• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Embedding Help content within an application
New Here ,
Jan 12, 2015 Jan 12, 2015
I am investigating possible methods of embedding Help content within an application, and wondered what experience people have of doing this. I would also be interested in the pros and cons of the various RoboHelp outputs for embedding Help
Views
357
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Really no differences in how to include Help in an application; your main consideration is size – one of my projects is webhelp that I ship separately outside of the software installer because it would bloat the software installer up too much. Another of my projects ships locally-installed AIRHelp and that one is included in the build of the software. It’s still small enough that it’s not having much impact on installer size. You should have a chat with your developers to see how they are able to include the help you produce with their installers.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks very much for your comments. Apologies, I should have provided more details: I am looking into ways of permanently displaying Help information within an application, rather than having to access a separate Help file. For example, This could be through a window that is permanently displayed in the application, or through adding relevant Help content within dialogs. Using tooltips for buttons and menu items is also a consideration. I was wondering what other users of Robohelp recommend, and which output would be most appropriate. Any comments or advice would be appreciated.
Votes
Translate
Translate
Report
Report
Community Expert ,
Ah, embedded help like that is usually done in the code itself (as opposed to a separate help file) and compiled as part of the application itself; you’ll have discuss with the developers on what they want from you content-wise.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
I think this question is really "tool agnostic" and falls mostly into the lap of the application developer. Remember, the application developer is the God of this realm. S/he has full control over what content appears in the visible area. So you likely need to work very closely with whomever it is to establish what is or is not acceptable. For example, will images be allowed? If not, you are left with text only. If that's the case, are you able to format the text? Perhaps using heading levels, making things bold or italic or whatever? If not, you will be pretty much limited to text files.
Hopefully that brings a bit of clarity... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Thanks, I agree that the question is actually "tool agnostic". At the moment, I am thinking about this question from a "User Interface" standpoint. That is, what would be the most effective way to display the Help, from the users' point of view, in order for them to access the Help content they need, in the best way. I could then try too achieve whatever solution we decide on by talking to the developers.
Votes
Translate
Translate
Report
Report
Community Expert ,
Depends on how much real estate you’ve got to work with in the application. I usually add text beside the fields that require assistance and create Help buttons for places where longer content is required. Mouse-over/tool tips are also much used to give users some idea of how something works – if the explanation is too much for a mouse-over to contain, it refers them off to the F1 help system.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 13, 2015 Jan 13, 2015
Thanks. Our users will be using a variety of screen sizes, so screen real estate will vary. Where, in the application, would you suggest the Help pane should be located? Perhaps it could be hidden most of the time, and displayed only when needed? I wondering if there were any proven ways of displaying Help in this way, or standards that should be followed.
Votes
Translate
Translate
Report
Report
Community Expert ,
That’s all going to depend on the application – maybe you need to engage the services of a UX designer?
Votes
Translate
Translate
Report
Report
Community Expert ,
My 2c aren't going to be a huge help, but I did look into this for an application that was being primarily designed for mobile devices.
The answer I came up with was "it depends on the information required at each specific point".
For example, an overlay with graphics can be good to describe touch gestures and key buttons for a screen, but won't work for anything that needs significant explanation.
Longer descriptions built into the interface can work well, but only up to (perhaps) a couple of lines on a portrait phone screen.
I'll see if I can find the short presso I put together about it or put together a new one - depends on how excited I get.
Also, if you are developing for mobile, I'd recommend this book: Developing User Assistance for Mobile Apps | Welinske.com
I haven't read the new one, but the old one provided some insight into mobile UA and at the very least makes you think about things. I think some of the ideas could be adapted for desktop display as well (there is a lot of merit to 'just in time' help, although the work involved is quite high compared to, say, web-deployed standalone help.
P.S. My personal opinion would be that none of the RH outputs would be appropriate for what I consider "embedded", but I think my definition might be narrower than most, ie. text within the application interface rather than 'standalone' help, like chm or webhelp, etc.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 14, 2015 Jan 14, 2015
Thanks very much for all your responses. I would be very interested to see Amebr's presentation, if possible. This may well get my thought processes going in the right direction!
Votes
Translate
Translate
Report
Report
LEGEND ,
In case it will help, here is a screen capture of a Microsoft application using embedded help.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Jan 15, 2015 Jan 15, 2015
LATEST
Thanks Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
