19 Replies Latest reply on Jan 19, 2015 7:36 AM by Peter Grainge
    Can I make bookmarks invisible?
    shawnvw
      RoboHelp HTML 11, output Multiscreen HTML5.
      I wondered why some of the text in my project output was green instead of black, but I finally realized that these are bookmarks. Is there any way to make bookmarked text look like ordinary text?
        • 1. Re: Can I make bookmarks invisible?
          Hi there
          I'm assuming that you mean you don't want to see it during the editing process, right? Because hopefully you know that the text is only green while you edit. When you generate the output, the text should be the same color as the rest of the text.
          Actually, it sounds like you are taking the wrong approach to bookmarks. Instead of selecting text and making the selected text a bookmark, I much prefer to leave all text unselected and simply insert a bookmark. This should then produce a little flag icon that can easily be repositioned if you need to move the bookmark.
          Another advantage to this approach is that clicking View > Show > Bookmarks will actually hide the small flags.
          Cheers... Rick
          • 2. Re: Can I make bookmarks invisible?
            shawnvw Level 1
            Actually, I was mistaken: it's reddish-brown, not green. (My color vision is impaired.). But it is definitely not black, and it is definitely in the output. as well as the editing screen.
            Also, I'm not the one who put the bookmarks in: RoboHelp did. When I linked in a Word document, every heading and figure caption comes out as a reddish-brown color. (Well, almost every heading and caption. Some are partly skipped.)
            I tried un-checking View > Show > Bookmarks. In the editing screen the bookmarks change from green (or whatever) to blue. In the output, it's still reddish brown.
            Any thoughts?
            • 3. Re: Can I make bookmarks invisible?
              Can you please share some screen captures?
              One with the text in the RoboHelp Editor.
              Select the bookmark and change the Editor to HTML view and give us a screen capture of what you see there
              One with the text in the ouptut
              Thanks... Rick
              • 4. Re: Can I make bookmarks invisible?
                If the problem is what I think it is, in Word there may be a TOC that is linked to heading styles. Word then makes the text a bookmark so when Rh receives the Word output it not unreasonably gives you the same setup. Try importing a simple document from Word with heading but no TOC and no bookmark.
                @petergrainge
                • 5. Re: Can I make bookmarks invisible?
                  shawnvw Level 1
                  Peter, you seem to be onto something. The linked Word document does have a Table of Contents, and when I remove it, the problem does go away.
                  Now, is there a way to solve the problem without removing the Word Table of Contents?  (I may need it for the Printed Documentation version.) Excluding it with Conditional Tags doesn't help.
                  • 6. Re: Can I make bookmarks invisible?
                    Nice catch, Peter!
                    • 7. Re: Can I make bookmarks invisible?
                      shawnvw Level 1
                      I realized that some of the colored bookmarks remain, because there are references to them in the text. In other words, removing the Table of Contents only solves part of the problem.
                      I'm still waiting for permission to send those screenshots. How would I do that on this forum?
                      • 8. Re: Can I make bookmarks invisible?
                        Jeff_Coatsworth Adobe Community Professional & MVP
                        Use the camera icon in the web interface.
                        • 9. Re: Can I make bookmarks invisible?
                          When you do the import, deselect the TOC.
                          See Importing on my site.
                          • 10. Re: Can I make bookmarks invisible?
                            shawnvw Level 1
                            I'm not importing, Peter, I'm linking. Does that make a difference?
                            In either case, deselecting the TOC is only solving part of the problem; I still see bookmarks created in Word by cross-references.
                            I'm seriously considering changing the color of the heading text from black to green; that way the bookmarks won't stand out!
                            • 11. Re: Can I make bookmarks invisible?
                              Surely there is some CSS or even a style in Word that would govern this, no?
                              • 12. Re: Can I make bookmarks invisible?
                                @rick I'm not seeing how the bookmark itself is showing at all, never mind what colour. I have a hunch as to what the problem might be, see below.
                                @shawnvw Please post an image of what you see in the generated help.
                                @petergrainge
                                • 13. Re: Can I make bookmarks invisible?
                                  shawnvw Level 1
                                  This is the output. All the header text should be black.
                                  • 14. Re: Can I make bookmarks invisible?
                                    I'll certainly defer to Peter as to the Word stuff. Especially as he has a hunch about it.
                                    But it sure looks to me as if over in Word world, there has been some style applied that configures those colors. It would be interesting to see the CSS files involved.
                                    RH conversion - AMHS.css
                                    RHStyleMapping.css
                                    Note that you can open these in Windows Notepad, then copy what is inside and paste into the forum reply.
                                    Cheers... Rick
                                    • 15. Re: Can I make bookmarks invisible?
