at the bottom to create the dripping blood animation
          When you're done you might want to add Bevel Alpha to give the blood some shine and surface tension. This all depends on your design.
          Here's what happens. The top half copy of your text layer hides the blood layer. The second copy of the text provides a matte for the blood layer. The bottom copy of the text layer gives your text the same color as the top copy until the animated blood layer covers it up.
          This is only one of a couple dozen ways to do the effect. Throwing text animators to make the bottom half of the letters separate as they are cut would be a nice addition.
          • 2. Re: Animating text
            DonAndress Level 1
            Hello Rick.
            Ok, so it took me 2 days to understand masks but I got more or less what I wanted
            Would you kindly take a look at the output and share your thoughts?
            http://youtu.be/5YJLoxqtV0A
