8 Replies Latest reply on Mar 8, 2007 1:27 PM by Newsgroup_User
    Popup Menu in Fireworks 8
    suzy_bcny
      Hi All,
      I want to create popup menu using fireworks 8. I was able to create basic simple popup menu.
      I want to make popup menu in which when mouse is moved over root button it changes its image, pops out the menu and root image stays into changed image till pop up menu is poped out. when popup menu is close root image changes to original image.(same as www.bestbuy.com is having - when mosue is moved over root image change to image with yellow font, pops out the menu and stays yello font imiage till pop up menu is open. when pop up menu is closed root image changes to original image/state.)
      Does anybody have idea, how to do this?
      Pls Help!
      Thank you.
        • 1. Re: Popup Menu in Fireworks 8
          Level 1
          Yeah, Id say at that point mussing around with the default popup menu may not be the best answer in the long run. You should check out how to make one from scratch or even use http://www.projectseven.com popup menus which are far more robust than the out of the box popup menu in Fw8.
          • 2. Re: Popup Menu in Fireworks 8
            suzy_bcny Level 1
            Thanks Alan for your reply.
            But I donot want to buy anything else. I have already bought fireworks8.
            I would just like to use fireworks8 for creating menu.
            Your suggestion in this will really help me. Thank you.
            • 3. anybody but me not see a reply?
              Level 7
              suzy_bcny wrote:
              > Hi All,
              > simple popup menu.
              > Pls Help!
              > Thank you.
              I was having some connection problems to the forum server yesterday and
              now I am not seeing some posts. Anyone else having this problem. I did
              not see a reply to this post or the Medal/Coin thread.
              SKB
              • 4. Re: anybody but me not see a reply?
                Level 7
                I am also missing some. This one strangely enough only shows content
                when I replied to it!
                SKB wrote:
                > suzy_bcny wrote:
                >> Hi All,
                >> Pls Help!
                >> Thank you.
                > SKB
                • 5. Re: anybody but me not see a reply?
                  Level 7
                  Don't have the time right now but, I will remove and re-add this forum
                  to see if it resets.
                  SKB
                  • 6. Re: anybody but me not see a reply?
                    Level 7
                    Let me know if that works. It didn't on this end - alex
                    > SKB
                    • 7. Re: Popup Menu in Fireworks 8
                      Level 7
                      I don't believe Alan suggested you buy anything, but if he did, then
                      consider these free alternatives. The FW menus simple suck large rocks....
                      Check the uberlink and MacFly tutorials at PVII -
                      http://www.projectseven.com/
                      and the Navbar tutorial/articles at Thierry's place
                      http://tjkdesign.com/articles/dropdown/
                      Or this one (more recent article):
                      http://tjkdesign.com/articles/Pure_CSS_Dropdown_Menus.asp
                      Or to get it done fast, go here -
                      http://www.projectseven.com/tutorials/navigation/auto_hide/index.htm
                      Murray --- ICQ 71997575
                      Adobe Community Expert
                      (If you *MUST* email me, don't LAUGH when you do so!)
                      http://www.dreamweavermx-templates.com - Template Triage!
                      http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                      http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                      http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
                      "suzy_bcny" <webforumsuser@macromedia.com> wrote in message
                      news:esp44q$j2d$1@forums.macromedia.com...
                      • 8. Re: anybody but me not see a reply?
                        Level 7
                        Nope. :(