                                      shawnvw Level 1
                                      Here's the first one:
                                      RHStyleMapping.css
                                      /*Created with Adobe RoboHelp 11.*/
                                      p.BodyLevel1 {
                                      margin-left: 18.000pt;
                                      margin-right: 0.000pt;
                                      text-align: left;
                                      text-indent: 0.000pt;
                                      margin-top: 8.000pt;
                                      margin-bottom: 0.000pt;
                                      word-spacing: 0.250em;
                                      font-family: "Times New Roman";
                                      font-style: normal;
                                      font-weight: normal;
                                      font-size: 11.0pt;
                                      color: #000000;
                                      letter-spacing: 0.00em;
                                      text-decoration: none;
                                      p.BodyLevel2 {
                                      margin-left: 36.000pt;
                                      text-align: left;
                                      font-style: normal;
                                      font-size: 11.0pt;
                                      color: #000000;
                                      p.BodyLevel3 {
                                      margin-left: 54.000pt;
                                      text-align: left;
                                      font-style: normal;
                                      font-size: 11.0pt;
                                      color: #000000;
                                      h1 {
                                      margin-left: 0.000pt;
                                      text-align: left;
                                      margin-top: 17.000pt;
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 14.0pt;
                                      color: #000000;
                                      h2 {
                                      margin-right: 36.000pt;
                                      text-align: left;
                                      margin-top: 16.000pt;
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 13.0pt;
                                      color: #000000;
                                      h3 {
                                      text-align: left;
                                      margin-top: 14.000pt;
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 12.0pt;
                                      color: #000000;
                                      h4 {
                                      text-align: left;
                                      margin-top: 13.000pt;
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 11.0pt;
                                      color: #000000;
                                      p.Title {
                                      text-align: left;
                                      margin-top: 22.000pt;
                                      margin-bottom: 11.000pt;
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 18.0pt;
                                      color: #000000;
                                      p.AuthorBook {
                                      text-align: left;
                                      margin-top: 0.000pt;
                                      margin-bottom: 292.000pt;
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 13.0pt;
                                      color: #000000;
                                      p.CellBody {
                                      text-align: left;
                                      margin-bottom: 4.000pt;
                                      font-style: normal;
                                      font-size: 9.0pt;
                                      color: #000000;
                                      p.CellHeading {
                                      text-align: left;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 9.0pt;
                                      color: #000000;
                                      p.Extract {
                                      margin-right: 18.000pt;
                                      text-align: left;
                                      margin-top: 7.000pt;
                                      font-style: normal;
                                      font-size: 9.0pt;
                                      color: #000000;
                                      p.Footnote {
                                      margin-left: 12.000pt;
                                      text-align: left;
                                      text-indent: -12.000pt;
                                      margin-top: 3.000pt;
                                      font-style: normal;
                                      font-size: 9.0pt;
                                      color: #000000;
                                      p.PublisherBook {
                                      text-align: left;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 12.0pt;
                                      color: #000000;
                                      p.TitleBook {
                                      text-align: left;
                                      margin-bottom: 60.000pt;
                                      font-style: italic;
                                      font-size: 30.0pt;
                                      color: #000000;
                                      letter-spacing: -0.04em;
                                      h5 {
                                      font-weight: bold;
                                      font-size: 10.0pt;
                                      h6 {
                                      font-weight: bold;
                                      font-size: 8.0pt;
                                      span.PageNumber {
                                      font-weight: bold;
                                      span.EquationVariables {
                                      font-style: italic;
                                      span.Emphasis {
                                      font-style: italic;
                                      span.Callout {
                                      font-family: Arial;
                                      font-style: normal;
                                      font-size: 8.0pt;
                                      color: #000000;
                                      span.BulletSymbol {
                                      font-family: Courier;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 11.0pt;
                                      color: #000000;
                                      span.FirstLetterTitle {
                                      font-style: italic;
                                      font-size: 42.0pt;
                                      color: #000000;
                                      span.EquationNumber {
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 8.0pt;
                                      color: #000000;
                                      span.ChapterNumber {
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 10.0pt;
                                      color: #000000;
                                      letter-spacing: 0.04em;
                                      span.StepNumber {
                                      font-family: Arial;
                                      font-style: normal;
                                      font-weight: bold;
                                      font-size: 8.0pt;
                                      color: #000000;
                                      span.WebJump {
                                      span.Superscript {
                                      font-style: normal;
                                      color: #000000;
                                      span.Underline {
                                      font-style: normal;
                                      color: #000000;
                                      span.Bold {
                                      font-style: normal;
                                      font-weight: bold;
                                      color: #000000;
                                      span.BlueBold {
                                      font-weight: bold;
                                      color: #2e97dc;
                                      span.White {
                                      color: #ffffff;
                                      span.Emphasis {
                                      font-style: italic;
                                      span.Symbol {
                                      font-family: Symbol;
                                      font-style: normal;
                                      font-size: 10.0pt;
                                      color: #000000;
                                      span.GreyBold {
                                      font-family: Arial;
                                      font-weight: bold;
                                      color: #3f3f3f;
                                      span.Subscript {
                                      font-style: normal;
                                      color: #000000;
                                      table.CellBorder {
                                      padding: 0px;
                                      border-top: Solid 1px #000000;
                                      border-left: Solid 1px #000000;
                                      x-border-spacing: 0px;
                                      table.CellBorder td {
                                      border-right: Solid 1px #000000;
                                      border-bottom: Solid 1px #000000;
                                      table.Colorful1 {
                                      padding: 0px;
                                      border-left-style: Solid;
                                      border-left-width: 1px;
                                      border-left-color: #000000;
                                      border-top-style: Solid;
                                      border-top-width: 1px;
                                      border-top-color: #000000;
                                      x-1st-row: 1;
                                      x-1st-row-name: row1;
                                      x-1st-col: 1;
                                      x-1st-col-name: col1;
                                      table.Colorful1 tr.row1 td {
                                      background-color: #800000;
