1 Reply Latest reply on Jan 12, 2015 6:45 PM by loopback
    Importing a 300GB iPhoto library to Lightroom
    panda1476 Level 1
      I have a very large file to import to Lightroom In looking at some discussions this is going to take days. Is there an easier way, maybe manually then using the import tool?
      Any help is appreciated.
        • 1. Re: Importing a 300GB iPhoto library to Lightroom
          loopback Level 1
          I posted the approach I used a few months ago- selectively imported photos from multiple iPhoto libraries to various folders within Lightroom.
          The way I did it:
          1. Create a symbolic link at the operating system level to your iPhoto library.
          Assuming your iPhoto library exists in its default location (~/Pictures/iPhoto Library for example):
          open the Terminal app (Applications Utilities Terminal)
          create a link to an existing iPhoto library by entering a command along the lines of:
            ln -s ~/Pictures/iPhoto\ Library ~/Pictures/iPhoto_import
            note: you can press the tab key (after typing only a few characters iPho) to correctly complete the directory name iPhoto Library in the command above
          2. Once this link is created at the operating system level, you can use the standard Lightroom import mechanism to selectively copy/import portions of your iPhoto library into various Lightroom folders (or however you choose to organize them).
          Note: make sure you select the Masters subfolder within the iPhoto folder as the import source or else you will import thumbnail and intermediate dupes (in the graphic below, I created test_iPhotoLibrary symlink so you could see what I'm talking about).