                                      padding-right: 10px;
                                      padding-left: 10px;
                                      font-weight: bold;
                                      border-right-style: Solid;
                                      border-right-width: 1px;
                                      border-right-color: #000000;
                                      border-bottom-style: Solid;
                                      border-bottom-width: 1px;
                                      border-bottom-color: #000000;
                                      color: #ffffff;
                                      table.Colorful1 td.col1 {
                                      background-color: #c0c0c0;
                                      padding-left: 10px;
                                      font-weight: bold;
                                      table.Colorful1 td {
                                      padding-left: 10px;
                                      table.Colorful2 {
                                      padding: 0px;
                                      x-1st-row: 1;
                                      x-1st-col: 1;
                                      table.Colorful2 tr.row1 td {
                                      background-color: #000080;
                                      padding-left: 10px;
                                      font-weight: bold;
                                      color: #ffffff;
                                      table.Colorful2 td.col1 {
                                      background-color: #0000ff;
                                      font-weight: bold;
                                      padding-left: 10px;
                                      color: #ffffff;
                                      table.Colorful2 td {
                                      padding-left: 10px;
                                      table.Colorful3 {
                                      padding: 0px;
                                      border-left-color: #ffffff;
                                      border-top-color: #ffffff;
                                      x-1st-row: 1;
                                      table.Colorful3 tr.row1 td {
                                      padding-left: 10px;
                                      font-weight: bold;
                                      color: #ffffff;
                                      table.Colorful3 td {
                                      border-right-color: #ffffff;
                                      border-bottom-color: #ffffff;
                                      padding-left: 10px;
                                      table.Colorful4 {
                                      padding: 0px;
                                      x-1st-row: 1;
                                      x-1st-col: 1;
                                      table.Colorful4 tr.row1 td {
                                      background-color: #008000;
                                      padding-left: 10px;
                                      font-weight: bold;
                                      color: #ffffff;
                                      table.Colorful4 td.col1 {
                                      background-color: #ffff00;
                                      font-weight: bold;
                                      padding-left: 10px;
                                      table.Colorful4 td {
                                      padding-left: 10px;
                                      table.LastColumn {
                                      x-row-pat-1: 1;
                                      x-row-pat-1-name: t1Row;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-row-pat-2-name: t2Row;
                                      x-last-col: 1;
                                      x-last-col-name: last;
                                      text-align: Right;
                                      font-size: 10pt;
                                      table.LastColumn tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LastColumn tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LastColumn td.last {
                                      font-family: Arial;
                                      text-align: Right;
                                      font-size: 10pt;
                                      table.lastcolumn tr.t1row td.last {
                                      font-family: Arial;
                                      text-align: Right;
                                      font-size: 10pt;
                                      table.lastcolumn tr.t2row td.last {
                                      font-family: Arial;
                                      text-align: Right;
                                      font-size: 10pt;
                                      table.LastRow {
                                      padding: 0px;
                                      x-last-row: 1;
                                      x-last-row-name: last;
                                      text-align: Right;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LastRow td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LastRow tr.last td {
                                      text-align: Right;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.BottomRowRightColumn {
                                      padding: 0px;
                                      x-last-row: 1;
                                      text-align: Right;
                                      font-family: Arial;
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-last-col: 1;
                                      table.BottomRowRightColumn td {
                                      table.BottomRowRightColumn tr.last td {
                                      text-align: Right;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.BottomRowRightColumn tr.t1Row td {
                                      text-align: Right;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.BottomRowRightColumn tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.BottomRowRightColumn td.last {
                                      text-align: Right;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.BottomRowRightColumn tr.t1row td.last {
                                      text-align: Right;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.BottomRowRightColumn tr.t2row td.last {
                                      text-align: Right;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumn {
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-1st-col: 1;
                                      x-1st-col-name: t1st;
                                      table.LeftColumn tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumn tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumn td.t1st {
                                      background-color: #cccccc;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.leftcolumn tr.t1row td.t1st {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.leftcolumn tr.t2row td.t1st {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.LeftColumnAlternatingColumns {
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-1st-col: 1;
                                      x-col-pat-1: 1;
                                      x-col-pat-1-name: t1Col;
                                      x-col-pat-count: 2;
                                      x-col-pat-2: 1;
                                      x-col-pat-2-name: t2Col;
                                      table.LeftColumnAlternatingColumns tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumnAlternatingColumns tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumnAlternatingColumns td.t1st {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.leftcolumnalternatingcolumns tr.t1row td.t1st {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.leftcolumnalternatingcolumns tr.t2row td.t1st {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.LeftColumnAlternatingColumns td.t1Col {
                                      background-color: #ccffcc;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumnAlternatingColumns td.t2Col {
                                      table.LeftColumnRepeatingColumns {
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-1st-col: 1;
                                      x-col-pat-1: 1;
                                      x-col-pat-2: 1;
                                      x-col-pat-count: 3;
                                      x-col-pat-3: 1;
                                      x-col-pat-3-name: t3Col;
                                      table.LeftColumnRepeatingColumns tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumnRepeatingColumns tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumnRepeatingColumns td.t1st {
                                      background-color: #808080;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.leftcolumnrepeatingcolumns tr.t1row td.t1st {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.leftcolumnrepeatingcolumns tr.t2row td.t1st {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.LeftColumnRepeatingColumns td.t1Col {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumnRepeatingColumns td.t2Col {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.LeftColumnRepeatingColumns td.t3Col {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.Line1 {
                                      padding: 0px;
                                      border-bottom-width: 3px;
                                      border-bottom-color: #008000;
                                      border-top-width: 3px;
                                      border-top-color: #008000;
                                      x-1st-row: 1;
                                      table.Line1 tr.row1 td {
                                      table.PaddedCells {
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-border-spacing: 2px;
                                      table.PaddedCells tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.PaddedCells tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.PaddedCells td {
                                      padding-left: 5px;
                                      padding-right: 5px;
                                      padding-top: 5px;
                                      padding-bottom: 5px;
                                      table.Retro7 {
                                      x-border-spacing: 15px;
                                      x-row-pat-count: 1;
                                      x-row-pat-1: 1;
                                      table.Retro7 tr.t1Row td {
                                      border-top-style: Groove;
                                      border-bottom-style: Groove;
                                      border-top-color: #00ff00;
                                      border-top-width: 4px;
                                      border-bottom-color: #00ff00;
                                      border-bottom-width: 4px;
                                      table.Retro7 td {
                                      padding-left: 10px;
                                      padding-top: 0px;
                                      padding-bottom: 0px;
                                      table.ShadedAlternatingColumns {
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-col-pat-1: 1;
                                      x-col-pat-count: 2;
                                      x-col-pat-2: 1;
                                      table.ShadedAlternatingColumns tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.ShadedAlternatingColumns tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.ShadedAlternatingColumns td.t1Col {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.ShadedAlternatingColumns td.t2Col {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.ShadedAlternatingRows {
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      table.ShadedAlternatingRows tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.ShadedAlternatingRows tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.SimpleBorder {
                                      padding: 0px;
                                      table.SimpleBorder td {
                                      table.TopRow {
                                      x-1st-row: 1;
                                      x-1st-row-name: t1st;
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      table.TopRow tr.t1st td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      text-align: Center;
                                      table.TopRow tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRow tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRowRepeatingRows {
                                      x-row-pat-1: 1;
                                      x-row-pat-2: 1;
                                      x-1st-row: 1;
                                      x-row-pat-count: 3;
                                      x-row-pat-3: 1;
                                      x-row-pat-3-name: t3Row;
                                      table.TopRowRepeatingRows tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRowRepeatingRows tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRowRepeatingRows tr.t1st td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      text-align: Center;
                                      table.TopRowRepeatingRows tr.t3Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRowAlternatingRows {
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-1st-row: 1;
                                      table.TopRowAlternatingRows tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRowAlternatingRows tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRowAlternatingRows tr.t1st td {
                                      text-align: Center;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.TopRowLeftColumn {
                                      x-row-pat-1: 1;
                                      x-row-pat-count: 2;
                                      x-row-pat-2: 1;
                                      x-1st-row: 1;
                                      x-1st-col: 1;
                                      table.TopRowLeftColumn tr.t1Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRowLeftColumn tr.t2Row td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      table.TopRowLeftColumn tr.t1st td {
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      text-align: Center;
                                      table.TopRowLeftColumn td.t1st {
                                      text-align: Center;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.toprowleftcolumn tr.t1row td.t1st {
                                      text-align: Center;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      table.toprowleftcolumn tr.t2row td.t1st {
                                      text-align: Center;
                                      font-family: Arial;
                                      font-size: 10pt;
                                      font-weight: bold;
                                      span.WD_button {
                                      p.WD_step1 {
                                      color: #000000;
                                      • 16. Re: Can I make bookmarks invisible?
                                        shawnvw Level 1
                                        And here's the second:
                                        RH_conversion_-_AMHS.css
                                        /* Style Sheet created by ImportDoc 13.0 */
                                        p.WD_Normal {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:8.0pt;
                                        margin-left:0in;
                                        line-height:107%;
                                        font-size:11.0pt;
                                        font-family:"Calibri"   ,sans-serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Heading1 {
                                        margin-top:0in;
                                        margin-right:-.75in;
                                        margin-left:22.5pt;
                                        text-indent:-.3in;
                                        background:#B1C2D7;
                                        border:none;
                                        padding:0in;
                                        font-size:18.0pt;
                                        font-family:"Lucida Sans Unicode"   ,sans-serif;
                                        font-variant:small-caps;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Heading2 {
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.5in;
                                        margin-bottom:.0001pt;
                                        text-indent:-.5in;
                                        font-size:16.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Heading3 {
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.7in;
                                        text-indent:-.7in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:.1pt;
                                        font-weight:bold;
                                        p.WD_Heading4 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-bottom:12.0pt;
                                        margin-left:.75in;
                                        text-indent:-.75in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Heading5 {
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-left:.7in;
                                        text-indent:-.7in;
                                        font-size:12.0pt;
                                        font-family:"Arial"   ,sans-serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Heading6 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-bottom:3.0pt;
                                        margin-left:1.0in;
                                        text-indent:-1.0in;
                                        font-size:10.0pt;
                                        font-family:"Verdana"   ,sans-serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Heading7 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.9in;
                                        text-indent:-.9in;
                                        font-size:12.0pt;
                                        font-family:"Times New Roman"   ,serif;
                                        color:windowtext;
                                        p.WD_Heading8 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-1.0in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        font-style:italic;
                                        p.WD_Heading9 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:1.1in;
                                        text-indent:-1.1in;
                                        font-size:11.0pt;
                                        color:windowtext;
                                        p.WD_Index1 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Index2 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.75in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Index3 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Index4 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:1.25in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Index5 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:1.5in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Index6 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:1.25in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Index7 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:1.5in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Index8 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:1.75in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Index9 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:2.0in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Toc1 {
                                        margin-top:6.0pt;
                                        margin-right:0in;
                                        margin-bottom:2.0pt;
                                        margin-left:45.35pt;
                                        text-indent:-45.35pt;
                                        font-size:14.0pt;
                                        font-family:"Times New Roman Bold"   ,serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Toc2 {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:66.6pt;
                                        text-indent:-30.6pt;
                                        font-size:11.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Toc3 {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:81.0pt;
                                        text-indent:-45.0pt;
                                        font-size:9.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Toc4 {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:1.25in;
                                        text-indent:-.75in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Toc5 {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Toc6 {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-bottom:1.0pt;
                                        margin-left:117.35pt;
                                        text-indent:-63.35pt;
                                        font-size:9.0pt;
                                        font-family:"Georgia"   ,serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Toc7 {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:1.0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Toc8 {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:84.0pt;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Toc9 {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:96.0pt;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_NormalIndent {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_FootnoteText {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:9.35pt;
                                        text-indent:-9.35pt;
                                        line-height:11.0pt;
                                        font-size:9.0pt;
                                        color:windowtext;
                                        p.WD_CommentText {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:9.35pt;
                                        line-height:11.0pt;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Header {
                                        margin:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        font-family:"Eras Light ITC"   ,sans-serif;
                                        color:windowtext;
                                        p.WD_Footer {
                                        margin:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_IndexHeading {
                                        margin-top:6.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:14.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_CaptionTableTitle {
                                        margin-top:3.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:11.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Tof {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        font-size:9.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_EnvelopeAddress {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:2.0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_EnvelopeReturn {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        span.WD_FootnoteReference {
                                        vertical-align:super;
                                        span.WD_CommentReference {
                                        color:navy;
                                        display:none;
                                        span.WD_LineNumber {
                                        span.WD_PageNumber {
                                        font-weight:bold;
                                        span.WD_EndnoteReference {
                                        p.WD_EndnoteText {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:9.35pt;
                                        line-height:11.0pt;
                                        font-size:9.0pt;
                                        color:windowtext;
                                        p.WD_Toa {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.25in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_MacroText {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        font-family:Courier New;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ToaHeading {
                                        margin-top:6.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:14.0pt;
                                        color:windowtext;
                                        letter-spacing:1.0pt;
                                        font-weight:bold;
                                        p.WD_List {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.75in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListBullet {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListNumber {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_List2 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.75in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_List3 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_List4 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.25in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_List5 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListBullet2 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.75in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListBullet3 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListBullet4 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.25in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListBullet5 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListNumber2 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.75in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListNumber3 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListNumber4 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.25in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListNumber5 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_Title {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:15.0pt;
                                        margin-left:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:26.0pt;
                                        font-family:"Calibri Light"   ,sans-serif;
                                        color:#323E4F;
                                        letter-spacing:.25pt;
                                        p.WD_TitleCxSpFirst {
                                        margin:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:26.0pt;
                                        color:#323E4F;
                                        p.WD_TitleCxSpMiddle {
                                        margin:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:26.0pt;
                                        color:#323E4F;
                                        p.WD_TitleCxSpLast {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-left:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:26.0pt;
                                        color:#323E4F;
                                        p.WD_Closing {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:3.0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Signature {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:3.0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BodyTextBodyTextChar2BodyTextCharChar1BodyTextChar1CharCharBodyTextCharCharCharCharBo dyTextChar1CharCharCharCharBodyTextCharCharCharCharCharCharBodyTextChar2CharCharCharCharCh arBodyTextChar1Char1Char {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_BodyTextIndent {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-bottom:6.0pt;
                                        margin-left:.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_ListContinue {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListContinue2 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.75in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListContinue3 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListContinue4 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.25in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListContinue5 {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_MessageHeader {
                                        margin-top:12.0pt;
                                        margin-right:2.0in;
                                        margin-left:.75in;
                                        text-indent:-.75in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_Subtitle {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:14.0pt;
                                        color:windowtext;
                                        font-style:italic;
                                        p.WD_Salutation {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Date {
                                        margin-top:24.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BodyTextFirstIndent {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-indent:10.5pt;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BodyTextFirstIndent2 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.25in;
                                        text-indent:10.5pt;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_NoteHeading {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BodyText2 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BodyText3 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BodyTextIndent2 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BodyTextIndent3 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BlockText {
                                        margin-top:12.0pt;
                                        margin-right:1.0in;
                                        margin-left:1.0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        span.WD_Hyperlink {
                                        color:blue;
                                        font-style:italic;
                                        text-decoration:underline;
                                        text-underline:single;
                                        span.WD_HyperlinkFollowed {
                                        color:purple;
                                        p.WD_DocumentMap {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        background:navy;
                                        font-size:10.0pt;
                                        font-family:"Tahoma"   ,sans-serif;
                                        color:windowtext;
                                        p.WD_PlainText {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_AutoSig {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_CommentSubject {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_Acetate {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        span.WD_PlaceholderText {
                                        color:gray;
                                        p.WD_NoSpacing {
                                        margin:0in;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        p.WD_RMPane {
                                        margin:0in;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        p.WD_ListParagraph {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_ListParagraphCxSpFirst {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_ListParagraphCxSpMiddle {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_ListParagraphCxSpLast {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        span.WD_Heading1 {
                                        background:#B1C2D7;
                                        font-weight:bold;
                                        span.WD_Heading2 {
                                        font-weight:bold;
                                        span.WD_Heading3 {
                                        font-weight:bold;
                                        span.WD_Heading4 {
                                        font-weight:bold;
                                        span.WD_Heading5 {
                                        font-weight:bold;
                                        span.WD_Heading6 {
                                        font-weight:bold;
                                        span.WD_Heading7 {
                                        span.WD_Heading8 {
                                        font-style:italic;
                                        span.WD_Heading9 {
                                        p.WD_IMPORTANT {
                                        margin-top:6.0pt;
                                        margin-right:1.0in;
                                        margin-left:84.95pt;
                                        text-indent:-1.05in;
                                        background:#FFFF99;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_normalcell {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Step1 {
                                        margin-top:4.0pt;
                                        margin-right:0in;
                                        margin-bottom:4.0pt;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-left:99.05pt;
                                        text-indent:-18.45pt;
                                        font-size:8.0pt;
                                        font-family:"Arial Narrow"   ,sans-serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.25in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        span.WD_button {
                                        border:solid #7B7B7B 1.0pt;
                                        padding:0in;
                                        font-weight:bold;
                                        span.WD_italics {
                                        font-style:italic;
                                        p.WD_CellLverdana9 {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Cell1R {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:right;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Cell1L {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        span.WD_selectoption {
                                        padding:0in;
                                        font-weight:bold;
                                        span.WD_paragraphnote {
                                        position:relative;
                                        top:0pt;
                                        letter-spacing:0pt;
                                        span.WD_bold {
                                        font-weight:bold;
                                        font-weight:bold;
                                        p.WD_NOTE {
                                        margin-top:12.0pt;
                                        margin-right:2.25pt;
                                        margin-left:5.4pt;
                                        background:#E0E0E0;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_TableHeadingC {
                                        margin:0in;
                                        text-align:center;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Captioncont {
                                        margin-top:3.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_tablecaptioncont {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_Normalnoindent {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_callout800 {
                                        margin:0in;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_NOTEQRG {
                                        margin:0in;
                                        line-height:9.0pt;
                                        background:#E0E0E0;
                                        border:none;
                                        padding:0in;
                                        font-size:9.0pt;
                                        font-family:"Franklin Gothic Book"   ,sans-serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_IMPORTANTQRG {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:16.55pt;
                                        text-indent:-15.1pt;
                                        line-height:9.0pt;
                                        background:#FFFF99;
                                        border:none;
                                        padding:0in;
                                        font-size:9.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_sectionQRG {
                                        margin:0in;
                                        line-height:12.0pt;
                                        font-size:12.0pt;
                                        font-family:"Segoe UI"   ,sans-serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_CAUTION {
                                        margin-top:6.0pt;
                                        margin-right:1.0in;
                                        background:#FFFF99;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_stepacell {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        span.WD_StylefilefolderpathBookmanOldStyle {
                                        font-family:"Bookman Old Style"   ,serif;
                                        position:relative;
                                        top:0pt;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        span.WD_filefolderpath {
                                        position:relative;
                                        top:0pt;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        span.WD_linkclick {
                                        color:#282850;
                                        font-weight:bold;
                                        span.WD_link {
                                        color:#282850;
                                        font-weight:bold;
                                        p.WD_callout {
                                        margin:0in;
                                        text-align:center;
                                        text-autospace:none;
                                        font-size:9.0pt;
                                        color:black;
                                        letter-spacing:0pt;
                                        p.WD_callout8c {
                                        margin:0in;
                                        text-align:center;
                                        font-size:9.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        span.WD_notepara {
                                        font-family:"Cambria"   ,serif;
                                        position:relative;
                                        top:0pt;
                                        letter-spacing:0pt;
                                        font-style:italic;
                                        text-decoration:none;
                                        text-underline:none;
                                        span.WD_HTMLAddress {
                                        font-style:italic;
                                        span.WD_HTMLPreformatted {
                                        span.WD_CommentText {
                                        span.WD_Header {
                                        span.WD_Footer {
                                        span.WD_EndnoteText {
                                        span.WD_MacroText {
                                        font-weight:bold;
                                        span.WD_Closing {
                                        span.WD_Signature {
                                        span.WD_BodyTextIndent {
                                        span.WD_MessageHeader {
                                        font-weight:bold;
                                        span.WD_Title {
                                        color:#323E4F;
                                        span.WD_Subtitle {
                                        font-style:italic;
                                        span.WD_Salutation {
                                        span.WD_Date {
                                        span.WD_BodyTextFirstIndent {
                                        span.WD_BodyTextChar1BodyTextChar2Char1BodyTextCharChar1Char1BodyTextChar1CharCharChar1Bod yTextCharCharCharCharChar1BodyTextChar1CharCharCharCharChar1BodyTextCharCharCharCharCharCh arChar1 {
                                        font-weight:bold;
                                        span.WD_BodyTextFirstIndent2 {
                                        span.WD_NoteHeading {
                                        span.WD_BodyText2 {
                                        span.WD_BodyText3 {
                                        span.WD_BodyTextIndent2 {
                                        span.WD_BodyTextIndent3 {
                                        span.WD_DocumentMap {
                                        background:navy;
                                        span.WD_PlainText {
                                        span.WD_EmailSignature {
                                        span.WD_CommentSubject {
                                        font-weight:bold;
                                        span.WD_BalloonText {
                                        p.WD_footnote {
                                        margin-top:6.0pt;
                                        margin-right:0in;
                                        margin-left:9.35pt;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_BlockQuotation {
                                        margin-top:12.0pt;
                                        margin-right:.5in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        font-style:italic;
                                        p.WD_BlockQuotationFirst {
                                        margin-top:6.0pt;
                                        margin-right:.5in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        font-style:italic;
                                        p.WD_BlockQuotationLast {
                                        margin-top:12.0pt;
                                        margin-right:.5in;
                                        margin-left:.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        font-style:italic;
                                        p.WD_Body1L {
                                        margin-top:6.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Body1R {
                                        margin-top:6.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:right;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_callout10V {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_Cell {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.2in;
                                        text-indent:-.2in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Cella {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        span.WD_Cell1R {
                                        p.WD_ChapterLabel {
                                        margin-top:.25in;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ChapterSubtitle {
                                        margin-top:.25in;
                                        margin-right:0in;
                                        margin-bottom:.25in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:14.0pt;
                                        color:windowtext;
                                        font-style:italic;
                                        p.WD_ChapterTitle {
                                        margin-top:30.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:16.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_GlossaryDefinition {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.25in;
                                        layout-grid-mode:char;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_DocumentLabel {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:18.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_Figure {
                                        margin:0in;
                                        text-align:center;
                                        border:none;
                                        padding:0in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_FigureLabel {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        span.WD_figureAncorC {
                                        p.WD_figureAncorC {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_figureAncorL {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:10.0pt;
                                        margin-left:0in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_figureAncorR {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:right;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_FooterEven {
                                        margin:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_FooterFirst {
                                        margin:0in;
                                        text-align:center;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_FooterOdd {
                                        margin:0in;
                                        text-align:right;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Footerpps {
                                        margin:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_FootnoteBase {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:9.35pt;
                                        line-height:11.0pt;
                                        font-size:9.0pt;
                                        color:windowtext;
                                        p.WD_HeaderBase {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_HeaderEven {
                                        margin:0in;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_HeaderFirst {
                                        margin:0in;
                                        text-align:center;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_HeaderOdd {
                                        margin:0in;
                                        text-align:right;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_Heading2table {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        font-size:16.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Heading3no {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Heading4table {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-1.0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_HeadingBase {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:18.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_Heading0 {
                                        margin:0in;
                                        text-align:center;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_HeadingCno {
                                        margin-top:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        text-indent:0in;
                                        background:#B1C2D7;
                                        border:none;
                                        padding:0in;
                                        font-size:18.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_HeadingCnoNoBrk {
                                        margin-top:.25in;
                                        margin-left:0in;
                                        text-align:center;
                                        text-indent:0in;
                                        background:#B1C2D7;
                                        border:none;
                                        padding:0in;
                                        font-size:18.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_IndexBase {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.5in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_ListBulletFirst {
                                        margin-top:4.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListBulletLast {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListFirst {
                                        margin-top:4.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListLast {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListNumberFirst {
                                        margin-top:4.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ListNumberLast {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:.5in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        span.WD_TableHeadingC {
                                        font-weight:bold;
                                        p.WD_TableHeadingL {
                                        margin:0in;
                                        text-align:center;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_ListHeadingLunderline {
                                        margin:0in;
                                        text-align:center;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Notes {
                                        margin-top:6.0pt;
                                        margin-right:.25in;
                                        margin-left:81.35pt;
                                        background:#F3F3F3;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_num10c {
                                        margin-top:3.0pt;
                                        margin-right:0in;
                                        margin-left:.25in;
                                        text-indent:-.25in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_PageBrk {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        line-height:1.0pt;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_PartLabel {
                                        margin-top:30.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        p.WD_PartSubtitle {
                                        margin-top:.25in;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:16.0pt;
                                        color:windowtext;
                                        font-style:italic;
                                        p.WD_PartTitle {
                                        margin-top:30.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:18.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_Picture {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_ReturnAddress {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        font-family:"Garamond"   ,serif;
                                        color:windowtext;
                                        letter-spacing:-.15pt;
                                        p.WD_SectionHeading {
                                        margin-top:6.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:14.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_SectionLabel {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:18.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_SubtitleCover {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:18.0pt;
                                        color:windowtext;
                                        font-style:italic;
                                        p.WD_table {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_TableHeading2 {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:black;
                                        font-weight:bold;
                                        p.WD_TableHeading2C {
                                        margin-top:2.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_TableHeadingR {
                                        margin-top:0in;
                                        margin-right:2.15pt;
                                        margin-bottom:0in;
                                        margin-left:0in;
                                        text-align:right;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_TitleCover {
                                        margin-top:.5in;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:24.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_TOCBase {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        span.WD_CAUTION {
                                        background:#FFFF99;
                                        span.WD_CellLverdana9 {
                                        span.WD_figureanchor {
                                        p.WD_figureanchor {
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_head1ap {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-1.0in;
                                        font-size:16.0pt;
                                        font-family:"Eras Medium ITC"   ,sans-serif;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_head2ap {
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.4in;
                                        text-indent:-.4in;
                                        font-size:13.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_head3ap {
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.5in;
                                        text-indent:-.5in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_head4ap {
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.6in;
                                        text-indent:-.6in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_head5ap {
                                        margin-top:0in;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:.7in;
                                        text-indent:-.7in;
                                        font-size:12.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Headingno {
                                        margin:0in;
                                        text-align:center;
                                        line-height:150%;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        span.WD_none {
                                        p.WD_none {
                                        margin:0in;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        span.WD_Normalnoindent {
                                        span.WD_Step1 {
                                        span.WD_subheaderno {
                                        font-weight:bold;
                                        p.WD_subheaderno {
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-bottom:0in;
                                        margin-left:0in;
                                        font-size:11.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        p.WD_Figuretitle {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:-.35pt;
                                        text-align:center;
                                        border:none;
                                        padding:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        font-style:italic;
                                        span.WD_Stepa {
                                        p.WD_Stepa {
                                        margin-top:8.0pt;
                                        margin-right:0in;
                                        margin-left:1.0in;
                                        text-indent:-.25in;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        margin-top:12.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        p.WD_tablecaption {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:8.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        font-style:italic;
                                        p.WD_CellRverdana9 {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:right;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_spacernormal8pt00 {
                                        margin:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        span.WD_LeadinEmphasis {
                                        font-weight:bold;
                                        font-style:italic;
                                        span.WD_Superscript {
                                        position:relative;
                                        top:0pt;
                                        span.WD_MyHighlight {
                                        font-family:"Microsoft Sans Serif"   ,sans-serif;
                                        font-weight:bold;
                                        span.WD_AtOnInUnderthewinfoldrtabareafield {
                                        letter-spacing:0pt;
                                        font-style:italic;
                                        span.WD_boldVerdana {
                                        letter-spacing:0pt;
                                        font-weight:bold;
                                        span.WD_passworditalic {
                                        position:relative;
                                        top:0pt;
                                        letter-spacing:.4pt;
                                        font-style:italic;
                                        span.WD_type {
                                        letter-spacing:.05pt;
                                        span.WD_optionselect {
                                        font-weight:bold;
                                        span.WD_Cell1L {
                                        p.WD_Cell2L {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Cell2C {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        p.WD_Cell1C {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        text-align:center;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        span.WD_FootnoteText {
                                        p.WD_GlossaryTerm {
                                        margin-top:1.0pt;
                                        margin-right:0in;
                                        margin-left:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        font-weight:bold;
                                        p.WD_calibri {
                                        margin:0in;
                                        font-size:10.0pt;
                                        color:windowtext;
                                        letter-spacing:0pt;
                                        span.WD_Ins {
                                        text-underline:double;
                                        color:blue;
                                        span.WD_Del {
                                        text-decoration:line-through;
                                        color:red;
                                        OL {
                                        margin-top:0px;
                                        margin-bottom:0px;
                                        UL {
                                        margin-top:0px;
                                        margin-bottom:0px;
                                        • 17. Re: Can I make bookmarks invisible?
                                          What you have shown are heading styles and you found that problem did not occur if you did not include the TOC in the link. I believe you then said there were other instances of this problem. I would need to see images of those.
                                          As far as the output is concerned, that is covered in Importing Using RoboHelp 9, 10 and 11 on my site. See Internal (Embedded) style sheet under Fixing the import. You are linking but there is a solution that will help. Alternatively you would have to use a find and replace operation on the output to remove the embedded style.
                                          @petergrainge
                                          • 18. Re: Can I make bookmarks invisible?
                                            shawnvw Level 1
                                            Here it is.
                                            Since the code references "default.css", I'm including that too:
                                            body {
                                            font-family: Arial;
                                            background-color: #ffffff;
                                            h1 {
                                            font-weight: bold;
                                            font-size: 24.0pt;
                                            color: #000000;
                                            x-next-class: ;
                                            x-next-type: p;
                                            LI.h1 {
                                            font-weight: bold;
                                            font-size: 24.0pt;
                                            color: #0000ff;
                                            h2 {
                                            font-weight: bold;
                                            font-size: 18.0pt;
                                            LI.h2 {
                                            font-weight: bold;
                                            font-size: 18.0pt;
                                            h3 {
                                            font-weight: bold;
                                            font-size: 14.0pt;
                                            LI.h3 {
                                            font-weight: bold;
                                            font-size: 14.0pt;
                                            h4 {
                                            font-weight: bold;
                                            font-size: 12.0pt;
                                            LI.h4 {
                                            font-weight: bold;
                                            font-size: 12.0pt;
                                            h5 {
                                            font-weight: bold;
                                            font-size: 10.0pt;
                                            LI.h5 {
                                            font-weight: bold;
                                            font-size: 10.0pt;
                                            h6 {
                                            font-weight: bold;
                                            font-size: 8.0pt;
                                            LI.h6 {
                                            font-weight: bold;
                                            font-size: 8.0pt;
                                            p {
                                            font-size: 12.0pt;
                                            margin-top: 0pt;
                                            margin-bottom: 0pt;
                                            LI.p {
                                            font-size: 12.0pt;
                                            a.expandspot {
                                            color: #008000;
                                            cursor: hand;
                                            font-style: italic;
                                            span.expandtext {
                                            font-style: italic;
                                            color: #ff0000;
                                            a.dropspot {
                                            cursor: hand;
                                            color: #008000;
                                            font-style: italic;
                                            a.glossterm {
                                            color: #800000;
                                            cursor: hand;
                                            font-style: italic;
                                            span.glosstext {
                                            font-style: italic;
                                            color: #0000ff;
                                            ol,
                                            ul {
                                            margin-top: 0px;
                                            margin-bottom: 0px;
                                            • 19. Re: Can I make bookmarks invisible?
                                              Can you let me have a Word document that will cause this problem?
                                              See the Contact page on my site and send the project as instructed there. Do make sure you include a link to this thread and please do not email the document direct.
                                              @petergrainge
